Foscam FI9903P issue.
Freddy315pk
Domoticz version: V3.5010
Post by Freddy315pk »
I have a strange problem with a Foscam FI9903P ip camera and I am hoping someone here can help.
I can configure it and I get a picture with "Test Connection" button:
Foscam edit camera.jpg (91.75 KiB) Viewed 2808 times
But, there is no preview:
Foscam overzicht camera.jpg (153.64 KiB) Viewed 2808 times
If I click on the webcam icon, there is also no image:
Foscam voordeur camera.jpg (34.64 KiB) Viewed 2808 times
My other camera, a Foscam FI9818W V2, connected on the same lan-switch, does work.
Does anyone here have any idea what can possible be wrong?
The "voordeur" camera is linked to my kaku doorbell and is supposed to send a picture when pressed.
But because, I think, since there is no image, no picture is sent.
If I login to the camera through a web browser, everything is also fine.
Raspberry Pi 3b - RFXCOM-E RFY - Foscam FI9818W V2 - Foscam FI9903P - ThermoSmart - P1 USB Smartmeter - Bunch of CoCo - Onkyo TX-NR525 - Kodi NUC
oliviers
Domoticz version: Stable
Re: Foscam FI9903P issue.
Post by oliviers »
Just to say that I have exactly the same problem with a FOSCAM FI8910W.
This is not the solution to your issue, but at least, you're not alone....
Oliviers
Paris area
Raspberry Pi 4 - RFXComm 433 - IrTrans - Zwave
RutgerBo
Domoticz version: V2.3530
Post by RutgerBo »
I've a FI9903EP, and the stream is working fine, only the preview is taken from the other cam I have added first (Dericam m601w, a Foscam dome clone (640x480). But the image button is working.
Besided the username and password in the url, it's only working for me when I add both username and password in the desired fields too.
Freddy315pk
After some "tinkering" I got my camera working again.
When I updated to the latest beta version, my camera is working again. Tried to go back to the latest stable version, problem came back.
So I assume there is a bug in the latest stable version, latest beta version is working fine (3.5010).
marmachine
Domoticz version: 3.4834
Post by marmachine »
Hi Freddy,
Did you also setup motion for your cam? (using your camera as motion sensor?)
I'm kinda stuck with that, however i have my camera FOSCAM FI9900P added to Domoticz.
nigels0
Domoticz version: 3.8153
Post by nigels0 »
Late response - sorry, but the problem is the firmware. The call is returning the HTML response, not the image. Foscam knew about this and fixed it in the firmware - relatively recently.
