Script -Error - Returned: 256
vicenschamorro
- Domoticz version: v3.9443
Hi All,
I'm a novice in Domoticz. I've configured correctly a couple of ZWave devices. The problem I have is that I cannot execute scripts in a Raspberry Pi 2 environment.
I've read a lot about this topic in the forums and internet but I have not be able to find a solution.
All the attempts has been unsuccessful. Always the error I see in the log from Domoticz is the same:
"Error: Error executing script command (/home/pi/domoticz/scripts/play_radio_sonos.py). returned: 256"
I've tried:
1. Add 777 permisions to the script file
2. Reboot pi and domoticz
3. Add a third "/" in the domoticz - On Action
4. Write the script in bash or python
5. Move the script to another locations
and probably other scenarios that now I cannot remember.
One important point is that if I execute the script using the "pi" user, I don't have any problem.
Any idea?
Thanks!!!
Vicens
I've tried:
Any idea?
Thanks!!!
Vicens
Raspberry PI 3 - Aeon S2 stick - Aeon Multisensor - Belkin Wemo Switch - Sonos Player1 - Xiaomi Gateway + sensors
vicenschamorro
Re: Script -Error - Returned: 256
I've been all the weekend trying alternatives without any progress.... Do you have some idea?
zaadstra
- Domoticz version: 2020.2
Today I've been debugging this "feature" for the second time.
First case, I ran a script with parameters, and one parameter was incorrect and the script wasn't too happy about that. The commandline showed that quickly.
Today, another script was tested on commandline first and happily ran there, but not as Action in Domoticz. This time it appeared that a config file was not used/not found but no clear error given.
2015-08-05 21:33:02.885 Error: Error executing script command (/home/pi/pushover/pushover.sh). returned: 256
2015-08-05 21:43:51.274 Error: Error executing script command (/home/pi/domoticz/scripts/pushover.sh). returned: 256
The problem was solved when I added extra parameters to the script line (the ones it should read from it's file in /home/pi/.config/
So tweak a little with your script and/or parameters, good luck
oliviers
- Domoticz version: Stable
Like several others, I'm also unable to execute scrits from an On/off virtual swith.... They result in "errror 256"..
Both scripts run just fine when executed from the command line.
Both scripts are owned by "pi" and have proper execution flags:
I have tried with two or three '/' in the swith configuration:
script:///home/pi/domoticz/scripts/listen_radio.sh
script:///home/pi/domoticz/scripts/stop_radio.sh
Script contents are quite simple:
and
Anyone has an idea ?
Oliviers
EDIT:
This is solved.
1. If any command in the script sends messages to the console, make sure you redirect the output somewhere ( > /dev/null)
(In my example above, this is the case of the mplayer command)
2. If any command "never ends/never returns" (like the mplayer radio streaming in my case), put an "&" at the end of the command to let the script continue and finish
2015-09-25 21:09:04.325 Executing script: /home/pi/domoticz/scripts/listen_radio.sh
2015-09-25 21:09:43.315 Error: Error executing script command (/home/pi/domoticz/scripts/listen_radio.sh). returned: 256
2015-09-25 21:09:44.324 Executing script: /home/pi/domoticz/scripts/stop_radio.sh
2015-09-25 21:09:45.064 Error: Error executing script command (/home/pi/domoticz/scripts/stop_radio.sh). returned: 256Both scripts are owned by "pi" and have proper execution flags:
pi@raspberrypi ~/domoticz/scripts $ ls -l *radio*
-rwxrwxrwx 1 pi pi 103 Sep 25 17:06 listen_radio.sh
-rwxr-xr-x 1 pi pi 59 Sep 25 18:06 stop_radio.shscript:///home/pi/domoticz/scripts/listen_radio.sh
pi@raspberrypi ~/domoticz/scripts $ cat listen_*
#!/bin/bash
echo RADIO CLASSIQUE
mplayer -noconsolecontrols -playlist /home/pi/domoticz/playlist.txtCode: Select all
pi@raspberrypi ~/domoticz/scripts $ cat stop*
#!/bin/bash
sudo /usr/bin/killall mplayer > /dev/nulOliviers
EDIT:
This is solved.
Paris area
Raspberry Pi 4 - RFXComm 433 - IrTrans - Zwave
jpinzon408
Hi, for ON/OFF works for me this way,
for ON: script:///path/yourpythonprogramON.sh
and OFF: only script:///path/yourpythonprogramOFF.py
I hope you find this information useful.
#!/bin/sh
python yourpythonprogram.py > /dev/null 2>&1 &
exit 0
zaadstra wrote:Today I've been debugging this "feature" for the second time.
I thought I would post my findings from when I had the same problem. Since my domoticz run as root, the scripts were executed as root as well. So in my case it tried to find the config files in /root/.config/xxx and then failed
Maybe someone will find this useful.
MikeNg
Got the same issue with the playcode.py script running from on/off action of a domoticz switch. Checked in the log it say error executing script returned 256. Running the script from SSH comand line it works perfectly.
Stefan
- Domoticz version: 3.5877
I`m also facing issues with this. My switch triggers two scripts, on and off. It throws the error 256 on both on and off action, however the on does get executed and turns on the purifier. I can`t understand why, since the scripts look exactly the same, both are owned by root and permission 777 had been applied.
ON:
OFF:
Can somebody help pls?
ON:
#!/usr/bin/lua
if (devicechanged['Air Purifier'] == 'On') then
os.execute ('node /etc/domoticz/scripts/xiaomi/airpurifier.js 192.168.1.20 power true > /dev/null')
#!/usr/bin/lua
if (devicechanged['Air Purifier'] == 'Off') then
os.execute ('node /etc/domoticz/scripts/xiaomi/airpurifier.js 192.168.1.20 power false')
root@stf-pi:/etc/domoticz/scripts/xiaomi# pwd
root@stf-pi:/etc/domoticz/scripts/xiaomi# ls
airpurifier.js air_purifier_off.lua air_purifier_on.lua
2017-07-29 19:36:22.376 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_on.lua). returned: 256
2017-07-29 19:36:32.979 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_off.lua). returned: 256
2017-07-29 19:39:17.320 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_on.lua). returned: 256
2017-07-29 19:39:27.036 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_off.lua). returned: 256
2017-07-29 19:41:07.420 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_on.lua). returned: 256
2017-07-29 19:41:15.853 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_off.lua). returned: 256
oliviers
The answer is above in this thread. You need an "intermediate" script which launches your lua sript with an "&" at the end of the command line to return to Domoticz without waiting. See my post of Sept 16 2015 and the post from jpinzon408 dated 21 Oct 2016.
Rgds,
Oliviers
Rgds,
Oliviers
Paris area
- EdddieN
- Domoticz version: 4.9700
Hello
Reviving this.
I'm doing a simple pmrestart.sh
my pmrestart.sh has a 755 and works from shell. But when I try to execute it within Domoticz I get the 256 error on the log file.
I have other SH files that work fine no idea why I'm wrong here. Any help?
Reviving this.
#!/bin/sh
/usr/bin/pm2 restart allI have other SH files that work fine no idea why I'm wrong here. Any help?
11101101 - www.machinon.com
timmpo
old thread but ...
When one of this problem hit me, was it because my python library environment path not was set when run from root/sudo
domoticz run python scripts with sudo/root environment path's
Stop Domoticz service:
Run Domoticz direct from terminal:
Run the script from inside domoticz (pushbutton etc..)
now you shuld see in terminal what cuase the problem
you can run this python code to check your environment path's the user using
for me sudoers missing /home/pi/.local/lib/python2.7/site-packages
to fix that you can add this directly in your python code
sudo /etc/init.d/domoticz.sh stopCode: Select all
./home/pi/domoticz/domoticznow you shuld see in terminal what cuase the problem
import sys
print (sys.path)to fix that you can add this directly in your python code
import sys
sys.path.append('/home/pi/.local/lib/python2.7/site-packages')- Keptenkurk
- Target OS: -
old thread but...
timmpo, thanks for sharing your solution, it saved my day! (after all other fixes about rights, wrapping the python script in a bash shell etc failed).
My newly installed and imported lib was just not in the path...
/paul
/paul
damdub
Hello all,
I read and followed solutions provided here with no luck.
I have a .sh script which I fire from a switch in domoticz.
The script is supposed to change a switch configuration via telnet communication.
The script is working from console with no error.
The script is working from Domoticz but leaves an error in logs
Error executing script command (/home/pi/domoticz/scripts/remote_HP_switch.sh). returned: 256
The script is
The script file permissions is rwx for everyone
I could live with the error as the script is running OK but I would prefer to understand what I'm doing wrong
Any idea someone ?
Thank you very much
Damien
The script is
#!/bin/sh
HOST='***.***.***.***' /IP address of the switch
CMD1='conf'
CMD2='interface 1 enable"
echo open "$HOST"
sleep 0.2
echo "$x"
sleep 0.2
echo "$CMD1"
sleep 0.2
echo "$CMD2"
sleep 0.2
echo "exit"
) | telnet
Any idea someone ?
Thank you very much
Damien
- FireWizard
Hi, @damdub
Please, have a look at: viewtopic.php?f=6&t=30657&p=231907#p231907
Perhaps the solution at the end, mentioned by DewGew is also suitable for you.
Best regards
Best regards
damdub
Hello FireWizard
Thank you for taking care of this case
I haven't tried your suggestion yet but are you sure it could change something for me ? I doubt that because in my case the script runs and does what I want him to do. The command reaches my HP switch and the configuration is changed as asked in the script. But there is an error code 256 in the domoticz logs.
Damien
Damien
damdub
Hello
I've found the solution.
I had to close the telnet communication properly at the end of the script by adding a exit 0
For anyone interrested in scripting HP Switch config, my working script is now
Thank you for your help
Damien
#!/bin/sh
CMD1='conf'
echo open "$HOST"
sleep 0.2
echo "$x"
sleep 0.2
echo "$CMD1"
sleep 0.2
echo "$CMD2"
) | telnet > /dev/null
exit 0
Damien
OldPensionado
@timmpo: many thanks! Your solution about an incomplete PATH variable saved my weekend!
Especially the suggestion about running Domoticz from the terminal and then printing sys.path was extremely clarifying.
Thanks again!
(And yes, I know: it's an old thread but who cares! I'm old too...)
Thanks again!
RPi 1, model B, Rev. 2; RPi 3B+; RPi Zero; RPi 4B
Raspbian 11 (Bullseye)
Domoticz V2024.7
Well, such is life. And it's getting sucher and sucher...
Domoticz V2024.7
nigels0
- Domoticz version: 3.8153
A good check before doing anything is to run the script with sudo beforehand. It should give an idea where the problems are.
I found that with my python scripts, I needed to install a library again using sudo pip install <libraryname> - saves having to edit the path.
