MQTT integration
pepijn
Re: MQTT integration
Did you know GPIO is supported native by Domoticz?
Yes, I see that but my relays are on a separate Pi.
By the way, is there a way to invert the state of the ON/OFF GPIO?
Because my relay board turns ON the relays when the GPIO is 0, so the Domoticz act contrariwise (the switches are all OFF but the relays are all ON).
- nayr
- Domoticz version: github
Domoticz supports a Master/Slave configuration so you can hook multiple Domo's together and have remote nodes.
and for inverting gpio, try: echo 1> /sys/class/gpio/gpioN/active_low
Thanks Nayr, the inversion of the GPIO works!!!
Derik
- Domoticz version: BETA
mmm
What can i do more with MQTT
I did make a MQTT broker with mysensors...
Only i do not understand what i can do with MQTT
What are the settings : And what are the best/beautiful options that in can make, with this...
And it is always so simple
what can i do with MQTT and Node red??
salvacalatayud
I'm new in all this domoticz things. What I want to know is how to translate the domoticz mqtt in order to manage a modbus plc. What I want is to integrate a plc into domoticz via node red.
salopette
Hello, I have a question if someone can help me?
Please excuse me for my English, I use Google Translate.
How can I connect this sketch with domoticz and controll?
https://github.com/thexperiments/esp826 ... tt_gateway
Thank you!
Thank you!
salopette
Can someone tell me
How can I control this in Domoticz?
Default topic is /ZB40_GATEWAY. You can controll it via MQTT with the following topics.
Topic Payload (only one at a time)
/ZB40_GATEWAY/ALL/ up, down, stop
/ZB40_GATEWAY/1/ up, down, stop
/ZB40_GATEWAY/2/ up, down, stop
/ZB40_GATEWAY/3/ up, down, stop
SweetPants
If you have a (mosquitto) MQTT broker installed and working, you can create dummy switches and send commands using mosquitto_pubsalopette wrote: Tuesday 17 October 2017 22:50 Can someone tell me
SweetPants
Domoticz has two topics domoticz/in and domoticz/out. Please take a look at https://www.domoticz.com/wiki/MQTT for different JSON formats to send/receive
salopette
Hello, I have looked here https://www.domoticz.com/wiki/MQTT, but I do not understand how I have to adjust in the sketch?
I now create a Virtuall switch, when I enter the command via browser, I see everything.
But how do I go on?
my MQTT is on 192.168.178.37/ port 1883
http://192.168.178.37:8080/json.htm?typ ... es&rid=266
But how do I go on?
ActTime: 1508492733,
ServerTime: "2017-10-20 11:45:33",
Sunrise: "07:56",
Sunset: "18:14",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "Open",
Description: "",
Favorite: 0,
HardwareID: 7,
HardwareName: "Virtual",
HardwareType: "Dummy (Does nothing, use for virtual switches only)",
HardwareTypeVal: 15,
HaveDimmer: true,
HaveGroupCmd: true,
HaveTimeout: false,
Image: "Light",
IsSubDevice: false,
LastUpdate: "2017-10-20 08:47:18",
Level: 0,
LevelInt: 0,
MaxDimLevel: 100,
Notifications: "false",
PlanID: "0",
PlanIDs: [],
Protected: false,
ShowNotifications: true,
SignalLevel: "-",
Status: "Open",
StrParam1: "",
StrParam2: "",
SubType: "Switch",
SwitchType: "Venetian Blinds EU",
SwitchTypeVal: 15,
Timers: "false",
Type: "Light/Switch",
TypeImg: "blinds",
Unit: 1,
Used: 1,
UsedByCamera: false,
XOffset: "0",
YOffset: "0",
idx: "266"
status: "OK",
title: "Devices"
Wijnand
MQTT/JSON integration
Hello guys,
I am playing with Domoticz now for a few days. My biggest problems with Domoticz and MQTT are the way they are using topics and JSON.
1. Domoticz impose the topics domoticz/in and domoticz/out. Why? It gives you not the freedom affined the MQTT standard. Keep the subscripe and publish topics open ( e.i ALF4all/domoticz and/or ALF4all/domoticz/${floorplan name}/${plan name} ), so you are not overwhelmed with messages if you are using a public MQTT-broker (like HiveMQ).
2. JSON is designed to keep messages readable. An object in Domoticz like "idx":1 (device index) is clear, objects as "nvalue" and "svalue" says nothing. Why not using objects as "temperature" and "humidity"? An object as "svalue":"20.5; 33.3; 2" for a Temp + Humidity type sensor is not readable at all. Better in JSON documents is to split up the data in seperate objects like: {"temperature":"20.5", "humidity":"33.3","humidity-status":"2"}.
Even better: {"temperature":"20.5", "humidity":"33.3","humidity-status":"dry"}.
Perhaps it would be nice if this way is also implemented (not diffecult I think) in Domoticz.
Regards...
Wijnand
b.t.w. As device hardware/firmware I use ESP8266 (thing) -> Arduino IDE -> ArduinoJson.h -> PubSubClient.h -> MQTT -> Domoticz.
Regards...
Wijnand
Users browsing this forum: jvdz and 1 guest
