Traffic with waze in Domoticz
DomoHouse
Re: Traffic with waze in Domoticz
Post by DomoHouse »
Yes, I have got exactly the same issue. Not sure whether Waze is blocking my IP address or that they have disallowed the usage of this feature :(
MarceldeJongNL
Domoticz version: 3.5108
Post by MarceldeJongNL »
DomoHouse wrote: Friday 28 July 2017 17:52 Yes, I have got exactly the same issue. Not sure whether Waze is blocking my IP address or that they have disallowed the usage of this feature :(
Just found out they made an extra check for the ""api""
I fixed my problem with information from here
You have to fake the referer url. I changed the row:
local waze=assert(io.popen('curl  "https://www.waze.com/r...".')
to:
local waze=assert(io.popen('curl --referer https://www.waze.com "https://www.waze.com/r...."')
And all is fine again
Hardware: Raspberry Pi 2B | RFXCOM RFXtrx433E v1 | Synology DS213+ | KaKu Clones | Conrad RSL switches | KAKu Doorbell Clone | USB Webcam | ICY Thermostat | Resol DL2 | Imatic Relay Board | Eminent 6230 | Eminent 6220 | iMatic 16 ports Relay Board
Podarcis
Post by Podarcis »
+1! Great find. Now my lua script is working again!
pimseb
Domoticz version: 2020.1
Post by pimseb »
I'm sorry I've followed the howto of lemassykoi but I'm getting this error :
2017-09-13 13:42:30.717 LUA: >> Monitoring Traveltimes
2017-09-13 13:42:30.718 LUA: >> Debug is set to: Y
2017-09-13 13:42:30.718 LUA: >> Update timeout: 600
2017-09-13 13:42:30.718 LUA: >> Lastupdate Home to Work : 5934
2017-09-13 13:42:30.718 LUA: >> Lastupdate Work to Home : 5922
2017-09-13 13:42:31.033 LUA: ========================================================================================================
2017-09-13 13:42:31.033 LUA: { "error" : "Internal Error"}
2017-09-13 13:42:31.034 Error: EventSystem: in script_time_Waze.lua: [string "-- script_time_Waze.lua..."]:99: attempt to index field 'response' (a nil value)
EDIT :
I changed the value work to home to their french translations and forgot to change the value in the script
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
great adonn
pimseb
Post by pimseb »
Hello
I've reinstalled domoticz and lost all my files.
Is there still somebody here still using this script ? I've tried the bash script but I can't make it work.
I have a forbidden error
Thank you
krizzz
Post by krizzz »
Sae request here, nobody using the script anymore?
Kangooroo42
Post by Kangooroo42 »
I got this error since 2 days:
Error: EventSystem: in Waze: [string "..."]:38: bad argument #1 to 'for iterator' (table expected, got nil)
it seems to be a problem on line 38
for response,results in pairs(route) do
anyone has an idea ?
thx
zicht
Domoticz version: 2023.1+
Post by zicht »
looks like the json/api is changed, but no clue how to correct the script yet
Joep123
Post by Joep123 »
zicht wrote: Tuesday 05 October 2021 20:37 looks like the json/api is changed, but no clue how to correct the script yet
I don't know which script you are using but in my PHP script I had to change:
foreach($traffic['response']['results'] as $street) {
into
foreach($traffic['response'][0]['result'] as $street) {
and
$time = $time + $street['crossTime'];
into
$time = $time + $street['cross_time'];
zicht
Post by zicht »
thank you !
