Dear EdKo66, Yes there's a title tag with a small explanations but probably not showing? ( I will do a small update to make the question marks more clearly and make message when it is successfully saved ) You can add a device by adding it withIsn't there supposed to be a help text when you click on the '?' in the config?
How do you add devices? I tried with several of mine, but those didn't work
Make a notice when you save the settings. Now we don't have a way of knowing if saving did work or not.
"Device=3" where the number indicates de idx number of the device.
** ADDED YOUR REQUESTED IDEAS IN LATEST UPDATE
