Hi, I have an issue with notifications from dzVents.
In the following code I have added a domoticz.notify string. When executed the logg tells me the notification was sent successfully, but in Pushbullet and Telegram I only get a message containing "-2". What's causing this?
active = true,
timer = {'at 23:00-06:00'},
-- your script logic goes here, something like this:
if (domoticz.devices('AJ lampe').state == 'On') then
domoticz.devices('AJ lampe').switchOff()
domoticz.notify('Leselys AJ lampe slått av for natten.', domoticz.PRIORITY_LOW)
domoticz.log('Leselys AJ lampe slått av for natten.')
