Could you please enable debug and investigate the logs ? On my side I'll try to replicate on my development system when I find the time
Python plugin: Air quality monitoring (for France only)
- papoo
- Domoticz version: 4.10
Re: Python plugin: Air quality monitoring (for France only)
i enable debug mode but nothing appears in the logs, domoticz run only 10 seconds before crash
- Domoticz version: Stable
Hi Papoo,
I was browsing through the changes made in the last beta versions, i noticed something about Python 3.6.
On my system i only have Python 3.5 installed. I will install 3.6 this evening to see if that is the problem.
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
Thanks. I saw your post in the topic viewtopic.php?f=6&t=19065#p147589... so it is not only this plugin that is affected... I'll try to understand but currently away from my development system... please bear with me (or other plugin developers) on this
- Domoticz version: v4.11307
I've just installed your plugin and it's working fine for now !
Thank you.
Thank you.
- xhark
- Domoticz version: 2023.1
Thank you for this plugin, but can't work on my domoticz (with debug enabled):
No icon in "Utility" tab too.
Any idea ?
thank you !
2018-09-12 16:52:27.650 Status: (PrevAir) Started.
2018-09-12 16:52:30.814 Status: (PrevAir) Initialized version 0.0.3, author 'logread'
2018-09-12 16:52:30.816 Status: (PrevAir) Entering work loop.
2018-09-12 16:52:30.879 (PrevAir) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2018-09-12 16:52:30.881 (PrevAir) 'Port':'0'
2018-09-12 16:52:30.882 (PrevAir) 'Key':'PrevAir'
2018-09-12 16:52:30.884 (PrevAir) 'DomoticzVersion':'4.9700'
2018-09-12 16:52:30.886 (PrevAir) 'Mode2':'1'
2018-09-12 16:52:30.888 (PrevAir) 'Mode1':'15043'
2018-09-12 16:52:30.890 (PrevAir) 'Mode6':'Debug'
2018-09-12 16:52:30.892 (PrevAir) 'DomoticzHash':'a3a45906'
2018-09-12 16:52:30.894 (PrevAir) 'HardwareID':'13'
2018-09-12 16:52:30.896 (PrevAir) 'DomoticzBuildTime':'2018-06-23 16:24:51'
2018-09-12 16:52:30.897 (PrevAir) 'Name':'PrevAir'
2018-09-12 16:52:30.899 (PrevAir) 'HomeFolder':'/home/pi/domoticz/plugins/PrevAir/'
2018-09-12 16:52:30.901 (PrevAir) 'Author':'logread'
2018-09-12 16:52:30.903 (PrevAir) 'Version':'0.0.3'
2018-09-12 16:52:30.904 (PrevAir) Device count: 0
2018-09-12 16:52:30.906 (PrevAir) Number of icons loaded = 3
2018-09-12 16:52:30.908 (PrevAir) Icon 101 prevairorange
2018-09-12 16:52:30.910 (PrevAir) Icon 102 prevairred
2018-09-12 16:52:30.912 (PrevAir) Icon 103 prevairgreen
2018-09-12 16:52:30.914 (PrevAir) Using polling interval of 1 hour(s)
2018-09-12 16:52:31.404 (PrevAir) using station 15043/38185 GRENOBLE - Grenoble Les Frenes at 0km
2018-09-12 16:52:31.407 (PrevAir) Creating device 'PrevAir Station'.
2018-09-12 16:52:31.409 Error: (PrevAir) Failed to update device unit 99
Any idea ?
thank you !
FR blogger & sysAdmin
- Domoticz version: 4.9700
Hello
The plugin is working for me but:
- it didn't find the position itself, I had to enter myself.
- since I have more than 99 deivces, I modified the 99 in the Python plugin by 150.
- I had to validate the add of new devices in parameters.
Tx
Antoine
Tx
Antoine
- xhark
It works.
I had to enable "allow new devices" in settings (I forget it was disabled!). And change 99 to 150 (maybe it works without this modification!)
thank you for your help Antoine!
Users browsing this forum: assp22 and 1 guest
