Dashticz - Function - RGB-support
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Now it is possible to control your hue RGB-lamps..
I've found out that Domoticz doesnt return the current value so I save the last picked color to a cookie.
Try it out and please let me know if this works...
Onrust
Domoticz version: 4.10717
Re: Dashticz - [BETA]Function - RGB-support
Post by Onrust »
Doesn't work here. I can select a color from the new selector, but nothing happens when I select Choose.
robgeerts
Post by robgeerts »
It should change when you click a color...
What kind of RGB-device do you have?
Onrust
Post by Onrust »
robgeerts wrote: What kind of RGB-device do you have?
Hue color/RGB lights.
robgeerts
Post by robgeerts »
Strange, I'm using it to.
Shall I try to fix it via Teamviewer?
PM me your ID and password...
Teunissm
Domoticz version: V3.5858
Post by Teunissm »
tried it also over here but i can't change color as well
I use: Lighting Limitless/Applamp RGBW
Onrust
Post by Onrust »
PM sent
robgeerts
Post by robgeerts »
Could you try latest BETA @Teunissm?
Edit: 22:55 Small fix again ;)
Teunissm
Post by Teunissm »
robgeerts wrote:Could you try latest BETA @Teunissm?
It still doesn't work.
With the first release de color indicator changed tot the color i choose but the lamp didn't react.
With the latest beta the color indicator don't even change??
robgeerts
Post by robgeerts »
Do you get any error in console?
The fix I just did is working for @Onrust...
Onrust
Post by Onrust »
robgeerts wrote: The fix I just did is working for @Onrust...
And I confirm it works for my other Hue's as well.
Teunissm
Post by Teunissm »
I don't see any errors in yhe console when switching the rgb light. I only have another rgb device as you use. I use Milight?
robgeerts
Post by robgeerts »
Ah that could be the problem. Maybe I can have a Teamviewer session with you tomorrow?
Teunissm
Post by Teunissm »
the i should instal teamviewer first ;-)
DONE
Update: So strange, everything works fine suddenly???
Thanx Rob
htilburgs
Post by htilburgs »
Hi Rob, I'm using Yeelight (Wifi), but trying to change the color the lamp turns to white.
Probably because Yeelight is not implemented.
Hardware:
robgeerts
Post by robgeerts »
I assume its working correctly in Domoticz? It could be this type of lamp needs another call... maybe we can debug it via Teamviewer tonight?
EdwinK
Post by EdwinK »
robgeerts wrote:BETA
In latest beta it is possible to control your hue RGB-lamps..
How exactly do I try this ;)
robgeerts
Post by robgeerts »
Adding a hue lamp to your dashboard?
EdwinK
Post by EdwinK »
ah.. I thought adding some sort of block thing or so :)
EdwinK
Post by EdwinK »
Screen Shot 2017-07-13 at 16.25.20.png (69.9 KiB) Viewed 4183 times
Although the lights do change to different colours, the icon only shows one colour for both devices
