Get dimmer level with LUA
Westcott
Post by Westcott »
How do you GET the level of a dimmer with LUA?
jvdz
Domoticz version: 4.107
Re: Get dimmer level with LUA
Post by jvdz »
otherdevices_svalues['dimmername'] ?
Jos
sisaenkov
Domoticz version: 3.8
Post by sisaenkov »
Hello!
I also want to get dimmer level on LUA from JSON parameter "Level" :.
JSON parameter stores dimmer slider position instead of otherdevices_svalues['dimmername'] that is only shows current percentage when it's turned On.
Now I have to use variables as Level storage. But this is not the best solution (also curl with jq).
madrian
Post by madrian »
sisaenkov wrote:Hello!
Can you share your solution?
I am trying to do the same, but my LUA script hangs. :evil:
viewtopic.php?f=61&t=18375
sisaenkov
Post by sisaenkov »
madrian wrote: Can you share your solution?
Here are necessary code blocks:
(The key strings for you contains "uservariables")
idx = 383
function getname(deviceIDX)
   for i, v in pairs(otherdevices_idx) do
      if v == deviceIDX then
         return i
   return 0
DomDevice = getname(idx)
if devicechanged[DomDevice] then
        if tonumber(otherdevices_svalues[DomDevice]) ~= tonumber(uservariables['Dimmer_' .. idx]:match("(%d+)")) then
                if (devicechanged[DomDevice] == 'Off') then
                        DomValue = 0
                        print (DomDevice ..": Turn Off")
                        datasend()
                elseif (devicechanged[DomDevice] == 'On') then
                        print (DomDevice ..": Turn On without level change")
                        DomValue = (otherdevices_svalues[DomDevice]);
                        print (DomDevice ..": Dimming to " .. (DomValue) .. "%");
                        datasend()
        elseif (tonumber(otherdevices_svalues[DomDevice]) ~= tonumber(uservariables['Dimmer_' .. idx]:match(",(%d+)")) and devicechanged[DomDevice] == 'On') then
                DomValue = tonumber(uservariables['Dimmer_' .. idx]:match(",(%d+)"))
                print (DomDevice ..": Turn On")
                datasend()
