I run Domoticz on a Synology NAS.
My ZWave controller is an Aeotec ZW090 Z-Stick Gen5 EU.
I have several ZWave devices connected and they work fine.
Recently I bought a couple of Neo Coolcam PIR sensors. I connected two, they are connected as you can see but not recognised.
Manufacter name is empty, ID and Type are both 0x0000.
I checked manufacturer_specific.xml, it has a section for Neo:
<Manufacturer id="0258" name="Neo CoolCam">Code: Select all
<Product type="0003" id="0083" name="Battery Powered PIR Sensor" config="shenzen_neo/nas-pd01z.xml"/>
<Product type="0003" id="1083" name="Battery Powered PIR Sensor" config="shenzen_neo/nas-pd01z.xml"/>
Since Manufacter name is empty, ID and Type are both 0x0000, I think the problem is the handshake between the Neo devices and my ZWave controller.
Anyone has the same problem?
Anyone with ideas?
Any help much appreciated.
Cheers,
Emiel
