Generic Denon / Marantz python plugin
italoc
Re: Generic Denon / Marantz python plugin
i'm trying to use this plugin width latest beta of domoticz, but in hardware if i select DENON plugin i can't add the hardware, i obtain this error
" Do not enable this option for devices that do not receive data! "
any ideas?
any ideas?
Hello rjblake,
i found the problem for me in your code....marked in red
THX, Andyyyyrjblake wrote: # Changed for Denon AVR-X2300W
<param field="Mode3" label="Sources" width="550px" required="true" default="Off|SAT/CBL|DVD|BD|GAME|AUX1|MPLAY|TV|AUX2|TUNER|USB/IPOD|CD|BT|IRP|FVP”/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
rjblake
Andyyyy - glad you found it - was going to suggest using the standard script as opposed to mine. Can't see any red text, so not sure what was different?
it is the last quote mark in the Sources section.
Andyyyy
Andyyyy
elgringo
- Domoticz version: Left
Plugin works great!
I have a Marantz SR5009. When I enable it via the amin zone selction from 'Off' to 'Tuner', both the main zone and zone will enabled and switch to tuner.
Is this a bug?
And is it possible to disable zone2?
EDIT: I rewrote the plugin only for Zone 1
Is this a bug?
- gielie
- Domoticz version: latest β
After the latest beta update and the changes they made in python the Denon plugin doesn't work anymore.
Does someone have a solution to make the plugin working again?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
rjblake
Ah - damn the different types of "''s ...and being colourblind! I've corrected in my earlier post in case anyone else just does a copy/paste.Andyyyy wrote:Hi,
Andyyyy
rjblake
Have not updated my Domoticz for a few weeks. Will look into it. I know there was/is a change planned to the Python plugin and how it is being handled. This is documented here https://www.domoticz.com/forum/viewtopi ... 95#p134695. Also, there was an issue with Python not starting with one of the recent beta versions, so this may be related and fixed in a later beta version.gielie wrote:After the latest beta update and the changes they made in python the Denon plugin doesn't work anymore.
Thunderbolt
- Domoticz version: 4.11665
After trying to find the reason why Domoticz is crashing randomly, I found the reason in the denon plugin.
When it's activated, domoticz is crashing randomly a few times a day. I activated the log and found something, but I don't know what it means.
Maybe someone of you can help me.
Domoticz Version: 3.7976
Python version '3.4.2'
plugin key="Denon4306" version="2.5.4"
Here are the last enries in the log:
2017-06-17 23:52:11.176 (RFXtrx) Temp (Unknown)
2017-06-17 23:52:19.269 Hardware Monitor: Fetching data (System sensors)
2017-06-17 23:52:19.285 (X3300) Calling message handler 'onHeartbeat'.
2017-06-17 23:52:19.286 (X3300) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2017-06-17 23:52:19.286 (X3300) Sending 4 bytes of data:.
2017-06-17 23:52:19.286 Error: Domoticz received fatal signal 11 !...
2017-06-17 23:52:19.287 (X3300) 5a 4d 3f 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ZM?.
2017-06-17 23:52:19.292 Error: /home/pi/domoticz/domoticz() [0x1cca74]
2017-06-17 23:52:19.292 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1ccb2c]
2017-06-17 23:52:19.292 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76a8f180]
lbuijk
italoc wrote:i'm trying to use this plugin width latest beta of domoticz, but in hardware if i select DENON plugin i can't add the hardware, i obtain this error
any ideas?
Did you get a solution? I have the same problem....
(Domoticz 3.8072)
simon_rb
- Target OS: -
Whats the correct way of loading this plugin? Can't quite workout on after reading through this thread. I have tried various methods all resulting with many errors.
Cheers
Cheers
- G3rard
- Target OS: -
- Domoticz version: No
@simon_rb, I use the attached plugin with Domoticz v3.8153 stable.
Just remove _.txt from the filename, I couldn't upload it otherwise.
Not using Domoticz anymore
simon_rb
- Target OS: -
Cheers G3rard.. Come to my rescue again!G3rard wrote: Saturday 12 August 2017 23:32 @simon_rb, I use the attached plugin with Domoticz v3.8153 stable.
plugin.py_.txt
Working now
madiep
I'm kinda new to this all, but I have a set-up that's working for me now. Last thing I wanted to add is this plugin, which is my first plugin. Can't seem to get it work though.
I'm running:
- Pi Zero +W
- Raspbian Stretch
- Python v3.5.3-1
- Domoticz V3.8153
I created a folder denon in the plugins folder, then I created a file called plugin.py with nano and pasted the contents of the txt file above in it. I used sudo chmod 775 to give it the appropriate permissions. Then restarted domoticz.
The error I am seeing in the log is:
What am I missing?
I'm running:
- Pi Zero +W
- Raspbian Stretch
- Python v3.5.3-1
- Domoticz V3.8153
Error: PluginList: Parsing '/home/pi/domoticz/plugins/denon/', 'Error document empty.' at line 0 column 0 in XML- Dnpwwo
@madiep,
There are a few versions of this plugin floating around so you need to be more specific.
There is an example that ships with Domoticz under /plugins/examples but there are others as well. If you are running a current beta there is one i the 'python-enabled' branch that will auto-discovery the receiver for you. For most you need to specifiy a fixed IP address.
If you post where you got the plugin file (and the version number from inside the file) from and what make/model of receiver you have that will help.
madiep
Txs for your help. I was talking about this one:
The next issue I am having is finding devices. The log shows me some errors:
I think I just fixed it by removing the three quotation marks in the first uncommented line. So the plugin is now loading fine, and I am able to add my receiver in the hardware menu.G3rard wrote: Saturday 12 August 2017 23:32 @simon_rb, I use the attached plugin with Domoticz v3.8153 stable.
download/file.php?id=12388
2017-09-02 14:27:16.494 Error: (Denon) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/denon/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2017-09-02 14:27:16.494 Error: (Denon) Module Import failed, exception: 'SyntaxError'
2017-09-02 14:27:16.494 Error: (Denon) Import detail: File: /home/pi/domoticz/plugins/denon/plugin.py, Line: -1351624480, offset: 10
2017-09-02 14:27:16.494 Error: (Denon) Error Line ''
2017-09-02 14:28:30.227 Error: Denon hardware (2) thread seems to have ended unexpectedly-
simon_rb
- Target OS: -
Looking at upgrading my Denon to the X4300 as its last years model an going cheaper. I assume this plugin will not work as I think the http stuff has been removed from the 4300 & 6300 amps. I currently control mine using TEL NET and I think thats still working.. I think. Just wondered if anyone on here has had success with the X4300?
Cheers
Cheers
nixalsschrott
- Domoticz version: 2020.2
Dear friends,
what’s about the latest 2017 series from Denon, eg x1400H - are the latest models still supported? I have tried with the Telnet script, but do not get any response from Receiver, when changing values through remote control. Actually I am not able to install the generic script, because I get error - script is not starting and Receiver does not show up in hardware selection.
Kind regards
Matty
Kind regards
Matty
Domoticz Beta | Aeon Labs Z-Wave USB Stick Gen5 | Cyrus SmartHome 4-in-1 Multisensor | Qubino ZMNHCD1 - Roller Shutter | NEO COOLCAM NAS-WR01ZE Power Plug | Fibaro FGRGB-101 | WEMOS D1 MINI (ESP8266) Sensors CO2/TEMP/BARO |
- LouiS22
Works fine for me, I also own x1400H. To tell the truth I don't recall which plugin was the correct one, but gonna upload it once I get home.nixalsschrott wrote: Friday 26 January 2018 7:52 Dear friends,
Kind regards
Matty
nixalsschrott
Super. Thanks I’m advance. What Domoticz version you are using actually? I am on latest stable.
Users browsing this forum: PatrickH67 and 1 guest
