Dashticz - Bug report
kurniawan77
Re: Dashticz - Bug report
Does anyone experience lag in dimmer sliders? They don't slide so smoothly. I don't know if this has to do with latest beta as this is the first time that I try dashticz...
Sent from my Nexus 6P using Tapatalk
robgeerts
- Domoticz version: 3.7067
Just tested, no problems here...
kurniawan77
What can it be? because mines are very laggy.. i cant drag them smoothly, i've tried on my tablet, PC, Phone... bummer
robgeerts
Somebody else having this problem???
- HansieNL
Same problem here on both ipad and pc. Don't know when this problem started.robgeerts wrote:Somebody else having this problem???
Blah blah blah
Blueone
hmm strangerobgeerts wrote:It is an async call?
req = $.getJSONP({ url: settings['domoticz_ip']+'/json.htm?type=devices&filter=all&used=true&order=Name&jsoncallback=?', type: 'GET', async: true, contentType: "application/json",dataType: 'jsonp', error: function( jqXHR, textStatus ) { console.error("Domoticz error!\nPlease, double check the path to Domoticz in Settings!"); }, success: function(data) { //etc etc
I checked with the chrome debug console, I have quite some devices in domoticz and it takes about 200 to 500ms to do the call to get all data. During this time the dashboard freezes, as it refreshes every 5 seconds the dasboard is freezed for 10% of the time. So maybe the json call to domoticz can be approved or run async?
Also the external pages are causing issue's sometimes, with long loading times the dashboard also freezes until the reqeust receives a time-out.
I also made a video of the issue, maybe that helps in recognizing the problem. During the freeze I can't do anything with the screen:
https://player.vimeo.com/video/228036880
kurniawan77
Would be great if this would be fixed. I was just planning on to getting rid of the Eneco Toon and do it with Dashticz...HansieNL wrote:Same problem here on both ipad and pc. Don't know when this problem started.robgeerts wrote:Somebody else having this problem???
robgeerts
Problem is it dont occurs with me... I was hoping someone could help me with this or could find the bug in the scripts. Although, i am working on loading scripts faster so maybe that solves it already.
Blueone
Do you have some tips for debugging something like this, I can't see it in the network tab from the google debugger, I would like to debug it but I need some directions
. At this moment I only know it happens just after the call to domoticz.
I just send you a profiling copy, maybe you can do something with it.
I'm a little bit further, appearently not the call itself but the success function (processing the received data) is causing the freeze. I have about 356 devices in domoticz so maybe this way of processing isn't suitable enough for a bigger domoticz installation?
kurniawan77
2 things...
how do i get the button "Comfort" next to "Home"? Seems to me that this should fit without making the buttons smaller imo.
And... i cannot change the "Room Setpoint" with -(minus), but the + is working...
Swifty
Anyone know the answer to this?Swifty wrote:I have a graph on my dashticz page for energy usage.
The graph has automatically added several buttons for "Last Hours" "Today" and "Last Month".
I'd like to permanently display "Today" but if I click this button it only displays for a couple of minutes then goes back to last hours.
Is this a bug or by design?
Bigted
- Domoticz version: 2020.1
It was recently fixed in the betaSwifty wrote:Anyone know the answer to this?Swifty wrote:I have a graph on my dashticz page for energy usage.
viewtopic.php?p=143352#p143352
Swifty
Ah brilliant, many thanks - I hadn't seen that!Bigted wrote:It was recently fixed in the betaSwifty wrote:Anyone know the answer to this?Swifty wrote:I have a graph on my dashticz page for energy usage.
Time to update again
Blueone
Oke, after debugging a couple of hours i found out is has to do with the lights which have the RGB option, when I remove my hue lights the issue is gone.Blueone wrote:hmm strangerobgeerts wrote:It is an async call?
robgeerts
Can someone with this issue confirm this?
Blueone
I didn't had any freezes anymore after removing the RGB lights from the dashboard, I will try to narrow it down further to see what is causing it in the weekend.robgeerts wrote:Can someone with this issue confirm this?
- gielie
- Domoticz version: latest β
Is it possible to decrease the font size of the selector switchkurniawan77 wrote:
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Blueone
Oke, this row is causing the freeze issue:Blueone wrote:I didn't had any freezes anymore after removing the RGB lights from the dashboard, I will try to narrow it down further to see what is causing it in the weekend.robgeerts wrote:Can someone with this issue confirm this?
$(".rgbw").spectrum({
if I comment the line, the issue doesn't occur, it is not caused by the "color: Cookies.get('rgbw_'+idx)" in the block.
Appearently this is the color spectrum for picking the color?
robgeerts
Yes, thats the plugin I use to show a colorpicker..
- gielie
HI Rob,
The following code doesn't work anymore in the latest beta.
Its the presence switch with is no a on/off again instead of a aan/afwezig.
Can you fix this?
function getBlock_6(device,idx){
$('.block_'+idx);
var html='';
html+='<div class="col-xs-4 col-icon">';
if(device['Status']=='Off') html+='<img src="img/cust_away.png" class="off icon" />';
else html+='<img src="img/cust_home.png" class="on icon" />';
html+='</div>';
html+='<div class="col-xs-8 col-data">';
html+='<strong class="title">'+device['Name']+'</strong><br />';
if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
else html+='<span class="state">AANWEZIG</span>';
if((_SHOW_LASTUPDATE && (typeof(blocks[idx])=='undefined' || typeof(blocks[idx]['hide_lastupdate'])=='undefined' || blocks[idx]['hide_lastupdate']===false)) || (!_SHOW_LASTUPDATE && (typeof(blocks[idx])!=='undefined' && typeof(blocks[idx]['show_lastupdate'])!=='undefined' && blocks[idx]['show_lastupdate']==true)) ){
html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
html+='</div>';
return html;
}Can you fix this?
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
