Notifications sending -2
thorbj
Post by thorbj »
Domoticz version 3.8153
Hi, I have an issue with notifications from dzVents.
In the following code I have added a domoticz.notify string. When executed the logg tells me the notification was sent successfully, but in Pushbullet and Telegram I only get a message containing "-2". What's causing this?
    active = true,
        timer = {'at 23:00-06:00'},
        -- your script logic goes here, something like this:
        if (domoticz.devices('AJ lampe').state == 'On') then
            domoticz.devices('AJ lampe').switchOff()
            domoticz.notify('Leselys AJ lampe slått av for natten.', domoticz.PRIORITY_LOW)
            domoticz.log('Leselys AJ lampe slått av for natten.')
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
BakSeeDaa
Re: Notifications sending -2
Post by BakSeeDaa »
Wrong number of arguments to the notify function.
Have a look at this:
domoticz.notify('Leselys', 'Leselys AJ lampe slått av for natten.', domoticz.PRIORITY_LOW)
thorbj
Post by thorbj »
Great, that did the trick!
