Blockly basic doesn't work
darrepac
Post by darrepac »
Just discovering event and make a try: send me an email if memory usage is above 95%.
I created the following and it is not possible to save the event (so I guess there is an error in it).
Do you see where is the mistake??
Domoticz - Google Chrome_2014-04-16_20-05-01.jpg (14.07 KiB) Viewed 2533 times
SweetPants
Re: Blockly basic doesn't work
Post by SweetPants »
The issue is the '%" sign in the subject, remove it and try to save it then
darrepac
Post by darrepac »
Indeed, it works now!
We have to limit to the alphabetical letter in any text?
SweetPants
darrepac wrote:We have to limit to the alphabetical letter in any text?
Don't know, maybe if you 'escape' the character (\%) it wil also work, didn't try that.
gizmocuz
Post by gizmocuz »
Should now be fixed in #2421+
Egregius
Domoticz version: v2024.7
Post by Egregius »
Great! Send email is working from blocky.
Thank you gizmocuz!
assenzuid
Post by assenzuid »
I have created below Blocky, but the email is not send.
Is there some debug or log to check why it isn't working.
There's no separate notification configured or set at the device self.
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
As I can see in your blocky you are using the if/else function.
Change it to a single if and it should work.
(Don't use the if with + function)
Sent from space using an app.
assenzuid
Post by assenzuid »
Ok, I will change it to a single IF statement
assenzuid
Post by assenzuid »
I can confirm it's working, thanks!
assenzuid
Post by assenzuid »
I have configured below working Blocky, the cron job is running every 10 minutes to fetch the actual data from Buienrader.
If the value is above 25% an email is send out, but the notification is send every 10 minutes when the value is still above the 25%.
I want to build some logic into the blocky that prevents this, when the value is below 25% and later at the day it is raised above 25% the notification must send out again.
Someone an idea how to build/ configure this.
Thanks.
