domoticz in synology as package! Available now.
- Domoticz version: lastbeta
Today I noticed an new beta release for Synology and installed it.
But, the error message is still there every second:
Error: EventSystem: in /usr/local/domoticz/var/scripts/dzVents/runtime/dzVents.lua: cannot open /usr/local/domoticz/var/scripts/dzVents/runtime/dzVents.lua: No such file or directory
Any idea how to solve this issue?
Disabling dzVents (2.1.0) stopped the error messages.
Synology DS716+. Domotica devices (on about 30): KaKu (and other 433MHz devices), Z-Wave, Mi-Light, Xiaomi.
Then someone must have removed it or didn't include it as it is definitely part of the build.
- Domoticz version: 3.8875
Conclusion from the documentation directory in dzVents, it's still on version 2.0.0. Any reason for that?
- jumbotroll
This is because of backup restore function on the synology packages.
If you reinstall the package, the history will show correct version.
I have No solution to fix this right now, but maybe later
If you check in settings menu it will show 2.2.0
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
@jumbotroll: Thanks again (and again and again) for your great help.
I reinstalled the package and, indeed, now dzVents version 2.2.0 is shown.
But the error messages remain so I still have to disable dzVents ;-(
Is dzVents working for you as expected?
- jumbotroll
@digimate
I don't use dzVents, but I only testet this with the Python version, and that worked last time I tested.
http://www.jadahl.com/domoticz_beta_6.1_python/
Install Python 3.5.1 package from synology before you install this version!
Jumbotroll
Jumbotroll
You should, hahajumbotroll wrote:@digimate
I don't use dzVents, ..
So am I right and is dzVents 2.2.0 not included in the Synology packages you share?
@all
Is there someone who has dzVents 2.2.0 working with his Synology and is willing to share how 'things' were done?
Weird that it cannot find the module. In EventSystem.cpp the lualoader loads dzVents.lua from 'scripts/dzVents/runtime/'. So it looks like the lua loader inside domoticz cannot see that path. Is there some magic done here in the package?
I am having the exact same issue as you with the latest beta Synology build. For now I also disabled dzVents 2.2.0 in the settings to get rid of the error messages. Hope this will be resolved soon, because the sole reason I upgraded was to use dzVents.digimate wrote: @all
- jumbotroll
After careful consideration, I have now made a decision.
I'm just going to update/build stable versions of Domoticz to Synology in the future.
There are often changes to the source code that make the beta versions need to be tested carefully before I can post them, and this requires allot of time I do not have ...
I think that docker or raspberry pi are better suited for beta testing.
Url's for beta versions will eventually be removed from my server, so please follow the update here on the forum or on my website for future url's.
Jumbotroll
Jumbotroll
- EdwinK
- Domoticz version: BETA
Can understand you.
- mvveelen
That's unfortunate Jadahl. Although I understand why you made the decision.
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
Jadahl, many thanks for your hard work over all this time. I join the other forum members in understanding your decision.
Would you just be kind enough to produce a tutorial or guide showing the process of building the packages, or direct us to some of such tutorials if they exist?
I know the one on the wiki but it seems a bit outdated ... DSM5.1... maybe just an update of what changes need to be taken into account for DSM6?
That might engage some of us to follow your great work and keep the momentum via a more collaborative effort.
- jumbotroll
Hi.manutremo wrote: ↑Monday 14 August 2017 18:21 Jadahl, many thanks for your hard work over all this time. I join the other forum members in understanding your decision.
I would like to put out the recipe for how this is done, but I use a combination of the syncommunity framework (spksrc) and some smart solutions
Unfortunately, there is no support for DSM 6.1 in spksrc yet and then a little trouble downloading kernel and toolchains to that framework.
In my building environment, there are kernels and toolchains for all synology NASes that hold about 90-100GB of files.
The building environment on my development machine is a big mess that is not suitable for distrubusion at the moment.
Maybe if I get a lot of time left I create a wiki.
Jumbotroll
Jumbotroll
Tried to install the epic work from Jumbotroll on my Synology DS-412+ today... unfortunatly it stopped before even getting started.
The log states:
https://www.dropbox.com/s/2j4ttcxscpun2eo/Demo.JPG?dl=0
...and since I am not the type who understands or writes code via prompt (need desktop windows) - I have no clue how to move forward.
Running:
DSM: 6.1.3
Python: 2.7.13
In addition - will it actually work with my "Z-Wave USB Stick" or does it demand the Z-Stick from Aeon Labs (ZW090)?
Thank you and kudos for your time and effort!
Cheers from Sweden!
The log states:
Running:
DSM: 6.1.3
Python: 2.7.13
Cheers from Sweden!
- Domoticz version: 4.10538
Install the synology python3 package, that will solve this problem
Thanx for all the work @jumbotroll.
Is dzVents suppose to work on the latest stable release without Python? I'm trying to get it to work but it seems my generated scripts (from the events editor) go into /usr/local/domoticz/var/scripts/dzVents/generated_scripts/ but are never executed.
[EDIT]
Nevermind, it works. There was an error in my script.
[EDIT]
Hi ,
I used Domoticz on Synology DS 216 II + since 10 month.
Since update Synology DSM 6.1.3-15152 Update 3, the driver USB not load directly when DSM restart.
Message : Error, contrlr, ERROR : Dropping command ....... -->in journal application
Solution : Stop application, restart DSM after 5-10 min start application -->all are ok
I update Last stable version is installed after this problem, but is not resolved this problem.
Have you an idea or better on solution for this problem ?
Thx in advanced.
Thx in advanced.
hello
I install domoticz on synology ds416 and i need to work with miio to configure some devices.
The problem is i have this error:
node: /lib/libstdc++.so.6: no version information available (required by node)
someone can upgrade the node.js in synology?
- Domoticz version: 2022.2
will the package for the DS716+II also run on the 718+
i noticed that they vboth have a celeron cpu but one is the N3160 4 core anbd the other is the J3455
thanks
thanks
