PRi + MotionEye + Domoticz Setup - Help Please
husar
Post by husar »
I am not sure if it possible to get my current setup working in Domoticz but I am half way there and looking for some assistance. I have looked to the camera wiki page and it has allowed some success.
My current setup has several USB camera attached to their own RPI and an RPi running MotionEye as the main controller. This works great.
Now I'd like to see about getting the cameras added to Domoticz. I can access each camera's direct feed in the browser by doing the following.
Live feed: http://10.0.xxx.xx:xxxx
List image: http://10.0.xxx.xx:xxxxx/picture/1/current/
Testing the live feed link in the More Options >> Cameras does show the feed when I test it during setup.
Back on the Camera page the image to the far left is broken. If I right click and look at the locaion it is the Domoitcz server with /camsnapshot.jpg?idx=1 after it. Clciking on the web cam icon brings up the live feed overlay window but the stream loads as a broken image.
Is this the correct way to get my setup working in Domoticz or is it just not possible with my setup?
Thank you.
fabix68
Re: PRi + MotionEye + Domoticz Setup - Help Please
Post by fabix68 »
I have the same problem.
You've solved?
pepijn
Post by pepijn »
Set mjpg_client_idle_timeout to 0 in your motioneye.conf file and you'll no longer get empty JPEGs (except for the very first request after you restart the server).
DaWauZ
Post by DaWauZ »
pepijn wrote:Set mjpg_client_idle_timeout to 0 in your motioneye.conf file and you'll no longer get empty JPEGs (except for the very first request after you restart the server).
I tried this, but still no stream or snapshot taken.
Test image is good though.
Raspberry Pi 2 model B with domoticz
OMV NAS installed on thin client HP T610
Openelec Kodi Mediaplayer on thin client HP T520 (and with multiboot windows 10)
armine
Post by armine »
Plase help me.I've got Domoticz on one Pi and my 2 Raspberry Pi Cam on another. Eyemotion and PiKellCam.How do I add this cam to Domoticz?I have another raspberry running the web interface, and the connection made i Domoticz with the following settings. No Dmotocz not detect camera stream.
TDK20
Domoticz version: 3.8367
Post by TDK20 »
Anybody who has solved this? Please share.
TDK20
Post by TDK20 »
Simple solution, had to omit the leading slash.
Mozart
Post by Mozart »
husar wrote: Wednesday 18 January 2017 19:22 I am not sure if it possible to get my current setup working in Domoticz but I am half way there and looking for some assistance. I have looked to the camera wiki page and it has allowed some success.
Thank you.
In Domoticz you should not add the http://10.0.x.x in the ImageURL box, only this:
picture/1/current/
Raspberry 3
Aeon Labs Z-Wave Stick Series 2 - RFLink USB Gateway
Z-Wave switches
433 MHz Temperature + Humidity sensors
Philips Hue Lights
Mi-Light WiFi Bridge + RGBW Controllers
DaWauZ
Post by DaWauZ »
well @ my setup it just wont work. With or without slash, with or without image url, only the test image succeeds.
the streaming url should be http://ipadress:8081
The embedd url should be http://ipadress/picture/1/frame/
well tell me what I should fill in domoticz, I tried everything, also with or withouth usernames
TDK20
Post by TDK20 »
As mozart mentioned, just use
picture/1/current/
as the image URL no leading backslash or anything else. I tried a few variations, only the previous mentioned one worked.
DaWauZ
Post by DaWauZ »
does not work. Only test image works.
heggink
Domoticz version: 12451
Post by heggink »
Anyone ever got this to work?
P1 meter & solar panel
alexsh1
Domoticz version: v3.8975
Post by alexsh1 »
heggink wrote: Sunday 04 February 2018 21:49 Anyone ever got this to work?
Yes. I did.
You should add a different URL:
picture/1/current/?_username=admin&_signature=[whatever your signature is]
You can get your exact URL in Video Streaming - Snapshot URL in the motionEye settings. Make sure there is no "/" in front of the image URL.
Works fine in the latest Domoticz.
pmarcus
Domoticz version: 4.10256
Post by pmarcus »
I have solved it for me. Had the same issue.
In Motioneye added a user with no password. (only view rights)
Then i made the configuration as mentioned with: picture/1/current/
The standard port = 8765
works for me.
quilae
Post by quilae »
That's pretty weird. If I try the solution provided by alexsh1 and test the connection then the image shows up for a fraction of a second and then shows a broken image but if I accept the settings anyway then the thumbnail shows up and both streaming and taking snapshots work so this is definitely a correct solution.
Jimbolaya
Domoticz version: 4.11207
Post by Jimbolaya »
I believe MotionEye is no longer being developed. You should try motionEyeOS. Google it and you’ll find the download and install instructions. I have that working perfectly with Domoticz.
Jim
iMoi
Post by iMoi »
Jimbolaya wrote: Saturday 29 December 2018 14:53 I believe MotionEye is no longer being developed. You should try motionEyeOS. Google it and you’ll find the download and install instructions. I have that working perfectly with Domoticz.
Hi Jimbolaya
I followed your advice and installed MotionEyeOS on my RPi, and would like to add its video stream to Domoticz : in Domoticz, I managed to get the video with the "Test connexion" button, but not when clicking on the Cam icon in the list of cameras.
could you tell me how you did it ?
thanks a lot !
iMoi
Domoticz (domoticz_apollolake-6.2_4.0.9700-7.spk)
installed on a Synology NAS DS 218+ (INTEL Celeron J3355)
under DSM 6.2.1-23824 Update 4
Raspberry Pi B+ with official cam
+ Android smartphone with IP Webcam
Jimbolaya
Post by Jimbolaya »
Jim
ThirstyThursten
Domoticz version: 2021.1
Post by ThirstyThursten »
@Jimbolaya, I have the same problem now, sadly the link you provided no longer works. Thread has been deleted.. :(
Do you have any additional information?
Greets,
Thirsty
EdwinK
Post by EdwinK »
He hasn't been around since the end of 2019, so I'm afraid there will be no answer. Too bad, looking for it myself.
