Buienradar Weather Lookup Plugin
schulpr
Re: Buienradar Weather Lookup Plugin
Post by schulpr »
G3rard wrote: Monday 21 August 2017 23:58 I have made some updates to the Buienradar script of @ffes.
Added the following devices (data from xml.buienradar.nl):
* Visibility
* Solar radiation
* Rain rate
* Weather forecast
* Rain forecast (uses data from https://gps.buienradar.nl/getrr.php?lat=51&lon=3)
Check this Dutch site for more information on the rain forecast.
I have made a pull request for this and hopefully it will be merged :D
I love you already ;)
Ewaldharmsen
Post by Ewaldharmsen »
awesome!
Brutus
Post by Brutus »
Nice !
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
rickvanakkeren
Post by rickvanakkeren »
How can I install this plugin?
jvdz
Domoticz version: 4.107
Post by jvdz »
Which part of the elaborate explanation in Github isn't working for you? https://github.com/ffes/domoticz-buienr ... -and-setup
You of course need to take the version of @G3rard at this moment untill that gets merged into the original: https://github.com/gerard33/domoticz-buienradar
Hope that helps. ;)
Jos
rron
Post by rron »
Is there an issue with the latest beta release 8373? I can't find buienradar in the hardware list.
What have I done:
sudo apt-get update
sudo apt-get upgrade
sudo apt install python3.4
sudo apt install libpython3.4
sudo apt install python3-dev
After that I have rebooted domoticz.sh
There's buienradar-domoticz in the plugin dir and when I run the localtest.py it's working.
Did I forgot something? :?:
Rpi, RFXcom, klikaan klikuit switch,thermosmart, z-wave, espeasy, smartevse
G3rard
Domoticz version: No
Post by G3rard »
In the latest Domoticz beta versions the Python plugin has been disabled.
You can use the last stable version if you want to use plugins.
Not using Domoticz anymore
rron
Post by rron »
Ok thanks. I try to revert to the latest stable version.
Is there a special reason for this?
rron
Post by rron »
I went back to the stable version 8153 and buienradar is now in the hardwarelist :D
The only thing now is that the script is not working.
In the logging I see only: 2017-09-03 17:55:02.809 (Buienradar) Initialized version 1.1.0, author 'ffes'
No further remarks.
It works!
rickvanakkeren
I'm also using the stable version of Domoticz. I can see the buienradar plugin in the hardware list, but no devices are created. In the log I see
2017-09-08 18:36:49.715 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/local/lib/python35.zip:/usr/local/lib/python3.5/:/usr/local/lib/python3.5/plat-linux:/usr/local/lib/python3.5/lib-dynload'.
2017-09-08 18:36:49.715 Error: (Buienradar) Module Import failed, exception: 'SyntaxError'
2017-09-08 18:36:49.716 Error: (Buienradar) Import detail: File: /home/pi/domoticz/plugins/domoticz-buienradar/rainforecast.py, Line: 1734047936, offset: 92
2017-09-08 18:36:49.716 Error: (Buienradar) Error Line ' Domoticz.Log("No data found from Buienradar containing rain forecast, assuming rain forecast is 0)
Can someone help me?
G3rard
Post by G3rard »
rickvanakkeren wrote: Friday 08 September 2017 18:40 I'm also using the stable version of Domoticz. I can see the buienradar plugin in the hardware list, but no devices are created. In the log I see
Yep, I see you are using my updated version from https://github.com/gerard33/domoticz-buienradar.
I missed a " in line 92 of rainforecast.py. Just updated this on Github.
If you use the latest version of rainforecast.py from Github it should work.
rickvanakkeren
Thanks for your quick reply. I updated the python-file, and for 90% it works. But I'm now getting another error:
HTTP error in rain predictor: URL: https://gps.buienradar.nl/getrr.php?lat=52.01&lon=4.32
Can you see what's going wrong here?
rickvanakkeren
This is by the way the whole log
2017-09-09 13:41:31.719 (Buienradar) Retrieve weather data from http://xml.buienradar.nl/
2017-09-09 13:41:31.830 (Buienradar) Temperature: 13.0
2017-09-09 13:41:31.831 (Buienradar) Wind Speed: 5.5 | Wind Bearing: 266.0 | Wind Direction: W | Wind Speed Gusts: 9.7 | Wind Chill: 13.0
2017-09-09 13:41:31.831 (Buienradar) Barometer: 996.56 | Barometer Forecast: 2
2017-09-09 13:41:31.831 (Buienradar) Humidity: 87 | Humidity status: 3
2017-09-09 13:41:31.831 (Buienradar) Visibility: 3120
2017-09-09 13:41:31.831 (Buienradar) Solar Irradiance: 8.0
2017-09-09 13:41:31.831 (Buienradar) Rain rate: 23.7
2017-09-09 13:41:31.832 (Buienradar) Weather prediction today: Beter weer vanuit het westen! Maar voor hoelang? (Opgesteld op zaterdag 9 sep 2017 om 12:30)
2017-09-09 13:41:31.833 (Buienradar) Rain forecast started with following coordinates from Domoticz: 52.007062;4.322434
2017-09-09 13:41:31.833 (Buienradar) Rain forecast url: https://gps.buienradar.nl/getrr.php?lat=52.01&lon=4.32
2017-09-09 13:41:31.834 Error: (Buienradar) HTTP error in rain predictor: URL: https://gps.buienradar.nl/getrr.php?lat=52.01&lon=4.32
2017-09-09 13:41:31.834 (Buienradar) Going to try another Buienradar URL
2017-09-09 13:41:31.928 (Buienradar) Timeframe: 30, rows: 7
2017-09-09 13:41:31.928 (Buienradar) 000|13:45
2017-09-09 13:41:31.928 (Buienradar) 000|13:50
2017-09-09 13:41:31.928 (Buienradar) 000|13:55
2017-09-09 13:41:31.928 (Buienradar) 000|14:00
2017-09-09 13:41:31.929 (Buienradar) 000|14:05
2017-09-09 13:41:31.929 (Buienradar) 000|14:10
2017-09-09 13:41:31.929 (Buienradar) 000|14:15
2017-09-09 13:41:31.929 (Buienradar) Rain forecast: 0 [0-255] | 0.0 mm/hour
So it seems that "another Buienradar URL" works.
G3rard
Post by G3rard »
Yep that is by design. Sometimes the url is not reachable, so I have added a second URL which will be checked if the first one fails. So this error should only be there occasionally.
EdwinK
Post by EdwinK »
I've got some other errors now
2017-09-09 15:50:16.864 Error: (Buienradar) 'onHeartbeat' failed 'NameError':'name 'br' is not defined'.
2017-09-09 15:50:16.864 Error: (Buienradar) ----> Line 143 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:16.864 Error: (Buienradar) ----> Line 130 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:27.064 Error: (Buienradar) 'onHeartbeat' failed 'NameError':'name 'br' is not defined'.
2017-09-09 15:50:27.064 Error: (Buienradar) ----> Line 143 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:27.064 Error: (Buienradar) ----> Line 130 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:37.264 Error: (Buienradar) 'onHeartbeat' failed 'NameError':'name 'br' is not defined'.
2017-09-09 15:50:37.264 Error: (Buienradar) ----> Line 143 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-09-09 15:50:37.264 Error: (Buienradar) ----> Line 130 in /usr/local/domoticz/var/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
Just did a git clone earlier today.
HierBenIk
Domoticz version: 4.9700
Post by HierBenIk »
I just updated my Domoticz to the latest stable release.
After the update I installed the Buienradar Weather Lookup plugin.
Now I can see the new hardware in Domoticz but the hardware cannot be added.
Does sombody has any idea why the hardware cannot be added?
EdwinK
Post by EdwinK »
I thought I saw a fix for this before but can't seem to find it anymore.
Found Meetstation Lauwersoog (ID: 6277) at 7.7 km from your home location
N
Living near Rotterdam, that station is a bit further away.
Running G3rard's version of the script.
mrombout
Domoticz version: v4.10415
Post by mrombout »
Domoticz V3.8392 (c)2012-2017 GizMoCuz
Build Hash: 68538e3, Date: 2017-09-10 15:51:15
Well, I´d really like this plugin to start working... but, if I did I wouldn´t post this :-)
Read the entire thread, installed all Python dependencies, restarted service etc. but also in my case I caný find the entry with Buienradar.
The python3 localtest.py works ok
XML file contains weather station information
No Barometer and Visibility info found in your weather station, getting info from weather station De Bilt
Temperature: 14.7
Wind Speed: 11.96 | Wind Bearing: 182.0 | Wind Direction: S | Wind Speed Gusts: 16.0 | Wind Chill: 14.7
Barometer: 994.51 | Barometer Forecast: 2
Humidity: 80 | Humidity status: 3
Visibility: 14800.0
Solar Irradiance: None
Rain rate: None
Weather prediction today: Winderige en natte nacht (Opgesteld op zondag 10 sep 2017 om 11:45)
I run the last beta of Domoticz.
Any tips?
pvm
Domoticz version: 4.10538
Post by pvm »
First of all: I really like the plugin, I've been using it on my raspberry pi domoticz install
An idea: Is it possible to include this plugin in domoticz itself (no need to get from seperate repository and related steps) ?
It would be easier to use and for more Domoticz users.
G3rard
Post by G3rard »
mrombout wrote:Domoticz V3.8392 (c)2012-2017 GizMoCuz
Any tips?
viewtopic.php?p=148953#p148953
