Domotica, PC or Raspberry Pi or ...?
Domotica PC or Raspberry Pi ?
PC
9
18%
Raspberry Pi
31
61%
Something else (specify below)
11
22%
Total votes: 51
janvier123
Post by janvier123 »
I was wondering if i can trade my RBPI for a bigger, faster linux PC
Any thoughts?
Opinions are more then welcome !
SweetPants
Re: Domotica, PC or Raspberry Pi or ...?
Post by SweetPants »
janvier123 wrote:I was wondering if i can trade my RBPI for a bigger, faster linux PC Any thoughts?
I use an Intel NUC, dual Atom CPU 4Gb, 60Gb MSATA running Ubuntu 14.04 LTS and Domoticz Beta compiled from source and this runs smootly 24x7 for more then 2 years now.
Brutus
Post by Brutus »
I also use an Intel NUC, Intel Core I5, 8Gb, 256Gb Msata with Windows 7 64 Bits, Kodi and Domoticz.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
janvier123
AlexSurf86 wrote:CYBERPOWERPC Gamer Xtreme
https://www.bestadvisor.com/best-gaming-pcs
This PC is not so expensive in compare with other models, but anyway you can play the most popular games at max settings without a problem.
What else needs gamer for happiness? :)
its for domotica ;)
EdwinK
Post by EdwinK »
Now running Domoticz on my Synology NAS, but I'm thinking of moving it to a Raspberry PI.
Derik
Post by Derik »
Odroid Xu4...
Fast as..... :D :lol:
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
Would really like to get Domoticz running on my Synology NAS connected to my HomeWizard. The Syno is on 24/7 so no extra Watts to be burned. Domoticz is running fine (or so it seems). If I could only get the script from @Wobbles to work... :roll:
Edit: Got the plugin working :D Just had to place it in the folder /usr/local/domoticz/var/plugins/HomeWizard (the last folder name is completely arbitrary ;) ) BTW the location is the same as /volume1/@appstore/domoticz/var/plugins/HomeWizard :)
HTH
Greetz,
Sjonnie
Last edited by Sjonnie2017 on Friday 04 August 2017 13:25, edited 2 times in total.
YouLess Energy meter
tlpeter
Post by tlpeter »
Is i need to start over them it will be a nuc rubbing vmware. Domoticz will then be on Ubuntu and probably the nuc will run some more virtual machines.
philchillbill
Post by philchillbill »
I have a Synology DS916+ with 8GB RAM which I use as an Audio (LMS) and Video (Kodi) server but not for Domoticz. It's not a full Linux machine and I just felt that for 100% flexibility with home-automation I should have a real Ubuntu box. Maybe I'm wrong, but I see the RPi as a little light, so I use a NUC5CPYH (which consumes just 6W) for Domoticz. All the compute-power needed for tons of cron jobs and full Linux. They are not *that* expensive, those low-end NUCs - for under EUR 200 you can put 4GB RAM and a decent SSD inside. WiFi, BT and ETH are already standard, as is CIR so you can also use it as a Kodi player if you like. The NUC6 and 7 families even have a MIC array to mess with speech recognition directly.
Sometimes having a nicer solution is worth a few bucks more, just my 2 cents...
randytsuch
Post by randytsuch »
I'm running domoticz on a pi, and it works great for me.
My system is pretty small, so at some point maybe I'll want more horsepower.
To me, I like the the pi is small so easy to find a place for it, and that it doesn't use much power. Power is important since it runs 24/7.
Overkill is not always best lol
Randy
