Vocal command for Domoticz
forumfab
Post by forumfab »
Hi all Domoticz users
I suggest every one to take a look on this new application
With this precious tool, you'll have an easy solution to command your box like jarvis did ...
https://play.google.com/store/apps/deta ... .pro&hl=fr
There is two products, and old version ( more than one year), an a new one version 2
In both cases , there is a free version ( to test), and an other one, witch will give you a full access to all the product power
Now, the product documentation in english
http://jarvishome.fr/index.html
http://jarvishome.fr/doc.html
Bests regards
zak45
Domoticz version: V2024.4
Re: Vocal command for Domoticz
Post by zak45 »
Cool !!
actually have automate + Okay google but if this one do the same thing and stay local...
give it a try asap.
EdwinK
Post by EdwinK »
This looks cool. Now we need some configuration's to use it for domoticz (and Toon and Hue).
forumfab
Post by forumfab »
EdwinK wrote: Monday 16 October 2017 9:28 This looks cool. Now we need some configuration's to use it for domoticz (and Toon and Hue).
Hi Edwink
I suppose than you did observed that you can download full ready solutions on the site, and then configure them with you personnal IP API commands
http://jarvishome.fr/download.html
First of all install a Butler (Kind) or (Wise)
Then install a command scenario template by download it, and filling your ip API Command, like
http://your_ip_domoticz:8080/json.htm?type=command&param=switchlight&idx=99&switchcmd=On for Open scenario part
http://your_ip_domoticz:8080/json.htm?type=command&param=switchlight&idx=99&switchcmd=Off for Close scenario part
And so on
It's really easy to use
You will just have to folow this explanation to start
http://jarvishome.fr/howToStart.html
Every think is indicated step by step
Best regards
zak45
Post by zak45 »
so... tested ... approved it ...like it. :-)
This will replace my Ok Google + Automate...
Once you have understand the way this work, so cool things can be made.
Really nice piece of software, thanks to the devloper.
PS even bought pro version to help
PascalEM
Post by PascalEM »
This is my first post, so I present myself. I'm the developper of this android application.
And for your information, there is a new version available.
The main feature is that you can manage multiple Jarvis@Home installed on multiple android systems, and you will be able to synchronize the configurations between all of them.
Personnally, I share the configurations between my home tablet, my personnal mobile phone and an old phone set in my bathroom :)
To start: http://jarvishome.fr/howToStart.html
See you soon,
zak45
Post by zak45 »
@PascalEM
welcome and congratulation for your soft.
the synchronization is really a good feature.
will try that as my goal is to use your soft for voice command.
PascalEM
Post by PascalEM »
I published a new beta version, I give you the details to install it below.
But first here are the new features:
- Scenarios/actions can be executed on a remote mobile (notification, TTS, openUrl, tasker, etc...)
- Android TV Support
- More actions available in the free version
- Options are added in the application settings to choose which service must be started at launch (Http Server and/or Voice Recognition)
- New action to generate notification with a vibration schema
- new Google translation toolbar in the interface
And the bugfixes:
- Review of the volume management
- system.lastSpeech now returns the TTS sentence
- Fix of the Kill action
- Multiple Bug fixes
To get the beta, you just have to follow the links below:
- for the Free Version: https://play.google.com/apps/testing/co ... is.home.v2
- for the Pro Version : https://play.google.com/apps/testing/co ... ome.v2.pro
Do not hesitate to give me feedbacks by email or in this forum
Thanks and see you soon,
Pascal
blauwebuis
Domoticz version: current
Post by blauwebuis »
This could give voice control AND protect privacy, right? It doesn't need the cloud? If so: brilliant!
PascalEM
Post by PascalEM »
Hi @blauwebuis,
Yes there is no cloud for the voice recognition everything is local.
To be really honest: If you execute a scenario on a "remote" device, in this case I need the cloud to determine the location of the device. It is the only case where the cloud is required, but it is your choice to use or not this feature.
Pascal
PascalEM
Post by PascalEM »
I published a new version. It allows you to have an overview of variables & synonyms of all your configurations.
You can edit quickly variables/synonyms value without opening the configuration.
It's easier, allows you to have a quick look on the variables and allows you to stabilize the synonyms accross all the configurations.
Example
and
Thanks,
Pascal
zak45
Post by zak45 »
that's great...
I use it now since weeks and surprised by the power: able now to put up/down sound level of my TV, change channels, request if it will rain or not, put on/off my lights/TV..., have rooms temperature etc ...
AND all of that stay local... nothing to go outside :-)
really great piece of software.
PascalEM
Post by PascalEM »
I published a new version that fix some bugz, but mainly that improve the reactivity of the Jarvis answers. Is is already available.
Here are the changes:
Improvement of the Jarvis reactivity
Bugfix of the httpServerStop & VoiceRecognitionStop actions
Bugfix of the group name that was not saved
Bugfix of the stop action in the notification area
Thanks,
Pascal
zak45
Post by zak45 »
FYI: in process to write a Python Plugin to have a full integration with Jarvis: automatic creation of scenarios.
kniazio
Domoticz version: 3.7243
Post by kniazio »
A great application.
I encourage you to create your own configurations. Especially in Polish :)
zak45
Post by zak45 »
right.
this is the reason why will spend some time to create configuration in automatic way.
For the moment, On/Off devices are managed and working.
Can retreive temperature and ask it.
Remaining:
lights/dimmer
scenarios
.. and some extra
All, if possible, in native language.
kniazio
Post by kniazio »
I installed the Jarvis @ Home v2 application on a device with Android 8.1.
All the time when I'm using I get this message:
Developer warning for package "com.emily.jarvis.home.v2"
Failed to post notification on channel"null"
See log for more details
Please help
zak45
Post by zak45 »
Have updated my samsung to 8.x version. Do not have this problem ??!!!
zak45
Post by zak45 »
some news about the plugin:
On/Off - dimmer - temperature - Thermostat - scenario/group
already work and under deep testing !!
renerene
Post by renerene »
Fresh install, newbie:
1) it only recognises first words, not sentences.
Like if the recognition is only done for 0.2 secs.
2) can it be used in conjunction with Google Assistent?
3) can it be used on a Alexa or Home device (dedicated)? Or only tablets and phones
