Great Job, re-added my 12 Switchescorbin wrote: Saturday 19 August 2017 4:47 Thanks, I've submitted the changes to be included in the main beta, there is a problem compiling but I don't think it is related to my changes.
Also if it does get added to the beta, existing wall switches will need to be deleted and re-added in Domoticz due to the new unit codes being used.
islandman
Guys, I'm a little confused with all the switches
Just to be sure, is there solution for Wireless Two-Button Switch LEFT click problem with 149 firmware in latest build or we all suppose to wait for an update from Xiaomi?
deennoo
You have to wait about a Fw update, that not à domoticz problème.pandemicz wrote:Guys, I'm a little confused with all the switchesJust to be sure, is there solution for Wireless Two-Button Switch LEFT click problem with 149 firmware in latest build or we all suppose to wait for an update from Xiaomi?
http://domo-attitude.fr
Luigi87
I have just ordered the Xiaomi Gateway. But it seems the gateway has an AU plug. Is there an EU plug?
Of do you have to put allways an adapter between the Power plug/ and the power socket?
Yes, we have to put an adapter, there's only Chinese version available.Luigi87 wrote: Tuesday 22 August 2017 16:31 I have just ordered the Xiaomi Gateway. But it seems the gateway has an AU plug. Is there an EU plug?
Pyros
Hello
Just bought that new model of XIAOMI (EDIT) ceiling : https://www.gearbest.com/flush-ceiling- ... 33589.html
Unfortunatly, it's no more seen in yeelight app but in smart home only.
Since it's not a device managed by the gateway nor a pure yeelight device, it's not visible in domoticz.
Any advice to manage it ?
thx
thx
deennoo
Where have you read that à yeelight device ? That à Philips One...once again search about product before buy a price...now you have :Pyros wrote:Hello
Just bought that new model of yeelight ceiling : https://www.gearbest.com/flush-ceiling- ... 33589.html
thx
- to search some source (i already give some)
- dévelop à python plugin for this, (thanks you)
Been there, bought xioami philips table lamp once, thought it's compatible with yeelight, unfortunately no developer gateway for xiaomi-philips productsPyros wrote: Wednesday 23 August 2017 0:51 Hello
thx
Pyros
Some guys worked on it : https://github.com/aholstenson/miio/issues/57deennoo wrote: Wednesday 23 August 2017 7:45 Where have you read that à yeelight device ? That à Philips One...once again search about product before buy a price...now you have :
I've just succeded with light on/light off the ceiling with miio.
So next step is to work on domoticz plugin with those informations
Mozart
Please use english in this forum so everyone can understand what you say.Pyros wrote: Wednesday 23 August 2017 15:11A priori y a du monde qui bosse dessus : https://github.com/aholstenson/miio/issues/57 et qui a trouvé des infos.deennoo wrote: Wednesday 23 August 2017 7:45 Where have you read that à yeelight device ? That à Philips One...once again search about product before buy a price...now you have :
Je vais regarder coté plugin mais je risque d'être léger en niveau
Raspberry 3
Aeon Labs Z-Wave Stick Series 2 - RFLink USB Gateway
Z-Wave switches
433 MHz Temperature + Humidity sensors
Philips Hue Lights
Mi-Light WiFi Bridge + RGBW Controllers
Z-Wave switches
Philips Hue Lights
snuiter
So I installed some Xiaomi stuff, like the gateway, a switch button and some other devices, all are working pretty good. My question is now how can i control the coloring of the gateway light in my script I have tried a couple of things. I want to change color on specific occassions.
Any suggestions as I want to change the colors of the gateway light via a script?
hekm77
Xiaomi Gateway Light Scenessnuiter wrote: Wednesday 23 August 2017 22:04 So I installed some Xiaomi stuff, like the gateway, a switch button and some other devices, all are working pretty good. My question is now how can i control the coloring of the gateway light in my script I have tried a couple of things. I want to change color on specific occassions.
http://4pda.ru/forum/index.php?act=find ... 60482495-2
snuiter
Had to analyze the script and play with it to understand how it worked. But it does. Thanks hekm77!
Hello, I tried to follow the instructions from the Wiki https://www.domoticz.com/wiki/Xiaomi_Ga ... ateway_MP3 to make the gateway playback a recorded message using a dimmer control from Domoticz. I am not getting any sound from the gateway though when I move the slider. I do see the log messages corresponding to the script so I know the script is firing off the command to play back "10001", "10002" etc.. Has anyone got this to work and if yes please help.
I am able to change the ringtone etc. to the recorded message via the Xiaomi App so I know that the recording is on the gateway.
xbox2610
Hi everyone i would like to ask if xiaomi smart plug (zigbee) works with Domoticz?
deennoo
Yes it is using last stablexbox2610 wrote:Hi everyone i would like to ask if xiaomi smart plug (zigbee) works with Domoticz?
mikeoo
I am using the Xiaomi Smart Home Gateway 2 now for a while with door sensors and temp sensors. I notice then the updates on the dashboard are not always the latest.
When i open Domoticz you see the date and time when the sensor is last seen. Some temp sensors are correct and one is 30 min behind. The happens random with them. But when I open the chart I the time is correct.
Anyone have a explanation for it.
xbox2610
Hi all, I have a few days restarted domoticz + homebridge + mqtt + broadlink and it all works well apart from the gateway functionality (sound effects + RGB light) and xiaomi smart plug somebody to the same problem?
Thank you
Thank you
