Dashticz - Module - Chromecast
aiolos
Domoticz version: stable
Post by aiolos »
I started using the dashticz screen a while ago, and missed an easy way to cast directly to my chromecast audio. So I created a module, highly inspired by the streamplayer that is already integrated (it uses even the same streams from the config)
It looks like this:
Screen Shot 2017-11-10 at 16.25.01.png (159.91 KiB) Viewed 4911 times
The play button is changed to the default cast button from google. When clicking on it, the default casting screen from chrome pops up, where you can select the available chromecasts in your network. The arrows on the left let you select the streams, on the right side the volume buttons are available.
The block is available as 'chromecast' in the config, for example
columns[3]['blocks'] = ['chromecast'];
The code is available on github: https://github.com/aiolos/dashticz_v2/tree/chromecast
Rob, I can make a pull request to integrate it, just let me know. It might need some tweaks for the sizes of the elements, since I use dashticz in portrait, so only one column.
Contributor to Dashticz
More on my Github profile
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Module - Chromecast
Post by robgeerts »
Thanks for your efforts!!
You can create a pull request on the beta branch!
freakshock
Post by freakshock »
Nice addon! Works great on Chrome but unfortunately not on the browser app I use on my tablet (Fully Kiosk Browser). Does it only support chrome?
aiolos
Post by aiolos »
I guess it only works in Chrome, since that natively supports casting. I have not really looked into support on other browsers. I also noticed that if you add a direct link to the page on the home screen, the browser first needs to be started.
gijsje
Domoticz version: Stable
Post by gijsje »
Works great even on the google home
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
H0ppie
Post by H0ppie »
Works great in my desktop browser!
Would be so great if Spotify could be connected to this. :oops:
EdwinK
Post by EdwinK »
Screen Shot 2018-11-09 at 23.31.06.png (111.61 KiB) Viewed 2722 times
Only got this block to show
marcom
Post by marcom »
EdwinK wrote: Friday 09 November 2018 23:31 Screen Shot 2018-11-09 at 23.31.06.pngOnly got this block to show
Hi Edwin, did you (or anybody else) ever managed to get this working?
I have the same problem as you described..
Been searching now for over 2 hours but couldn't find a solution...
code used in config.js is:
columns[2] = {}
columns[2]['blocks'] = [frames.weather,'chromecast',calendars.afval]
columns[2]['width'] = 5;
Thanks in advance,
Marcom
jaaap
Post by jaaap »
Same here, I have no idea how to get this to work. Anybody got a working setup and is willing to share how you did it?
