Get dimmer level with LUA
- Westcott
How do you GET the level of a dimmer with LUA?
- jvdz
- Domoticz version: 4.107
Re: Get dimmer level with LUA
otherdevices_svalues['dimmername'] ?
Jos
Jos
- sisaenkov
- Domoticz version: 3.8
Hello!
I also want to get dimmer level on LUA from JSON parameter "Level" :.
JSON parameter stores dimmer slider position instead of otherdevices_svalues['dimmername'] that is only shows current percentage when it's turned On.
Now I have to use variables as Level storage. But this is not the best solution (also curl with jq).
Hi,sisaenkov wrote:Hello!
Can you share your solution?
I am trying to do the same, but my LUA script hangs.
viewtopic.php?f=61&t=18375
- sisaenkov
Here are necessary code blocks:madrian wrote: Can you share your solution?
(The key strings for you contains "uservariables")
idx = 383
function getname(deviceIDX)
for i, v in pairs(otherdevices_idx) do
if v == deviceIDX then
return i
return 0
DomDevice = getname(idx)
if devicechanged[DomDevice] then
if tonumber(otherdevices_svalues[DomDevice]) ~= tonumber(uservariables['Dimmer_' .. idx]:match("(%d+)")) then
if (devicechanged[DomDevice] == 'Off') then
DomValue = 0
print (DomDevice ..": Turn Off")
datasend()
elseif (devicechanged[DomDevice] == 'On') then
print (DomDevice ..": Turn On without level change")
DomValue = (otherdevices_svalues[DomDevice]);
print (DomDevice ..": Dimming to " .. (DomValue) .. "%");
datasend()
elseif (tonumber(otherdevices_svalues[DomDevice]) ~= tonumber(uservariables['Dimmer_' .. idx]:match(",(%d+)")) and devicechanged[DomDevice] == 'On') then
DomValue = tonumber(uservariables['Dimmer_' .. idx]:match(",(%d+)"))
print (DomDevice ..": Turn On")
datasend()
