Python Plugin: Broadlink RM2 V3
- Domoticz version: V2024.4
Re: Python Plugin: Broadlink RM2 V3
@srill
Does it work with e-control ?
@zak45
Thank you so much for this informations and your help.
I knew the plugin command iSamsung but not this one. I will look at it.
- Sjonnie2017
- Domoticz version: Latest ß
Hi All,
Small problem with the import feature here
I got the plugin working and copied the 3 json files over to the folder import as shown below:
I tried the Generate option on the switch and the Import option but the simulate.txt or accompanying ini files are not created. I changed permissions on the files but that did not help.
Any tips or help greatly appreciated!
Greetz,
Sjonnie
pi@RPi3:~/domoticz/plugins/BroadlinkRM2/import $ ls -al
total 140
drwxr-xr-x 2 pi pi 4096 Sep 11 19:15 .
drwxr-xr-x 4 pi pi 4096 Sep 11 19:10 ..
-rwxr-xr-x 1 pi pi 28355 Jan 1 1970 jsonButton
-rwxr-xr-x 1 pi pi 99402 Jan 1 1970 jsonIrCode
-rwxr-xr-x 1 pi pi 1057 Jan 1 1970 jsonSubIr
Greetz,
Sjonnie
YouLess Energy meter
@Sjonnie2017
the import folder need to be :
<<Folder to store ini files>>/import
if this is the case, put plugin in debug mode and show us the Domoticz log when you push 'generate'
- Sjonnie2017
Hi Zak,zak45 wrote:@Sjonnie2017
Tx for your reply! I will give it a try tomorrow and let you know.
Greetz,
Sjonnie
Verstuurd vanaf mijn YOGA Tablet 2-1050F met Tapatalk
This is my first post so I want to say hello
I was thinking about Broadlink RM2 in my setup and have a question.
I want something like this:
- push a button on harmony remote control,
- broadlink will recive a code from remote, send data to domoticz,
- domoticz will send data to broadlink to switch on a 433MHz sockets and after a few second will turn on, lets presume, tv by infrared.
Is it possible to do this with this plugin ?
RPi2 + sonoff + 433MHz + Xiaomi Gateway + EQ-3 MAX!
in fact, this is not related to the plugin...
but Broadlink is similar to your harmony remote control (more or less), this device do not listen continiously, only during learn process.
EDIT:
For one of my project ...this has been solved by using an ESP8266 + IR receiver
- Sjonnie2017
Hi Zak,
Changed folder location and the import worked.
Now I have some 150 switches to choose from (4 simple remotes ). Every button has it's own switch in Domoticz. Not every description is clear but that's a Broadlink problem, not your plugins.
This will do for my intended scenario Tx!
Greetz,
Sjonnie
EDIT: Unfortunately none of the buttons/switches work. The eControl app functions properly. I will try the learn function and let you know.
EDIT2: I forgot to mention that I get an error every 5 minutes:
2017-09-12 19:20:12.987 Error: (Broadlink) Error Connecting to Broadlink device....
[/quote]
EDIT:
[/quote]
Thank you for the idea I will connect ir receiver to raspberry .
EDIT:
[/quote]
- Domoticz version: 2024.4
i have this error :
pi@raspberrypi:~ $ pip3 install broadlink
Downloading/unpacking broadlink
Downloading broadlink-0.5.tar.gz
Running setup.py (path:/tmp/pip-build-kjrvrc6j/broadlink/setup.py) egg_info for package broadlink
Downloading/unpacking pycrypto==2.6.1 (from broadlink)
Downloading pycrypto-2.6.1.tar.gz (446kB): 446kB downloaded
Running setup.py (path:/tmp/pip-build-kjrvrc6j/pycrypto/setup.py) egg_info for package pycrypto
Installing collected packages: broadlink, pycrypto
Running setup.py install for broadlink
error: could not create '/usr/local/lib/python3.4/dist-packages/broadlink': Permission denied
Complete output from command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-kjrvrc6j/broadlink/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-kv8mu0ga-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib
creating build/lib/broadlink
copying broadlink/__init__.py -> build/lib/broadlink
running egg_info
writing broadlink.egg-info/PKG-INFO
writing dependency_links to broadlink.egg-info/dependency_links.txt
writing top-level names to broadlink.egg-info/top_level.txt
writing requirements to broadlink.egg-info/requires.txt
warning: manifest_maker: standard file '-c' not found
reading manifest file 'broadlink.egg-info/SOURCES.txt'
writing manifest file 'broadlink.egg-info/SOURCES.txt'
running install_lib
creating /usr/local/lib/python3.4/dist-packages/broadlink
Cleaning up...
Command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-kjrvrc6j/broadlink/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-kv8mu0ga-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-kjrvrc6j/broadlink
Storing debug log for failure in /home/pi/.pip/pip.log
You dont have permissions. Run command with sudo
sudo pip3 install broadlink
Hello!
Guys, I really need help. I've installed new stretch, domotics and broadlink plugin. But no matter what I do it doen't work for me. I followed the wiki directly, step by step, but still I get this in the log.
Next, if I click on the discovery device it doesn't come on, in the log I see:
I know, I've asked a couple of times, but I have no idea what is wrong. The install procedure goes smoothly, all the directories are created, libs copied...
Please help!
P.S. If I fill in the IP and mac of the broadlink I get this:
Looks like it messes up the mac and port number...
2017-09-13 20:59:35.769 (BroadlinkRM2) Initialized version 3.0.0, author 'zak45'
2017-09-13 20:59:35.775 (BroadlinkRM2) Debug log level set to: 'true'.
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Mode1':'000000000000'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Mode2':'/home/pi/domoticz/plugins/BroadlinkRM2'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Port':'0'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Name':'BroadlinkRM2'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'HardwareID':'17'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Mode4':'yes'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Address':'127.0.0.1'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Key':'BroadlinkRM2'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Author':'zak45'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Mode3':'yes'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Mode5':'9000'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Mode6':'Debug'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'Version':'3.0.0'
2017-09-13 20:59:35.776 (BroadlinkRM2) 'HomeFolder':'/home/pi/domoticz/plugins/BroadlinkRM2/'
2017-09-13 20:59:35.776 (BroadlinkRM2) Device count: 4
2017-09-13 20:59:35.777 (BroadlinkRM2) Device: 1 - ID: 252, Name: 'BroadlinkRM2 - Discover', nValue: 0, sValue: 'Off'
2017-09-13 20:59:35.777 (BroadlinkRM2) Device ID: '252'
2017-09-13 20:59:35.777 (BroadlinkRM2) Device Name: 'BroadlinkRM2 - Discover'
2017-09-13 20:59:35.777 (BroadlinkRM2) Device nValue: 0
2017-09-13 20:59:35.777 (BroadlinkRM2) Device sValue: 'Off'
2017-09-13 20:59:35.777 (BroadlinkRM2) Device LastLevel: 0
2017-09-13 20:59:35.777 (BroadlinkRM2) Device: 2 - ID: 253, Name: 'BroadlinkRM2 - Temp', nValue: 0, sValue: ''
2017-09-13 20:59:35.777 (BroadlinkRM2) Device ID: '253'
2017-09-13 20:59:35.777 (BroadlinkRM2) Device Name: 'BroadlinkRM2 - Temp'
2017-09-13 20:59:35.777 (BroadlinkRM2) Device sValue: ''
2017-09-13 20:59:35.777 (BroadlinkRM2) Device: 254 - ID: 254, Name: 'BroadlinkRM2 - Remote', nValue: 0, sValue: ''
2017-09-13 20:59:35.777 (BroadlinkRM2) Device ID: '254'
2017-09-13 20:59:35.777 (BroadlinkRM2) Device Name: 'BroadlinkRM2 - Remote'
2017-09-13 20:59:35.778 (BroadlinkRM2) Device LastLevel: 0
2017-09-13 20:59:35.778 (BroadlinkRM2) Device: 255 - ID: 259, Name: 'BroadlinkRM2 - Import', nValue: 0, sValue: 'Off'
2017-09-13 20:59:35.778 (BroadlinkRM2) Device ID: '259'
2017-09-13 20:59:35.778 (BroadlinkRM2) Device Name: 'BroadlinkRM2 - Import'
2017-09-13 20:59:35.778 (BroadlinkRM2) Device nValue: 0
2017-09-13 20:59:35.778 (BroadlinkRM2) Device sValue: 'Off'
2017-09-13 20:59:35.778 (BroadlinkRM2) Connecting to: 127.0.0.1:000000000000
2017-09-13 20:59:35.791 Error: (BroadlinkRM2) Error Connecting to Broadlink device....
2017-09-13 20:59:35.791 (BroadlinkRM2) Device Number begin to : 2
2017-09-13 20:59:35.797 (BroadlinkRM2) No ini file :/home/pi/domoticz/plugins/BroadlinkRM2/remote/plugin_remote_17.ini
2017-09-13 20:59:35.797 (BroadlinkRM2) Custom Commands for Remote not managed
2017-09-13 20:59:35.798 (BroadlinkRM2) Heartbeat interval set to: 30.
2017-09-13 20:59:45.313 (BroadlinkRM2) Calling message handler 'onHeartbeat'.
2017-09-13 21:01:44.885 User: Admin initiated a switch command (252/BroadlinkRM2 - Discover/On)
2017-09-13 21:01:44.891 (BroadlinkRM2) Calling message handler 'onCommand'.
2017-09-13 21:01:44.891 (BroadlinkRM2) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2017-09-13 21:01:44.891 (BroadlinkRM2) All plugin system is on pause for 5s...
2017-09-13 21:01:49.897 (BroadlinkRM2) Found 1 broadlink devices
2017-09-13 21:01:49.909 Error: (BroadlinkRM2) 'onCommand' failed 'TypeError':'sequence item 0: expected str instance, bytes found'.
2017-09-13 21:01:49.909 Error: (BroadlinkRM2) ----> Line 210 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function onCommand
2017-09-13 21:01:49.909 Error: (BroadlinkRM2) ----> Line 397 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function Discover
2017-09-13 21:01:49.909 Error: (BroadlinkRM2) ----> Line 203 in /usr/lib/python3.5/broadlink/__init__.py, function auth
2017-09-13 21:01:49.909 Error: (BroadlinkRM2) ----> Line 258 in /usr/lib/python3.5/broadlink/__init__.py, function send_packet
2017-09-13 21:01:49.909 Error: (BroadlinkRM2) ----> Line 162 in /usr/lib/python3.5/broadlink/__init__.py, function encrypt_pyaes
2017-09-13 21:01:49.960 (BroadlinkRM2) Calling message handler 'onHeartbeat'.
Please help!
2017-09-13 21:08:51.625 (BroadlinkRM2) Initialized version 3.0.0, author 'zak45'
2017-09-13 21:08:51.629 (BroadlinkRM2) Debug log level set to: 'true'.
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Mode1':'b4430de436fe'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Mode2':'/home/pi/domoticz/plugins/BroadlinkRM2'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Port':'0'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Name':'BroadlinkRM2'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'HardwareID':'17'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Mode4':'yes'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Address':'192.168.0.39'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Key':'BroadlinkRM2'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Author':'zak45'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Mode3':'yes'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Mode5':'9000'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Mode6':'Debug'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'Version':'3.0.0'
2017-09-13 21:08:51.629 (BroadlinkRM2) 'HomeFolder':'/home/pi/domoticz/plugins/BroadlinkRM2/'
2017-09-13 21:08:51.629 (BroadlinkRM2) Device count: 4
2017-09-13 21:08:51.629 (BroadlinkRM2) Device: 1 - ID: 252, Name: 'BroadlinkRM2 - Discover', nValue: 0, sValue: 'Off'
2017-09-13 21:08:51.629 (BroadlinkRM2) Device ID: '252'
2017-09-13 21:08:51.629 (BroadlinkRM2) Device Name: 'BroadlinkRM2 - Discover'
2017-09-13 21:08:51.629 (BroadlinkRM2) Device nValue: 0
2017-09-13 21:08:51.629 (BroadlinkRM2) Device sValue: 'Off'
2017-09-13 21:08:51.629 (BroadlinkRM2) Device LastLevel: 0
2017-09-13 21:08:51.629 (BroadlinkRM2) Device: 2 - ID: 253, Name: 'BroadlinkRM2 - Temp', nValue: 0, sValue: ''
2017-09-13 21:08:51.629 (BroadlinkRM2) Device ID: '253'
2017-09-13 21:08:51.629 (BroadlinkRM2) Device Name: 'BroadlinkRM2 - Temp'
2017-09-13 21:08:51.629 (BroadlinkRM2) Device sValue: ''
2017-09-13 21:08:51.630 (BroadlinkRM2) Device: 254 - ID: 254, Name: 'BroadlinkRM2 - Remote', nValue: 0, sValue: ''
2017-09-13 21:08:51.630 (BroadlinkRM2) Device ID: '254'
2017-09-13 21:08:51.630 (BroadlinkRM2) Device Name: 'BroadlinkRM2 - Remote'
2017-09-13 21:08:51.630 (BroadlinkRM2) Device nValue: 0
2017-09-13 21:08:51.630 (BroadlinkRM2) Device sValue: ''
2017-09-13 21:08:51.630 (BroadlinkRM2) Device LastLevel: 0
2017-09-13 21:08:51.630 (BroadlinkRM2) Device: 255 - ID: 259, Name: 'BroadlinkRM2 - Import', nValue: 0, sValue: 'Off'
2017-09-13 21:08:51.630 (BroadlinkRM2) Device ID: '259'
2017-09-13 21:08:51.630 (BroadlinkRM2) Device Name: 'BroadlinkRM2 - Import'
2017-09-13 21:08:51.630 (BroadlinkRM2) Device sValue: 'Off'
2017-09-13 21:08:51.630 (BroadlinkRM2) Connecting to: 192.168.0.39:b4430de436fe
2017-09-13 21:08:51.636 Error: (BroadlinkRM2) Error Connecting to Broadlink device....
2017-09-13 21:08:51.636 (BroadlinkRM2) Device Number begin to : 2
2017-09-13 21:08:51.640 (BroadlinkRM2) No ini file :/home/pi/domoticz/plugins/BroadlinkRM2/remote/plugin_remote_17.ini
2017-09-13 21:08:51.640 (BroadlinkRM2) Custom Commands for Remote not managed
2017-09-13 21:08:51.640 (BroadlinkRM2) Heartbeat interval set to: 30.
2017-09-13 21:09:02.756 (BroadlinkRM2) Calling message handler 'onHeartbeat'.
- Domoticz version: 4.10693
Dear forum,
I am trying to install Broadlink Rm3, but something going wrong.
I understand that there are a lot of variables in installing Broadlink, and it will be hard for you to help me. But I will try to explain.
System:
Raspberry Pi 2
Domoticz V3.8394 (c)2012-2017 GizMoCuz
Build Hash: e9d01f6, Date: 2017-09-13 09:54:08
Linux raspberrypi 4.9.24-v7+
GNU bash, version 4.3.30(1)-release
Problem
When I do ./updatebeta, I can see a lot off paths of Domoticz.
But Domoticz doesn't see folder $ ~domoticz/plugins/BroadlinkRM2. As result - no any "Broadlink" in Hardware.
It is looks like:
But I put all files (as described in wiki) in folder:
I think that the problem somewhere in Python.
I didn't see any 3.5 version here. Maybe problems here?
I did many times:
Installing Crypto
Installing Broadlink
Installing pyaes
I don't know correct this or not:
Restart Domoticz
Ooook. Lets install libpython3.x.
But latest version already installed...
even like this:
Restart Raspberry and Domoticz...
Problems still here (after reboot):
Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
And no "BroadlinkRM2" in Hardware.
Can you help me?
System:
Raspberry Pi 2
Problem
It is looks like:
plugins/
plugins/examples/
plugins/examples/DenonMarantz.py
plugins/examples/BaseTemplate.py
plugins/examples/HTTP Listener.py
plugins/examples/Kodi.py
plugins/examples/HTTP.py
plugins/examples/UDP Discovery.py
plugins/examples/Dlink DSP-W215.py
plugins/examples/RAVEn.py
plugins/AwoxSMP/
plugins/AwoxSMP/lib/
plugins/AwoxSMP/lib/__init__.py
plugins/AwoxSMP/lib/pySmartPlugSmpB16.py
plugins/AwoxSMP/plugin.py
Restarting Domoticz... (please standby...)
pi@raspberrypi ~/domoticz/plugins $ ls -al
итого 20
drwxr-xr-x 5 pi pi 4096 сен 9 09:26 .
drwxr-xr-x 7 pi pi 4096 сен 14 16:20 ..
drwxr-xr-x 3 pi pi 4096 сен 9 09:26 AwoxSMP
drwxr-xr-x 2 pi pi 4096 сен 14 09:00 BroadlinkRM2
drwxr-xr-x 2 pi pi 4096 сен 9 09:26 examples
pi@raspberrypi ~/domoticz/plugins/BroadlinkRM2 $ ls -al
итого 56
drwxr-xr-x 2 pi pi 4096 сен 14 09:00 .
drwxr-xr-x 5 pi pi 4096 сен 9 09:26 ..
-rwxr-xr-x 1 pi pi 11504 сен 14 13:14 plugin_http.py
-rwxr-xr-x 1 pi pi 81 сен 13 11:11 plugin_http.sh
-rwxr-xr-x 1 pi pi 26803 сен 12 22:08 plugin.py
-rwxr-xr-x 1 pi pi 1501 сен 12 22:08 plugin_send.py
pi@raspberrypi ~ $ python -V
Python 2.7.9
pi@raspberrypi ~ $ python3 -V
Python 3.5.4
pi@raspberrypi ~ $ which python
/usr/bin/python
pi@raspberrypi ~ $ which python3
/usr/local/bin/python3
pi@raspberrypi ~ $ which python3.4
/usr/bin/python3.4
pi@raspberrypi ~ $ which python3.5
/usr/local/bin/python3.5
pi@raspberrypi ~ $ pip3 -V
pip 9.0.1 from /usr/local/lib/python3.5/site-packages (python 3.5)
lrwxrwxrwx 1 root root 9 сен 12 23:16 python -> python2.7
lrwxrwxrwx 1 root root 9 мар 28 2015 python2 -> python2.7
-rwxr-xr-x 1 root root 3201580 сен 18 2016 python2.7
lrwxrwxrwx 1 root root 36 сен 18 2016 python2.7-config -> arm-linux-gnueabihf-python2.7-config
lrwxrwxrwx 1 root root 16 мар 28 2015 python2-config -> python2.7-config
lrwxrwxrwx 1 root root 9 дек 6 2014 python3 -> python3.4
-rwxr-xr-x 2 root root 3816928 окт 19 2014 python3.4
lrwxrwxrwx 1 root root 36 окт 19 2014 python3.4-config -> arm-linux-gnueabihf-python3.4-config
-rwxr-xr-x 2 root root 3816928 окт 19 2014 python3.4m
lrwxrwxrwx 1 root root 37 окт 19 2014 python3.4m-config -> arm-linux-gnueabihf-python3.4m-config
lrwxrwxrwx 1 root root 16 дек 6 2014 python3-config -> python3.4-config
lrwxrwxrwx 1 root root 10 дек 6 2014 python3m -> python3.4m
lrwxrwxrwx 1 root root 17 дек 6 2014 python3m-config -> python3.4m-config
lrwxrwxrwx 1 root root 16 мар 28 2015 python-config -> python2.7-config
cd Python-3.5.4
./configure --enable-shared
make
sudo make install
pi@raspberrypi ~ $ sudo pip3 install Crypto
Requirement already satisfied: Crypto in /usr/local/lib/python3.5/site-packages
Requirement already satisfied: Naked in /usr/local/lib/python3.5/site-packages (from Crypto)
Requirement already satisfied: shellescape in /usr/local/lib/python3.5/site-packages (from Crypto)
Requirement already satisfied: requests in /usr/local/lib/python3.5/site-packages (from Naked->Crypto)
Requirement already satisfied: pyyaml in /usr/local/lib/python3.5/site-packages (from Naked->Crypto)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.5/site-packages (from requests->Naked->Crypto)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.5/site-packages (from requests->Naked->Crypto)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in /usr/local/lib/python3.5/site-packages (from requests->Naked->Crypto)
Requirement already satisfied: idna<2.7,>=2.5 in /usr/local/lib/python3.5/site-packages (from requests->Naked->Crypto)
pi@raspberrypi ~ $ sudo pip3 install broadlink
Requirement already satisfied: broadlink in /usr/local/lib/python3.5/site-packages/broadlink-0.5-py3.5.egg
Requirement already satisfied: pyaes==1.6.0 in /usr/local/lib/python3.5/site-packages (from broadlink)
pi@raspberrypi ~ $ sudo pip3 install pyaes
Requirement already satisfied: pyaes in /usr/local/lib/python3.5/site-packages
pi@raspberrypi $ sudo cp -r /usr/local/lib/python3.5/site-packages/crypto /usr/lib/python3.5/
pi@raspberrypi $ sudo cp -r /usr/local/lib/python3.5/site-packages/broadlink /usr/lib/python3.5/
EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
pi@raspberrypi ~ $ sudo apt-get install python3-dev
Чтение списков пакетов… Готово
Построение дерева зависимостей
Чтение информации о состоянии… Готово
Уже установлена самая новая версия python3-dev.
обновлено 0, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 9 пакетов не обновлено.
pi@raspberrypi ~ $ sudo apt-get install libpython3.4
Уже установлена самая новая версия libpython3.4.
pi@raspberrypi ~/domoticz $ dpkg -l | grep libpython3.4
ii libpython3.4:armhf 3.4.2-1 armhf Shared Python runtime library (version 3.4)
ii libpython3.4-dev:armhf 3.4.2-1 armhf Header files and a static library for Python (v3.4)
ii libpython3.4-minimal:armhf 3.4.2-1 armhf Minimal subset of the Python language (version 3.4)
ii libpython3.4-stdlib:armhf 3.4.2-1 armhf Interactive high-level object-oriented language (standard library, version 3.4)
Can you help me?
You are right. Thank you. I can see "BroadlinkRM2 with Kodi Remote" in hardware on stable version.
Now I need to restore all my scripts... i deleted it during downgrade....))))
And i get new errors:
As I thought - problems with Python.
What should I do?
2017-09-14 20:36:00.592 Error: BroadlinkRM3 hardware (5) thread seems to have ended unexpectedly
2017-09-14 20:36:02.799 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/BroadlinkRM2/:/usr/local/lib/python35.zip:/usr/local/lib/python3.5:/usr/local/lib/python3.5/plat-linux:/usr/local/lib/python3.5/lib-dynload'.
2017-09-14 20:36:02.799 Error: (BroadlinkRM3) Module Import failed, exception: 'ImportError'
2017-09-14 20:36:02.799 Error: (BroadlinkRM3) Module Import failed: ' Name: broadlink'
What should I do?
- Domoticz version: 3.8153
Hello, I´ve installed broadlink plugin, with some one button switch, but when I send command ON, device is going to on, but in domoticz stay OFF status.
Domoticz on RPI PI3
RFXCOM, BROADLINK RM PRO, Z-WAVE stick gen5, XIAOMI GATEWAY, HARMONY HUB
Hi, Broadlink plugin is one way communication only. No status came back from devices. if you want to set the push button to some other value just change settings on it.x15pa3ck15x wrote: ↑Friday 15 September 2017 2:27 Hello, I´ve installed broadlink plugin, with some one button switch, but when I send command ON, device is going to on, but in domoticz stay OFF status.
