Traffic with waze in Domoticz
bricololo
Post by bricololo »
Hello, there is a new API for Waze traffic.
https://www.waze.com/row-RoutingManager/routingRequest?
I am looking to get travel time Home - Work with this request.
Actually, I can get an XML file via the request,
(for me, latitude and longitude are reversed)
https://www.waze.com/row-RoutingManager ... LOW_UTURNS
It is possible to have the answer in XML or JSON, modify returnXML=true by returnJSON=true
<summary time = "9264" must be divided by 60 for take the time.
I would like to create a script in shell or python to have the traffic.
This value will be displayed in Domoticz with a JSON request and just put this script in CRON.
There is sources
http://www.domo-blog.fr/info-trajet-waz ... raspberry/
https://plus.google.com/+NicolasFovet/posts/Ei14c24n3hP
https://github.com/Nimrod007/waze-api/b ... /route.php
If anyone can realize the scripts before me it's will be good.
Egregius
Domoticz version: v2024.7
Re: Traffic with waze in Domoticz
Post by Egregius »
Nice idea :)
I wouldn't put in into domoticz do.
Quickly created a page on my site, bookmark it on my phone
http://egregius.be/traffic.php
I'm wondering how much request you may sent to that service :roll:
Offcourse with something like this you could also easily drop in into a text virtual switch.
<?php
header('Content-Type: text/html; charset=UTF-8');
function traffic($startlat, $startlon, $endlat, $endlon) {
	GLOBAL $traffic;
	$traffic=file_get_contents('https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'.$startlon.'+y%3A'.$startlat.'&to=x%3A'.$endlon.'+y%3A'.$endlat.'&at=0&returnJSON=true&timeout=60000&nPaths=1&clientVersion=4.0.0');
	$traffic=json_decode($traffic,true);
	$tijd=0;$lengte=0;
	foreach($traffic['response']['results'] as $street) {
		$tijd = $tijd + $street['crossTime'];
		$lengte = $lengte + $street['length'];
	$tijd = strftime("%k:%M:%S",$tijd);
	$lengte = round($lengte / 1000,0);
	return array('tijd' => $tijd, 'lengte' => $lengte);
$hw = traffic(50.892565,3.114135,50.877122,4.164326);
echo 'Home - Work = '.$hw['tijd'].' / '.$hw['lengte'].'km<br>';
$wh = traffic(50.877122,4.164326,50.892565,3.114135);
echo 'Work - Home = '.$wh['tijd'].' / '.$wh['lengte'].'km<br>';
remb0
Post by remb0 »
Wake is super!! Maybe the output can be written to a virtual text switch.
Egregius
Post by Egregius »
Offcourse. Just add something like this:
<?php
$idx = 153;//IDX of the virtual text switch
file_get_contents('http://ip:port/json.htm?type=command&param=udevice&idx='.$idx.'&nvalue=0&svalue='.$hw['tijd'])
bricololo
Post by bricololo »
It's interesting but I don't use a web server, so no php script.
That's why I'd like a shell script or python.
The hardest for me is to extract the time value of the answer to the request.
Thank for your answer
Egregius
Post by Egregius »
You can use php without webserver;)
bricololo
Post by bricololo »
Yes...
It's works :P
Thanks a lot
Egregius
Post by Egregius »
You're welcome ;)
Add the script to crontab so it runs every 5 minutes or something.
bricololo
Post by bricololo »
I don't understand,
Travel times are increased by an hour.
For a normal time 18min, I get 1 hour 18 min.
For a normal time 1 hour 30 min, I get 2 hour 30 min.
Is possible to decrease an hour.
I tried
$timestamp = mktime($tijd);
$timestamp -= 3600;
$tijd = date($timestamp);
but it's not works
Egregius
Post by Egregius »
Yes, I noticed that also...
Try
$tijd = strftime("%k:%M:%S",$tijd-3600);
strftime uses UTC or DST or something. If it's going to be a problem after wintertime I'll search for another function.
bricololo
Post by bricololo »
Super,
Thanks, I'm not good in php.
remb0
Post by remb0 »
maybe a nice for the wiki. a little tutor how to schedule, run configue and see it in domoticz?
iero
Post by iero »
Hello
I simplified the script in order to get only the time (every 10 minutes) for my trip home -> work
And I populate a "pressure" sensor to get the best timing to leave home (before 8h10 in my case)
Here is the code (quite the same) :
-- Script de calcul de temps pour un trajet entre 2 coordonnées
-- Auteur : Neutrino (updated iero)
-- Date : 7 septembre 2015 (updated 21/09/2015)
-- Nécessite un capteur virtuel de type Pression
-- source :
-- http://www.domo-blog.fr/info-trajet-waze-eedomus-version-raspberry/
commandArray={}
time = os.date("*t")
if((time.min % 10)==0) then
        --import des fontions pour lire le JSON
        json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
        --variables à modifier----------------
        --idx du capteur
        idx = 'XX'
        --coordonnées de départ
        departx="X.XXX"
        departy="X.XXX"
        --coordonnées d'arrivée
        arrivex="X.XXX"
        arrivey="X.XXX"
        --Récupération du trajet et de sa durée en temps réel via WAZE--
        local waze=assert(io.popen('curl "https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'..departx..'+y%3A'..departy..'&to=x%3A'..arrivex..'+y%3A'..arrivey..'&returnJSON=true&timeout=6000&nPaths=1&options=AVOID_TRAILS%3At%2CALLOW_UTURNS"'))
        local trajet = waze:read('*all')
        waze:close()
        local jsonTrajet = json:decode(trajet)
        --Noms des principales routes empruntées
        routeName = jsonTrajet['response']['routeName']
        --Liste des routes empruntées
        route = jsonTrajet['response']['results']
        --calcul du temps de trajet (en secondes)
        routeTotalTimeSec = 0
        for response,results in pairs(route) do
           routeTotalTimeSec = routeTotalTimeSec + results['crossTime']
        --Temps de trajet en minutes
        routeTotalTimeMin = routeTotalTimeSec/60-((routeTotalTimeSec%60)/60)
        --print(routeTotalTimeMin)
        commandArray[1]={['UpdateDevice'] =idx..'|0|' .. tostring(routeTotalTimeMin)}
Next step, I would like to receive an alert if waze see a police control on this trip..
sploutchi
Post by sploutchi »
Hi iero !
I just tried your lua script but i haave this error :
2015-09-28 11:48:10.576 Error: EventSystem: /home/pi/domoticz/scripts/lua/script_time_WAZEFLO.lua:35: attempt to index local 'jsonTrajet' (a nil value)
Any idea ?
My data are :
departx="48.632936"
departy="2.291525"
arrivex="48.796156"
arrivey="2.299969"
Timple
Post by Timple »
iero wrote:Hello
Very nice!
remb0
Post by remb0 »
there is an link to JSON.lua (for the calsulations) you miss that file!
download: http://regex.info/code/JSON.lua
and place it in the right folder.
Whatsek
Domoticz version: Latest B
Post by Whatsek »
I have the same error, I have the JSON.lua from you link, and put in /home/pi/domoticz/scripts/lua/JSON.lua
Do I have to edit something in that file? I couldn`t find anything about "trajet"
Derik
Post by Derik »
pffff I cannot handle all the great options ij Domoticz....[ like that ]
Is there perhaps a clean and working code example for Waze?
Or a Wiki?
salvation
Post by salvation »
Egregius wrote:Yes, I noticed that also...
Try
Thanks for this script Egregius, works great.
I've also tried the LUA variant but it's not working. Get the same message as others. Seems the call to waze is not correct and returns an empty result. But I didn't know how to fix.
Egregius
Post by Egregius »
Once you go PHP you'll never look back to lua :mrgreen:
