I am only able to change the thermostat heat/cool mode and fan mode by returning to the utility tab and editing the device settings. The only thing adjustable from the dashboard or the app is the temperature set points. This works with other HA applications. Is it just me?
V3.5877
Rpi 3B+
RTC CT-100 Z-wave thermostat
Unable to change TStat Mode and Tstat Fan mode from dashboard
Re: Unable to change TStat Mode and Tstat Fan mode from dashboard
I have the same issue. Just bought a Remotec ZXT-120 to control my A/C.
I can control the temperature but to change the mode/fan mode I have to click "edit" and than select a mode and save, which is quite cumbersome.
On the domoticz app I cannot change it at all which is kind of a showstopper for me.
Was thinking about creating a virtual selector sensor and than set the values accordingly on the real device using some LUA scripting, but maybe I am missing something here?
See the images below to illustrate my issue:
- Domoticz.png (25.92 KiB) Viewed 995 times
- Domoticz (1).png (17.34 KiB) Viewed 995 times
