[ DomoDash ] a Angular tablet/mobile dashboard *Updated
dycati
Post by dycati »
Dear users, after experiencing the amazing Dashticz v2 tool, I wanted to make my own version of dashticz but without the drawbacks of Jquery
so I came to the conclussion that I had a great example to start developing...
Now if you guys are interested the first version is downloadable from github
https://github.com/danielalmering/DomoDash/tree/master
Lastest UPDATES
- Added Garbage collector
- Added Sabnzb
- Added TV guide (tvgids.nl)
- Added internal/external ip support
- Added Save settings notification
- Made working Tooltip with information
Currently supporting
- Light switches
- Dimmers
- Weather ( Wunderground )
- Spotify
- News ( RSS reader )
- Traffic ( Anwb )
- Device mapper
- Google Calendar
- Tv guide (Tvgids.nl)
- Sabnzb
- Garbage collector (recyclemanager, mijnafvalwijzer)
- Cors PHP proxy ( cors.php?url=***** )
Installation
Before you start be sure that your webserver is running PHP! otherwise you cannot save the settings, you can only download them manualy
( Read install instructions below )
Windows based system
- step 1: Download the repo with following https://github.com//danielalmering/Domo ... master.zip
- step 2: Extract all files with program like winzip/7zip
- step 3: Open winSCP and connect to your desired webserver
- step 4: Select the extracted files and place them on the webserver
- step 5: Rename the config-default.json to config.json and give it write access (if subdirectory then that as well)
( continue to step 6 )
Linux based system
- step 1: Git clone https://github.com/danielalmering/DomoDash.git
- step 2: Move folder to webserver directory
- step 3: Rm config-default.json to config.json
- step 4: Chmod 777 config.json (if subdirectory then that as well)
- step 6: Open the application and fill in your settings like the example listed below!
https://raw.githubusercontent.com/danie ... ttings.png
- step 7: If you have PHP installed just hit the Save Changes button or if you dont have it installed just download it manualy with the Download Manualy button and upload the config.json to the root of the application
( if you experiencing that you hitting the save button but nothing happens it is probably your browser cache by cleaning it would show the correct saved settings )
Settings (example)
Coming features
- News Modal(iframe)
Missing features?
If there are features that are a must for your Domoticz environment please let me know!?
pvdhelm
Re: [ DomoDash ] a Angular tablet/mobile dashboard
Post by pvdhelm »
how to open the app
1. copied all the files to my webserver.
2. http://[url of webserver]
nothing happens
remb0
Post by remb0 »
very nice. a settings page is indeed very handy.
some ideas:
- updater from website (no need to ssh for a git pull)
- a domoticz device mapper? that it another name can select a domoticz device and give it another name for in the dashboard.
- tv gids.
dycati
Post by dycati »
remb0 wrote:very nice. a settings page is indeed very handy.
some ideas:
- tv gids.
I wil look into that device mapper seems legit!, and what kinda tv gids do you prefer?
Device mapper is added to the featurelist!!
dycati
Post by dycati »
Been busy making the widgets take less space.....
kniazio
Domoticz version: 3.7243
Post by kniazio »
pvdhelm wrote:how to open the app
nothing happens
I have the same
empty page
dressie
Domoticz version: V2020.2
Post by dressie »
nothing happens
I have the same
empty page
Same here.
dycati
Post by dycati »
Sorry guys, I made a mistake i didn't test the software without a proper config file. I have updated the master if you could redownload and try again it would be appreciated :o
kniazio
Post by kniazio »
Still the same
blindlight
Post by blindlight »
still the same
failed to load app.js and app.css
pvdhelm
Post by pvdhelm »
still a white page
dycati
Post by dycati »
Are you openening the app on a properly configured webserver with apache, because the app wont work just running on your
desktop without it ?
kniazio
Post by kniazio »
Man.
I'm trying to run it on two Apache servers.
One on Synology, the other on Raspberry Raspbian
Without result
dycati
Post by dycati »
I have update the directories and now it works on my default Domoticz(webserver), cant speak for the PHP because domoticz by default cant process PHP :cry:
kniazio
Post by kniazio »
The configuration page is displayed but nothing else
Does not save settings
I manually changed the IP: My Domoticz port, but I do not see any of my devices
The name of the config-default.json file has also changed to config.json
I changed the config.json file to 777 chmod
dycati
Post by dycati »
I could be that when you saved it would display the old config.json because of your cache, turning it off would do the trick. I Did a update so when you save the settings page you dont have to refresh it just rerenders the blocks/colums automatic!
If there are volunteers to share there teamviewer with me i would take a look to see what goes wrong? just pm me...
PS, If the console of your browser returns a "501 Not Implemented" it means it doenst support PHP
kniazio
Post by kniazio »
still the same
dycati
Post by dycati »
Kniazio can you please show me your console/network output when you save you settings page?
kniazio
Post by kniazio »
Please
I am typing IP of my Domoticz (192.168.1.100:8078)
I press Save
I have it:
So nothing.
dycati
Post by dycati »
Dear kniazio, I tested it on 2 machines with correct write access(777) and PHP running it should work.
After saving settingspage clear cache and refresh page. If you still have problems just pm your teamviewer login so i can help your setup correctly.
You can try and test it on your desktop by downloading USBWebserver and running the folder with that
http://www.usbwebserver.net/nl/
