I've created several custom icons for switches which all work fine. I recently decided to edit the PNG files to change some colours, keeping all file names the same and recreating a new zip archive with the usual required 4 files. When uploading to Domoticz via the web interface, neither the 'update' option nor delete/re-upload work (the old icon stays cached somewhere). Restarting Domoticz doesn't help. Neither does manually overwriting the PNG files in the /domoticz/www/images directory.
Any ideas?
Custom icons not updating after edit Topic is solved
- philchillbill
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
SweetPants
Re: Custom icons not updating after edit
Clear your browser and app cache (those are separate things)
- philchillbill
Yep, that did it - thanks. I forgot that refreshing/reloading a page is not sufficient...
SweetPants
Can you mark this 'solved'??philchillbill wrote: Sunday 22 October 2017 23:55 Yep, that did it - thanks. I forgot that refreshing/reloading a page is not sufficient...
- philchillbill
Done
