I think someone already post a question. I have on new temperature sensor ordered from gearbest, cube shape, with additional pressure sensor. Can someone confirm that he had in domoticz sensor registered or we need to wait for update on code. Problem with android is resolved I can add sensor via Mi Home app.
No, it does not work yet
Verstuurd vanaf mijn SM-G930F met Tapatalk
hum I receive it this day ! One beer for the dev who code that
The problem, as I understand it, is that the values for the new square button and thermometer aren't emitted over the LAN interface.
Looking at a tcpdump, it appears that the values are sent up to Xiaomi cloud, but the encryption keys/method for the cloud channel haven't been found - the protocol there is similar to that described here https://github.com/OpenMiHome/mihome-bi ... ROTOCOL.md
I am using quit some Xiaomi Product by now, I bought them all @ GearBest. The shipping time was okay, german express 7-20 days (also available for other country and EU) and no TAX. They are really affordable with good build quality and design. Also integration via homebridge works like a charm.
theo69 wrote:I am using quit some Xiaomi Product by now, I bought them all @ GearBest. The shipping time was okay, german express 7-20 days (also available for other country and EU) and no TAX. They are really affordable with good build quality and design. Also integration via homebridge works like a charm.
Not working right now are the Zero Line (neutral) Xiaomi Aqara Wall Switches.
i Just installed the Aqara Single Wall Switch Line (LN) 2 days ago - after updating git from corbin's - it works.. i have seen corbin added the code to deal with the LN switch.. (didn't dig into it.. as it seems to work fine)
Did you update beta or did you compiled from corbin?
I have latest version of Aquara temp/hum/bar sensor, cube shape. Can someone take look on this, maybe with this update we can have finally support for new xiaomi sensors.
Used Corbin's .cpp and .h on top of the beta before compiling.
but you can use corbin's git - it should work..
these changes are not yet in the official beta.
@benbammens Done - assuming it works the same as the Xiaomi sensor
@levynger I've just reset the changes for the wall switches in my repo to match the current Domoticz beta, so these new Aqara devices can be added in. I'm waiting on an order of wall switches to arrive so I can test it out fully, unless you could do it? You will see I've changed to using more unitcodes for the different devices.
corbin wrote:@benbammens Done - assuming it works the same as the Xiaomi sensor
