I was wondering how I could edit the wiki in order to fix some incorrect stuff in it, add some of my script to the dedicated area, and help maintaining it.
I asked on the Domoticz IRC channel and they told me the Domoticz forum and wiki account used to be linked but that doesn't seem to be the case anymore sadly.
There is also no option to create an account on the wiki, for security reasons I assume.
Hi, yes of course, it's the first thing I tried I tried again just now and I still get an error message :
"There is no user by the name "loitho". Check your spelling."
So I assume that there isn't any account that has been created on the wiki, or there is a problem with the sharing
Permission error
You do not have permission to create this user account, for the following reason:
The action you have requested is limited to users in the group: Administrators.
So i'm guessing you are not allowed to edit the wiki.
Which makes it not really a wiki..... But thats another discussion
I had a problem logging in to the wiki as well. It had something to do with special characters in my username or password, I don't remember. One of the admins fixed it for me.
jannl wrote: Monday 04 September 2017 7:31
Is there an admin available to look at this issue?
Would be a shame if the Wiki went out of date, not because nobody was willing to edit it but because of an login issue.
loitho wrote: Monday 04 September 2017 20:51
I too have an incorrect IP on the Wiki.
Verstuurd vanaf mijn SM-G930F met Tapatalk
You mean one of the Forum Administrator ?
Yes, one of the forum admins
hm, looks like the forum password is not equal to the wiki password. I just resetted my password and now I can login again.
Ican't modify the Wiki either. I have done that before without any problem.
Something has happened quite recently!
Edit:
It seems like you must have a Mediawiki account to be able modify the Wiki. I have never logged in before, but still been able to modify the Wiki. Now I had to re-activate my Mediawiki account and login. Then it works! It looks like someone has changed the overall protection of the Wiki.
Hey ! just an update about the wiki, Gizmocuz answered my MP and said
Yes this is correct. I updated the forum, and now the login system is not working anymore for the wiki
It is a special module that used the forums username/password for end users in the wiki
I will have a look at this ASAP [...]
It looks like the issue is still present: When I try to connect to the Wiki (using my forum's credentials), I get:
A database query error has occurred. This may indicate a bug in the software.[WlpIULkbjsYAAFXDZZ4AAAA8] 2018-01-13 17:56:33: Fatal exception of type "Wikimedia\Rdbms\DBQueryError"
Database error
A database query error has occurred. This may indicate a bug in the software.[Wl3HWrkbjsYAAHCcODMAAAAc] 2018-01-16 09:35:23: Fatal exception of type "Wikimedia\Rdbms\DBQueryError"
Raspberry Pi 4 2GB (RPi OS Light)
RFXCOM RFXtrx433E, firmware version = 1025
I am using Nginx as reverse proxy with a SSL connection and use Fail2Ban to monitor the Nginx logs and ban any connection after 2 failed tries. This way you run pretty secure.
