How to get an account to modify the wiki ?
loitho
Post by loitho »
Hello !
I was wondering how I could edit the wiki in order to fix some incorrect stuff in it, add some of my script to the dedicated area, and help maintaining it.
I asked on the Domoticz IRC channel and they told me the Domoticz forum and wiki account used to be linked but that doesn't seem to be the case anymore sadly.
There is also no option to create an account on the wiki, for security reasons I assume.
So here I am :)
Thanks !
Egregius
Domoticz version: v2024.7
Re: How to get an account to modify the wiki ?
Post by Egregius »
Have you tried logging in with your account from the forum?
loitho
Post by loitho »
Hi, yes of course, it's the first thing I tried :) I tried again just now and I still get an error message :
"There is no user by the name "loitho". Check your spelling."
So I assume that there isn't any account that has been created on the wiki, or there is a problem with the sharing
JelteV
Post by JelteV »
Normaly you would need to register At this URL.
http://www.domoticz.com/wiki/Special:UserLogin/signup
But....
there you get this :
Permission error
You do not have permission to create this user account, for the following reason:
The action you have requested is limited to users in the group: Administrators.
So i'm guessing you are not allowed to edit the wiki.
Which makes it not really a wiki..... But thats another discussion :)
loitho
Post by loitho »
Yup, saw that too, it's too bad
Is there anyone that I could contact to see about this problem ?
Egregius
Post by Egregius »
Strange,I can't remember that I did something special to login at the wiki. It used to be the same as the forum.
mischa
Domoticz version: 3.8872
Post by mischa »
I get a failure at login.
and the Ip-Address in the top right corner (the user page for the ip-address you are editing as) shows 141.101.104.xxx
but that is not my Ip-address!
Mischa
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
jannl
Domoticz version: 2022.2
Post by jannl »
I had a problem logging in to the wiki as well. It had something to do with special characters in my username or password, I don't remember. One of the admins fixed it for me.
Verstuurd vanaf mijn SM-G930F met Tapatalk
loitho
Post by loitho »
I too have an incorrect IP on the Wiki.
jannl wrote: Monday 04 September 2017 7:31 I had a problem logging in to the wiki as well. It had something to do with special characters in my username or password, I don't remember. One of the admins fixed it for me.
You mean one of the Forum Administrator ?
JelteV
Post by JelteV »
Is there an admin available to look at this issue?
Would be a shame if the Wiki went out of date, not because nobody was willing to edit it but because of an login issue.
jannl
Post by jannl »
loitho wrote: Monday 04 September 2017 20:51 I too have an incorrect IP on the Wiki.
Yes, one of the forum admins
hm, looks like the forum password is not equal to the wiki password. I just resetted my password and now I can login again.
JelteV
Post by JelteV »
Did anybody found fix for this yet?
I'm still not able to login (with my forum account) on the Wiki.
jannl
Post by jannl »
Did you try to reset your password via the wiki?
ubee
Domoticz version: 2021.1
Post by ubee »
Ican't modify the Wiki either. I have done that before without any problem.
Something has happened quite recently!
Edit:
It seems like you must have a Mediawiki account to be able modify the Wiki. I have never logged in before, but still been able to modify the Wiki. Now I had to re-activate my Mediawiki account and login. Then it works! It looks like someone has changed the overall protection of the Wiki.
loitho
Post by loitho »
jannl wrote: Friday 08 September 2017 7:08 Did you try to reset your password via the wiki?
I can't because the wiki doesn't recognize my account :(
I've had a Mediawiki account for a long time, and the Domoticz Wiki doesn't seem to be linked to the mediawiki user database.
It's really weird.
I sent a message to gizmocuz, but he hasn't seen it yet.
loitho
Post by loitho »
Hey ! just an update about the wiki, Gizmocuz answered my MP and said
Yes this is correct. I updated the forum, and now the login system is not working anymore for the wiki
It is a special module that used the forums username/password for end users in the wiki
I will have a look at this ASAP [...]
So, awesome ! The issue is now known :)
JelteV
Post by JelteV »
Any update yet?
CDuv
Post by CDuv »
It looks like the issue is still present: When I try to connect to the Wiki (using my forum's credentials), I get:
A database query error has occurred. This may indicate a bug in the software.[WlpIULkbjsYAAFXDZZ4AAAA8] 2018-01-13 17:56:33: Fatal exception of type "Wikimedia\Rdbms\DBQueryError"
Bernd
Domoticz version: 2023.1
Post by Bernd »
Still not solved:
Database error
A database query error has occurred. This may indicate a bug in the software.[Wl3HWrkbjsYAAHCcODMAAAAc] 2018-01-16 09:35:23: Fatal exception of type "Wikimedia\Rdbms\DBQueryError"
Raspberry Pi 4 2GB (RPi OS Light)
RFXCOM RFXtrx433E, firmware version = 1025
Cosmo88
Post by Cosmo88 »
I am using Nginx as reverse proxy with a SSL connection and use Fail2Ban to monitor the Nginx logs and ban any connection after 2 failed tries. This way you run pretty secure.
บาคาร่าบนมือถือ
