which is the best way to control a gate and know the status?
i think to use fibaro roller shutter 2, but in the manual says to don't connect motor in DC, only AC motor is supported
my motor works in DC, but in the mainboard i have 24V AC contact.
any ideas?
thanks
gate opener and status best way
- emme
- Domoticz version: latest
Re: gate opener and status best way
why don't use a dry contact to apply the 2 buttons proided by the motor for open/close?
the positioning could be quite difficult, specially if you have a logic control board that should provide it somehow (and normally they don't)
I've seen around that some users define movements with ultrasonic radars and other stuff (like mysensors)
Or.. under zWave environment, aeontec provide a garagedoor controller that could be helpful
ciao
M
ciao
M
"We always done this way"
this is external GATE, product like AEONTEC garagedoor works in indoor garage...
can uou explain such a hunch you mean with "use a dry contact to apply the 2 buttons proided by the motor for open/close" ???
- Domoticz version: 4.11083
Why don't you use 2 door/window sensors and a z-wave switch.
instead of on off you could set it to open close
success
Jan
success
Jan
You could take the fibaro ones and "pack" the sensor part.
the magnet is outdoor resistent allready
- Domoticz version: 4.10538
It's just a magnet, it will work when it's wet. The sensor part however needs to be 'packed' (protected from water)
