Fibaro FGSD001 Co sensor
wboerhoop
Post by wboerhoop »
I bought a Fibaro CO sensor and installed it in Domoticz.
The Co sensor is found in OpenZWave usb module
and in Domoticz is showing found zwave co device
If i use the found devices i only get a device showing in temp. page
I can't find a device Co Sensor elswhere.
please help.
RFXcom-433E last FW
Aeon Z-stick Gen5
Zigbee
Synology and Raspberry Pi4 last Beta
tlpeter
Re: Fibaro FGSD001 Co sensor
Post by tlpeter »
You should get more devices.
Wake it up a couple of times with the button in the middle.
You should also have switches for CO,burglar,heat e.d.
micha_pr
Post by micha_pr »
I think the question is about the CO level.
I have same sensor, it give me many devices, but not the CO level.
The CO-level itself is missing, device is supporting it (here a screen form Z-Way - in Fibaro HC2 it is available too).
I'm not sure in this time - is there missing somethinhg in OZW / Domoticz or not.
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
tlpeter
Post by tlpeter »
I know, it is not there at all.
I do not know if it is a Fibaro only option or that Open-Zwave just doesn't support it yet.
I am not capable of debugging it unfortunately.
ArnovP
Domoticz version: 4.9700
Post by ArnovP »
I also have this problem with the CO sensor. Is there still no work-around?
MartyDarty
Post by MartyDarty »
It would be great if this option can be added.
