No it's also on my todo list at this moment..HansieNL wrote: Wednesday 06 September 2017 19:45 Using IOS version 1.01, but can't set the color of my Hue lights?
Domoticz App
- galadril
- Domoticz version: latest
Re: Domoticz App
- galadril
Re: Domoticz App
Thanks for the feedback. Point 1 is already fixed (next release)Domoticzfun wrote: Wednesday 06 September 2017 19:33 Sorry if part of my remarks are already said in this thread, I haven't red all 278 posts. I installed the latest version from the app store and I wanted to give you a heads up, you did a wonderful job, thanks!
I used it for now only in my local network and with username/password validation. This is what I found out while using the app for an hour or so:
- App crashes in the setup when setting no or wrong port. After filling with the correct info and using http instead of https with untrusted certificate (uuuh...) it works fine. An helpfull error message is appreciated.
- Temperature decimals is presented with decimal point and at other places (dauwpunt) with comma seperator. One used format is preferred, in my case a comma seperator would be great.
One can discuss the chosen number of decimals. Only very expensive and precise calibrated thermometers are worth showing 2 or maybe 1 decimal.
- Humidity is only shown with a name e.g. "wet" and not the percentage.
- Last seen times in days and hours, hours and minutes, seconds and milliseconds ago. Can I choose for showing me "Last seen time and date" instead? (wishlist)
- Gas meter shows only total for today, not grand total on meter (the raw value is recieved from P1 Smart meter USB). Electricity does show actual, today an total use. The Android app doesn't do this too but this is on my wishlist.
Best regards,
- The Dashboard seems not to be sorted like the webpage, where you can order the icons like you wish. Is this possible?
Domoticzfun
Ill see about the other ones
- gielie
- Domoticz version: latest β
Re: Domoticz App
Is it possible to send notifications to different iPhones and not all messages to all phones, some i want to go to my phone, some to my wife, and some needs to go to all phones.
When this is possible i will buy the app, do i need to buy it per phone or can i buy it and use it on all phones (family sharing)
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
thastealth
- Target OS: -
Re: Domoticz App
I have a smart meter which is connected to the RPi running domoticz (USB->RJ45 cable)
I encountered the following bugs:
- The Gas and Energy usage items are not shown in the "other" tab (none of the items are shown there)
- I have them as favourites so they show up on the first page, but ticking them only shows the "Favorite" and "Abort options, no way to view the chart (also marking them as favourite on a when they are already favourite is a bit redundant)
- The Dutch translation on the chart "Legende" is incorrect, it should be "Legenda"
- The chart is not working (empty, no data)
Let me know if you need additional info,
- galadril
Re: Domoticz App
No thats not yet possible.. the app supports it, but it should be implemented in Domoticz base system..gielie wrote: Thursday 07 September 2017 12:12 Is it possible to send notifications to different iPhones and not all messages to all phones, some i want to go to my phone, some to my wife, and some needs to go to all phones.
- galadril
Re: Domoticz App
Can you pm me a viewonly-account on your system so I can debug against your devices?
- galadril
Re: Domoticz App
PS, if you like the app... please support us with a review in the apple store
thastealth
- Target OS: -
Re: Domoticz App
How can I create a readonly account? Can't seem to find a guide on the internetgaladril wrote: Friday 08 September 2017 8:55Can you pm me a viewonly-account on your system so I can debug against your devices?
- galadril
Re: Domoticz App
Under settings, account settings, you create a new account, with view rights.
Then i need the full connection settings (server url/port, plus credentials for the new account on your system)
Gerwin
Re: Domoticz App
I have bought the premium but i don't have the premium
Can someone tell me what to do
Gerwin
Gerwin
- G3rard
- Target OS: -
- Domoticz version: No
Re: Domoticz App
I have installed v0.034 but still the same issues. The 'Foutopsporing' in the app shows
The CancellationTokenSource has been disposed.After that I also can't switch a light on/off. Then the log shows
Object reference not set to an instance of an object.
Also tested this with app v0.0.34 against my Domoticz test system v3.8355 and that gives the same errors.
Any ideas?
Not using Domoticz anymore
anasazi
Re: Domoticz App
Can I come up with a suggestion?
See the attached image...
Here I have reduced the dead white space between the thermostats and this should be for all the groups (switches, temperature).
I have also re-arranged the thermostat controls to the bottom, this way the name and last seen won't get truncated.
In Domoticz, thermostat setpoints and electric usage is found under Utility and in the app they are found under "Mätare" (swedish)
What do you think of creating one group with the name Thermostats or Setpoints for all my thermostats and one group named Energy for all my energy sensors?
- thermostats.png (195.81 KiB) Viewed 4116 times
thastealth
- Target OS: -
Re: Domoticz App
Alright. found it, configured it and tested it again.galadril wrote: Friday 08 September 2017 14:37 Under settings, account settings, you create a new account, with view rights.
The issue I had was that I had no security enabled so I couldn't add a view only user (server is only available within the home network, or over VPN). After enabling everything and testing the credentials + external IP in the app the following issues were resolved:
Reverting to the "old" settings kept it working for some reason... Could perhaps have something to do with the changing of server settings?
Also, I noticed the following (new) issues:
- For changing the Server Connection settings you'll have to press the "Ok" button, would be more logical to change the button text to "Edit" or something
- When changing the server settings (and having the viewer only account stuff enabled) the app also indicates the version of the Domoticz server, when I use the "open" configuration it only shows "Ok"
- Sometimes during usage the app indicates it has lost internet connection, the message is shown over the navigation tab bar on the bottom (really annoying since you can't use the app anymore)
I think it is better if you setup a public issue tracker (there are a lot of free ones available). I can help you if you require that. Makes issues more easyier to track than over this forum
marcotrumpet
Domoticz App
I have “error: not connected to network”.. ideas?
It work for seconds and then none.. also I can’t see my cameras
Inviato dal mio iPhone utilizzando Tapatalk
scheelings
Re: Domoticz App
Great app!
I do have a problem with the premium version though.
I bought the premium version but the app does not recognize it. When I click buy again, the App Store informs me that I already have bought this premium version. When I click restore I get the message: "could not restore your premium account".
Below the log:
Could not restore your premium account.
GCM: error occured: Error Domain=com.google.fcm Code=2001 "FIRMessaging is already connected" UserInfo={NSLocalizedFailureReason=FIRMessaging is already connected}
GCM: error occured: Error Domain=com.google.fcm Code=2001 "FIRMessaging is already connected" UserInfo={NSLocalizedFailureReason=FIRMessaging is already connected} Could not restore your premium account.
Can you please help me?
Thx,
Danny
Great app!
Below the log:
Thx,
Danny
Markman006
- Target OS: -
Re: Domoticz App
Ik heb de premium app gekocht maar niks ontvangen..
bing69
Re: Domoticz App
Where van i find the GEOFENCING function?
- gielie
Re: Domoticz App
You're not gonna find it, it's not in there (yet I believe)
When it is I'm gonna buy the premium version.
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
drtrimble
Re: Domoticz App
kan iemand me vertellen hoe de premium werkende te krijgen? ik heb al betaald
