[MyDomoAtHome] Support thread
Eternity
Re: [MyDomoAtHome] Support thread
Ignore
Synology DS218+
Homey controller
Z-Wave stuff (Fibaro / Aeotec / NEO Coolcam)
Zigbee stuff (Aqara)
HUE lights
Logitech Harmony Ultimate + Hub
IP camera's
Homey controller
HUE lights
IP camera's
- EdwinK
- Domoticz version: BETA
Searched through the posts here, but it looks like this can't be installed on Synology D413j (armv5).
- epierre
are you on DSM5 ? then use(not my latest but should work):EdwinK wrote: Friday 29 September 2017 16:52 Searched through the posts here, but it looks like this can't be installed on Synology D413j (armv5).
https://e-nef.com/domoticz/mdah/node-my ... 0.1.56.spk
If you have only node in v1.0 this will not work till synology does a node version for you.
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
Ady92100
- Domoticz version: >V3.6796
Hello
I've tried to install Mdah for a DS212.
Due to request to install nodejs-V4( not available for DS212), I install Mdah on a PI 2 as a gateway for Dz installed on the DS212.
Does a DS212 version of Mdah exist ?
A DZ (test version) with several devices is installed on the PI, besides Mdah.
With Mdah i've only access to the PI's devices and not to the DS212's devices managed by DZ on the DS212.
in the log I found this
in config.json the configuration is that one
I understand that Mdah for whatever reason is unable to read the config.json file and uses default parameter (localhost = Pi) and therefore the Pi's devices.
How to solve this issue ?
for me it's not a login isssue, Mdah simply do not use my config.json file located in /etc/mydomoathome
Where to start to solve this?
Thanks for your help.
{"level":"warn","message":"basic configuration not found in /etc/mydomoathome/config.json, defaulting","timestamp":"2017-10-05T20:47:26.371Z"}
{"level":"warn","message":"domoticz access configuration not found in /etc/mydomoathome/config.json, defaulting","timestamp":"2017-10-05T20:47:26.431Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8080/json.htm","timestamp":"2017-10-05T20:47:26.589Z"}
"app_name": "MyDomoAtHome",
"auth": null,
"domoticz": {
"ssl": false,
"host": "192.168.1.xx",
"port": "8084",
"path": "/",
"auth": null,
"port": 3002,
"passcode": " "
Synology DS212 + RFXTrx433 + AEon Stick S2
Oregon - Thgr122Nx / Chacon - module 1000w - détecteur de fumée 34131 / OWL -CM180 / Greenwave Multiprise
- epierre
I can make one, but I can't verify the node version you have, and only a version >=0.12 works...Ady92100 wrote: Friday 06 October 2017 19:31 Hello
check that /etc/mydomoathome is readable by the user is is launched as ( do a 'ps aux|grep node' ), same for config.jsonAdy92100 wrote: Friday 06 October 2017 19:31 A DZ (test version) with several devices is installed on the PI, besides Mdah.
I understand that Mdah for whatever reason is unable to read the config.json file and uses default parameter (localhost = Pi) and therefore the Pi's devices.Code: Select all
{"level":"warn","message":"basic configuration not found in /etc/mydomoathome/config.json, defaulting","timestamp":"2017-10-05T20:47:26.371Z"} {"level":"warn","message":"domoticz access configuration not found in /etc/mydomoathome/config.json, defaulting","timestamp":"2017-10-05T20:47:26.431Z"} {"level":"info","message":"Domoticz server: http://127.0.0.1:8080/json.htm","timestamp":"2017-10-05T20:47:26.589Z"}
Ady92100
Hello
Thanks for your answer
for DS212, unfortunatly I use V0.10, so it won't work.
The result of 'ps aux | grep node'
and
The result of 'ps aux | grep config.json'
does it help ?
pi@raspberrypi:~$ ps aux|grep node
www-data 12252 0.0 3.1 119004 13928 ? Sl oct.05 0:12 node /usr/local/bin/forever --minUptime 5000 --spinSleepTime 2000 --max-old-space-size=128 -a -l /var/log/mydomoathome/mdah.log /usr/share/mydomoathome/app/mdah.js
www-data 12261 0.0 5.9 128588 26372 ? Sl oct.05 0:21 /usr/bin/node /usr/share/mydomoathome/app/mdah.js
pi 19352 0.0 0.4 4292 1916 pts/0 S+ 21:38 0:00 grep node
pi@raspberrypi:~$ ps aux|grep config.json
pi 19357 0.0 0.4 4292 1972 pts/0 S+ 21:38 0:00 grep config.json
- epierre
I would say do a :
chmod a+rx /etc/mydomoathome
chmod a+rx /etc/mydomoathome/config.json
Ady92100
I did it. I still have the same problem.
I noticed inthe log a parsing issue :
{"level":"error","message":"Global conf parsing issue !","timestamp":"2017-10-06T20:57:38.205Z"}
{"level":"error","timestamp":"2017-10-06T20:57:38.600Z"}
{"level":"error","message":"Global conf load issue !","timestamp":"2017-10-06T20:57:38.808Z"}
{"level":"error","timestamp":"2017-10-06T20:57:38.854Z"}
{"level":"warn","message":"basic configuration not found in /etc/mydomoathome/config.json, defaulting","timestamp":"2017-10-06T20:57:38.972Z"}
{"level":"warn","message":"domoticz access configuration not found in /etc/mydomoathome/config.json, defaulting","timestamp":"2017-10-06T20:57:39.041Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8080/json.htm","timestamp":"2017-10-06T20:57:39.205Z"}
{"level":"info","message":"Node version: 4.2.2","timestamp":"2017-10-06T20:57:39.228Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.26","timestamp":"2017-10-06T20:57:39.249Z"}
{"level":"info","message":"OS version: Linux linux 4.9.24+","timestamp":"2017-10-06T20:57:39.272Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.1.41 in /var/www /usr/share/mydomoathome","timestamp":"2017-10-06T20:57:39.332Z"}
{"level":"info","message":"MDAH port: 3002","timestamp":"2017-10-06T20:57:39.682Z"}
{"level":"info","message":"Refreshing version cache: v0.2.26","timestamp":"2017-10-06T20:57:43.152Z"}
- epierre
yes, no comma before a closing parenthesis
"auth": null, => "auth": null
- epierre
Hi All,
In the latest version you have support for Farenheight temperature ( imperial mesure, not international).
febalci
Version 0.2.27 gives referenceerror: tempmode not defined; and exits in synology package. Couldnt started it.
Ady92100
Hello epierre
Thanks for the explanation, it works now
My config.json was a copy of the "easydomoticz" https://easydomoticz.com/imperihome-no ... on-nodejs/ post. I will send a request for improvement to patrice.
- epierre
@febalci strange, latest is 0.2.29 and without the tag it work here.
try adding
"tempmode": "C",
just after app_name in /etc/mydomoathome/config.json
try adding
"tempmode": "C",
febalci
Hmm, where can i find config.json in a synology package install? /etc/mydomoathome folder doesn't exist.
- jumbotroll
Maybe /var/packages/MyDomoAtHome/etcfebalci wrote: Saturday 07 October 2017 21:19 Hmm, where can i find config.json in a synology package install? /etc/mydomoathome folder doesn't exist.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- epierre
just manually installed 0.2.29 opn my DS216j without any issue.
in case you have an issue, access your synology as admin, create /etc/mydomoathome and in it a config.json just as in the config.json section in:
https://github.com/empierre/MyDomoAtHome
- epierre
tried this one unsuccessfully: /var/packages/MyDomoAtHome/etc
this one works:
access your synology as admin, sudo to create /etc/mydomoathome and in it a config.json
this one works:
febalci
Thanks epierre, that solved the problem.
- epierre
@febalci which synology version are you running on ? on my DSM6 on DS216j I did not had the issue.
looking back
looking back
looks more a 0.2.27 version issue, you should move to 0.2.29Version 0.2.27 gives referenceerror: tempmode not defined; and exits in synology package. Couldnt started it.
febalci
I was already moved to 0.2.29. Had same problem again. Then uninstalled mydomoathome.spk and reinstalled it. Same problem. Didnot had any problem with 0.2.26. creating the folder and config.json solved it. Synology DS916+ with latest 6.2 dsm.
