- EdwinK
- Domoticz version: BETA
I Need to change the font size
tottka
Is it possible to combine a floorplan with dashticz?
perkonix
Is it possible to get rid off the On/Off status for switches? I have some Hue scenes that I'd like to activate with a single tap. So they should basically be push buttons without a status.
- gielie
- Domoticz version: latest β
I'd like to change the font size of my selector button switch in the (config['selector_instead_of_buttons'] = 0;) setting.
Is this possible and how can i do this?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Cubes
Same question. Combining the floorplan with the features of dashticz would be the ultimate interface imo.
robgeerts
- Domoticz version: 3.7067
Ok, do you mean you just want to see the floorplan like you see in domoticz?
Bob123bob
Can someone explain me how trafficmap is working now ?
After a git pull to update my old version (1 or 2 months old), I need to modify CONFIG.js with new settings options config[xxxx] to get dashticz working
Now I can't display google map with trafficmap anymore, I just have an empty block
So a reminder how it works should be helpful for me and others
The wiki seems not talk about google map details like where to create API and how to display the traffic map
See my setup below. I have four maps, but cutting it down to your preferred number should not be difficult
In the settings part of CONFIG.js:
After the settings part you should define something like:
To call the map in a column, do something like:
Hope this helps
config['gm_api'] = '<API KEY>';
config['gm_zoomlevel'] = '10';
config['gm_latitude'] = 0;
config['gm_longitude'] = 0;Code: Select all
var maps = {}
maps.arnhem = { width:12, latitude: 51.980109, longitude: 5.931587, zoom:10 }
maps.utrecht = { width:12, latitude: 52.090938, longitude: 5.122354, zoom:10 }
maps.amsterdam = { width:12, latitude: 52.335280, longitude: 4.938526, zoom:10 }
maps.denhaag = { width:12, latitude: 52.068880, longitude: 4.324216, zoom:10 }Code: Select all
columns[11] = {}
columns[11]['blocks'] = ['blocktitle_11',maps.arnhem,'blocktitle_13',maps.amsterdam]
columns[11]['width'] = 6;-
Bob123bob
That's help me a lotTapNL wrote: Sunday 27 August 2017 16:50 See my setup below. I have four maps, but cutting it down to your preferred number should not be difficult
After the settings part you should define something like:Code: Select all
config['gm_api'] = '<API KEY>'; config['gm_zoomlevel'] = '10'; config['gm_latitude'] = 0; config['gm_longitude'] = 0;
To call the map in a column, do something like:Code: Select all
var maps = {} maps.arnhem = { width:12, latitude: 51.980109, longitude: 5.931587, zoom:10 } maps.utrecht = { width:12, latitude: 52.090938, longitude: 5.122354, zoom:10 } maps.amsterdam = { width:12, latitude: 52.335280, longitude: 4.938526, zoom:10 } maps.denhaag = { width:12, latitude: 52.068880, longitude: 4.324216, zoom:10 }
Hope this helpsCode: Select all
columns[11] = {} columns[11]['blocks'] = ['blocktitle_11',maps.arnhem,'blocktitle_13',maps.amsterdam] columns[11]['width'] = 6;
My map is now working
Thanks to have taken the time to share
lukbe
- Domoticz version: 3.8153
I wanted add this nice dashboard in to the domoticz.
I followed the instructions:
cd domoticz/www/
git clone https://github.com/robgeerts/dashticz_v2
cd domoticz/www/dashticzv2/custom/
cp CONFIG_DEFAULT.js CONFIG.js
Then I opened CONFIG.js - sudo nano CONFIG.js and here I added my ip:port.
Then I opened browser my ip:port/dashticzv2/
in the domoticz I have 5 widgets (1 for control light and 4 with temperature and humidity)
And there is only time and date
Where is problem ? Thank you for support...
Last stable version of the domoticz on the RPI3.
cd domoticz/www/
robgeerts
Do you see a settings icon on the top right?
Otherwise, try the example CONFIG.js in the first post in the topic 'Getting Started'
lukbe
Yes, I there have settings icon.
When I use your config and in config I set my ip and port then I receive error invalid client and I am redirected to Spotify.
Odesláno z mého MI 4W pomocí Tapatalk
robgeerts
Remove spotify from your blocks, or enter a spotify api key
lukbe
It was not possible remove Spotify because dashticz was not loaded.
Now I cleared cookies and cache and it works.
Only one thing, why I must on each browser set in the settings ip address of the rpi ?
robgeerts
When you save your settings, you get a new popup with some output, this output you have to save into config.js ..
an0key
Re: Dimmer as a simple switch
Would be interested to know too.
A feature to override the switch type, or have a static option would be good, as I find the slider doesn't really work.
Will just create some dummy switches and some lua to call these up for now.
arnoldg
acces dashticz from WAN
when i try to acces Dashticz from wan, i get an empty page with headers and that kind off static stuff.
But the switches are not visisble.
what could it be ?
Dasthics is localy running at 192.168.1.104:80
domotics on the same server but at port 8080
please need some help here.
what could it be ?
DannyS
I have installed Dashticz_v2, and all is working, except for 1 thing :
The app doesn't read my CONFIG.js.
When I make a change in the file itself, it never shows on the main screen.
If I rename it, nothing is shown, so it must be found (or not found in this case), but if I, for example, change config['app_title'] = 'Dashticz_Test';
it is never shown.
Tried it with FireFox, and IE/Edge on Windows 10, and also on a Android tablet.
What is going wrong here? Or what did I mess up....
Thanx,
Danny
it is never shown.
Thanx,
Danny
DannyS
Kind off fixed it, it contained /* and *\ at the begining and end, removed it and now it works better!
- EdwinK
yes, those signals to the browser to not execute those lines, but see them as remarks
