First Blockly
dextm80
- Domoticz version: 4.10159
First Blockly
Hi guys, i'm trying my firts blockly
bun nothing happens
why?
tnx a lot
why?
tnx a lot
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
dextm80
Re: First Blockly
nothing change...
log write : 2017-10-29 18:22:40.670 EventSystem: reset all events...
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
DutchHans
Re: First Blockly
What does the 'current status' say about the sensor?.. thats the value you need to switch. And what about the light turning off.. you can't switch a light on that is already turned on.
Cheers, Hans
Cheers, Hans
dextm80
Re: First Blockly
Hi Hans,DutchHans wrote: Sunday 29 October 2017 18:58 What does the 'current status' say about the sensor?.. thats the value you need to switch. And what about the light turning off.. you can't switch a light on that is already turned on.
Cheers, Hans
current status is on/off both, the light start off and i want to switch on
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
cogliostrio
Re: First Blockly
The motion sensor switch is wrong. Your using a utility switch (purple), you need to use the switch under Devices --> Switches.
dextm80
Re: First Blockly
Thank you so much, now i understand the problem and all is ok!!!!!!!cogliostrio wrote: Sunday 29 October 2017 19:40 The motion sensor switch is wrong. Your using a utility switch (purple), you need to use the switch under Devices --> Switches.
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
DutchHans
Re: First Blockly
Hi, i meant cuttent status in the blockly environment. (The button on the bottom-right) You can see there what the value is when its idle and when the sensor is active.. depending on the type it could be on, motion or alarm etc...
Cheers,Hans
Cheers,Hans
dextm80
Re: First Blockly
Hi guys,
i'm implementig the blocky with other functions.....
i want that light switch on when motion sensor is on AND after SUNSET...
Now event don't do, without sunset function all is ok.
Any suggestion?
Thanks so much
Any suggestion?
Thanks so much
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
- StanHD
Re: First Blockly
Hi,dextm80 wrote: Monday 30 October 2017 11:59 Hi guys,
Any suggestion?
Thanks so much
I think you need "After Sunset" followed by "AND < 22:00" or perhaps for all night:- "OR Before Sunrise" so there is a distinct period for the condition.
Python:- Broadlink RM2, Sonos
