Hi.
I think DS718+ will use arch-denverton and kernel 4.4.15, then the USB serial drivers will not be compatible with DS716+II.
I will check out the new kernel source code and toolchain and compile a test version when someone want to test.
Hi.
Changed to Apollolake!
What DSM version du you have installed on this device?wedge34 wrote: ↑Friday 22 September 2017 15:36 Hello
I managed to install Domoticz adding http://www.jadahl.com/domoticz_stable/ into the synlogy package center.
but it doesn't start and i have no error message.
I have a Synology EDS14 can you help me ?
You have the right version of my package, compiled with arch-armada370 and it should work.
Unfortunately, I'm not familiar with EDS14, so I do not have much to contribute with to this model. It works with Raspberry Pi and it also uses sd card.
