I love you alreadyG3rard wrote: Monday 21 August 2017 23:58 I have made some updates to the Buienradar script of @ffes.
Added the following devices (data from xml.buienradar.nl):
* Visibility
* Solar radiation
* Rain rate
* Weather forecast
* Rain forecast (uses data from https://gps.buienradar.nl/getrr.php?lat=51&lon=3)
Check this Dutch site for more information on the rain forecast.
I have made a pull request for this and hopefully it will be merged
Buienradar Weather Lookup Plugin
schulpr
Re: Buienradar Weather Lookup Plugin
Ewaldharmsen
awesome!
- Brutus
Nice !
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
rickvanakkeren
How can I install this plugin?
- jvdz
- Domoticz version: 4.107
Which part of the elaborate explanation in Github isn't working for you? https://github.com/ffes/domoticz-buienr ... -and-setup
You of course need to take the version of @G3rard at this moment untill that gets merged into the original: https://github.com/gerard33/domoticz-buienradar
Hope that helps.
Jos
Hope that helps.
Jos
rron
Is there an issue with the latest beta release 8373? I can't find buienradar in the hardware list.
What have I done:
sudo apt-get update
sudo apt-get upgrade
sudo apt install python3.4
sudo apt install libpython3.4
sudo apt install python3-dev
After that I have rebooted domoticz.sh
There's buienradar-domoticz in the plugin dir and when I run the localtest.py it's working.
Did I forgot something?
What have I done:
sudo apt-get update
- G3rard
- Target OS: -
- Domoticz version: No
In the latest Domoticz beta versions the Python plugin has been disabled.
You can use the last stable version if you want to use plugins.
Not using Domoticz anymore
rron
Ok thanks. I try to revert to the latest stable version.
Is there a special reason for this?
rron
I went back to the stable version 8153 and buienradar is now in the hardwarelist
The only thing now is that the script is not working.
In the logging I see only: 2017-09-03 17:55:02.809 (Buienradar) Initialized version 1.1.0, author 'ffes'
No further remarks.
It works!
No further remarks.
It works!
rickvanakkeren
I'm also using the stable version of Domoticz. I can see the buienradar plugin in the hardware list, but no devices are created. In the log I see
Can someone help me?
2017-09-08 18:36:49.715 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/local/lib/python35.zip:/usr/local/lib/python3.5/:/usr/local/lib/python3.5/plat-linux:/usr/local/lib/python3.5/lib-dynload'.
2017-09-08 18:36:49.715 Error: (Buienradar) Module Import failed, exception: 'SyntaxError'
2017-09-08 18:36:49.716 Error: (Buienradar) Import detail: File: /home/pi/domoticz/plugins/domoticz-buienradar/rainforecast.py, Line: 1734047936, offset: 92
2017-09-08 18:36:49.716 Error: (Buienradar) Error Line ' Domoticz.Log("No data found from Buienradar containing rain forecast, assuming rain forecast is 0)
- G3rard
- Target OS: -
Yep, I see you are using my updated version from https://github.com/gerard33/domoticz-buienradar.rickvanakkeren wrote: Friday 08 September 2017 18:40 I'm also using the stable version of Domoticz. I can see the buienradar plugin in the hardware list, but no devices are created. In the log I see
Can someone help me?Code: Select all
2017-09-08 18:36:49.715 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/local/lib/python35.zip:/usr/local/lib/python3.5/:/usr/local/lib/python3.5/plat-linux:/usr/local/lib/python3.5/lib-dynload'. 2017-09-08 18:36:49.715 Error: (Buienradar) Module Import failed, exception: 'SyntaxError' 2017-09-08 18:36:49.716 Error: (Buienradar) Import detail: File: /home/pi/domoticz/plugins/domoticz-buienradar/rainforecast.py, Line: 1734047936, offset: 92 2017-09-08 18:36:49.716 Error: (Buienradar) Error Line ' Domoticz.Log("No data found from Buienradar containing rain forecast, assuming rain forecast is 0)
I missed a " in line 92 of rainforecast.py. Just updated this on Github.
If you use the latest version of rainforecast.py from Github it should work.
rickvanakkeren
Thanks for your quick reply. I updated the python-file, and for 90% it works. But I'm now getting another error:
Can you see what's going wrong here?
HTTP error in rain predictor: URL: https://gps.buienradar.nl/getrr.php?lat=52.01&lon=4.32Thanks
rickvanakkeren
This is by the way the whole log
So it seems that "another Buienradar URL" works.
2017-09-09 13:41:31.719 (Buienradar) Retrieve weather data from http://xml.buienradar.nl/
2017-09-09 13:41:31.830 (Buienradar) Temperature: 13.0
2017-09-09 13:41:31.831 (Buienradar) Wind Speed: 5.5 | Wind Bearing: 266.0 | Wind Direction: W | Wind Speed Gusts: 9.7 | Wind Chill: 13.0
2017-09-09 13:41:31.831 (Buienradar) Barometer: 996.56 | Barometer Forecast: 2
2017-09-09 13:41:31.831 (Buienradar) Humidity: 87 | Humidity status: 3
2017-09-09 13:41:31.831 (Buienradar) Visibility: 3120
2017-09-09 13:41:31.831 (Buienradar) Solar Irradiance: 8.0
2017-09-09 13:41:31.831 (Buienradar) Rain rate: 23.7
2017-09-09 13:41:31.832 (Buienradar) Weather prediction today: Beter weer vanuit het westen! Maar voor hoelang? (Opgesteld op zaterdag 9 sep 2017 om 12:30)
2017-09-09 13:41:31.833 (Buienradar) Rain forecast started with following coordinates from Domoticz: 52.007062;4.322434
2017-09-09 13:41:31.833 (Buienradar) Rain forecast url: https://gps.buienradar.nl/getrr.php?lat=52.01&lon=4.32
2017-09-09 13:41:31.834 Error: (Buienradar) HTTP error in rain predictor: URL: https://gps.buienradar.nl/getrr.php?lat=52.01&lon=4.32
2017-09-09 13:41:31.834 (Buienradar) Going to try another Buienradar URL
2017-09-09 13:41:31.928 (Buienradar) Timeframe: 30, rows: 7
2017-09-09 13:41:31.928 (Buienradar) 000|13:45
2017-09-09 13:41:31.928 (Buienradar) 000|13:50
2017-09-09 13:41:31.928 (Buienradar) 000|13:55
2017-09-09 13:41:31.928 (Buienradar) 000|14:00
2017-09-09 13:41:31.929 (Buienradar) 000|14:05
2017-09-09 13:41:31.929 (Buienradar) 000|14:10
2017-09-09 13:41:31.929 (Buienradar) 000|14:15
2017-09-09 13:41:31.929 (Buienradar) Rain forecast: 0 [0-255] | 0.0 mm/hour
- G3rard
- Target OS: -
Yep that is by design. Sometimes the url is not reachable, so I have added a second URL which will be checked if the first one fails. So this error should only be there occasionally.
- EdwinK
- Domoticz version: BETA
I've got some other errors now
Just did a git clone earlier today.2017-09-09 15:50:16.864 Error: (Buienradar) 'onHeartbeat' failed 'NameError':'name 'br' is not defined'.
2017-09-09 15:50:16.864 Error: (Buienradar) ----> Line 143 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:16.864 Error: (Buienradar) ----> Line 130 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:27.064 Error: (Buienradar) 'onHeartbeat' failed 'NameError':'name 'br' is not defined'.
2017-09-09 15:50:27.064 Error: (Buienradar) ----> Line 143 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:27.064 Error: (Buienradar) ----> Line 130 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:37.264 Error: (Buienradar) 'onHeartbeat' failed 'NameError':'name 'br' is not defined'.
2017-09-09 15:50:37.264 Error: (Buienradar) ----> Line 143 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:37.264 Error: (Buienradar) ----> Line 130 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
HierBenIk
- Domoticz version: 4.9700
I just updated my Domoticz to the latest stable release.
After the update I installed the Buienradar Weather Lookup plugin.
Now I can see the new hardware in Domoticz but the hardware cannot be added.
Does sombody has any idea why the hardware cannot be added?
- EdwinK
I thought I saw a fix for this before but can't seem to find it anymore.
Running G3rard's version of the script.
Living near Rotterdam, that station is a bit further away.Found Meetstation Lauwersoog (ID: 6277) at 7.7 km from your home location
N
mrombout
- Domoticz version: v4.10415
Domoticz V3.8392 (c)2012-2017 GizMoCuz
Build Hash: 68538e3, Date: 2017-09-10 15:51:15
Well, I´d really like this plugin to start working... but, if I did I wouldn´t post this
Read the entire thread, installed all Python dependencies, restarted service etc. but also in my case I caný find the entry with Buienradar.
The python3 localtest.py works ok
XML file contains weather station information
No Barometer and Visibility info found in your weather station, getting info from weather station De Bilt
Temperature: 14.7
Wind Speed: 11.96 | Wind Bearing: 182.0 | Wind Direction: S | Wind Speed Gusts: 16.0 | Wind Chill: 14.7
Barometer: 994.51 | Barometer Forecast: 2
Humidity: 80 | Humidity status: 3
Visibility: 14800.0
Solar Irradiance: None
Rain rate: None
Weather prediction today: Winderige en natte nacht (Opgesteld op zondag 10 sep 2017 om 11:45)
I run the last beta of Domoticz.
Any tips?
Temperature: 14.7
Visibility: 14800.0
Rain rate: None
Any tips?
pvm
- Domoticz version: 4.10538
First of all: I really like the plugin, I've been using it on my raspberry pi domoticz install
An idea: Is it possible to include this plugin in domoticz itself (no need to get from seperate repository and related steps) ?
It would be easier to use and for more Domoticz users.
- G3rard
- Target OS: -
viewtopic.php?p=148953#p148953mrombout wrote:Domoticz V3.8392 (c)2012-2017 GizMoCuz
Any tips?
