€10,- Temp/ humidity sensor: Froggit F007TH > not working
DrenLooc
Post by DrenLooc »
Dear Members,
I purchased some cheap Temp/Humid sensors from Amazon.de. (€9,99)
http://www.amazon.de/Transmitter-Froggi ... ds=froggit
I like these over many other sensors because of the small size, LCD screen, 8channel and IP rating.
I kind of hoped (expected?) these would work with the RFXcom TRX433E.
however, they are not detected by Domoticz.
In RFXmngr (in undec mode), I receive the following:
Packettype = UNDECODED RF Message
UNDECODED ARC:0F8440
(unit set in CH1)
How to get this device working in Domoticz?
I am not a programming type of guy :( ,so I'm also willing to donate a unit to the dev. team so they can add support for this device.
The rear of the device:
The units rear
The units rear
Anyone knows this?
b_weijenberg
Re: €10,- Temp/ humidity sensor: Froggit F007TH > not workin
Post by b_weijenberg »
Please contact support at rfxcom.com
RFX-433, RFX-433EMC, RFX-868
ThinkPad
Post by ThinkPad »
Big chance that b_weijenberg will get it working, i have good experiences with him when i sent him a device (cheap Banggood sensor).
Please report back here if it works, i am also interested.
I have subscribed to this topic (button at bottom of the page) so i will get a mail notification when a reply is posted ;)
DrenLooc
Post by DrenLooc »
OK, thanks guys..I will contact Support and inform about the results on this forum.
Gatsby
Domoticz version: 3.5065
Re: €10,- Temp/ humidity sensor: Froggit F007TH > not working
Post by Gatsby »
Anything new to report on this?
b_weijenberg
The F007TH is not (yet) supported by the RFXtrx.
This one is supported: http://www.banggood.com/433MHz-Wireless ... 65559.html
Gatsby
Post by Gatsby »
Thank you. :)
DeepB
Post by DeepB »
b_weijenberg wrote:The F007TH is not (yet) supported by the RFXtrx.
I bought this one. However I cannot find it in Domoticz. Anyone using this sensor care to explain how?
thank you
Daniel
greenisnews
Domoticz version: 3.8153
Post by greenisnews »
The RFXtrxE works perfect with F007TH in Domoticz v3.8153.
You must ensure the RFXtrxE use firmware Ext2. I run RFXtrx433_Ext2_1022.
See below.
F007TH, yes it works.jpg (106.92 KiB) Viewed 2208 times
ZStick-Gen5_ZW090-C, RFXtrx433E fw Ext2_1022
Boiler: HRT4 ASR-ZW, aka SSR303 with thermostat: HRT4-ZW, aka SRT321,
Plugs: GreenWave_z1, TKBHome-TZ69E, Temp: F007TH, Door/Window: DSB29
