Dashticz - Module - Spotify (new version!)
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Now can add a Spotify block.
Before you can use it, create an app on the spotify website:
https://developer.spotify.com/my-applic ... ons/create
Title: Dashticz
Description: whatever ;)
On the next page, copy "Client ID" to your CONFIG.js like:
config['spot_clientid'] = '1112f16564cf4f4dsd4cbe8b52c58a44';
At the same page, enter your dashticz-url in the Redirect URIs field, for example:'
http://192.168.1.3:8080/
DONT FORGET TO PUSH THE SAVE BUTTON!!
In CONFIG.js, add the block like:
columns[2] = {}
columns[2]['blocks'] = ['spotify']
columns[2]['width'] = 5;
Currently you can only change playlist, but more functions are coming!
vgr2
Re: Dashticz - Module - Spotify
Post by vgr2 »
Receiving: INVALID_CLIENT: Invalid redirect UR
Jonb
Domoticz version: 3.5877
Post by Jonb »
I’m back.
@Rob: Yes! Nice! Lets test tonight :mrgreen:
robgeerts
Post by robgeerts »
Did you enter the dashticz url into your spotify account in the app settings??
vgr2
Post by vgr2 »
Yes, as written...
robgeerts
Post by robgeerts »
Just to be sure, you didnt accidentally use the api key as I typed in the first post?
vgr2
Post by vgr2 »
Working with http://192.168.xxx.xx:8080/dashboard/ as redirect UR.
But after that i can only see 'Select playlist' button, nothing more. And yes I have a playlist.....
remb0
Post by remb0 »
INVALID_CLIENT: Invalid redirect URI
tried also my domain (external url)
vgr2
Post by vgr2 »
did you save it on the developer spotify page? Without saving I had the same problem..
robgeerts
Post by robgeerts »
Vgr2: Dont you see a popup when you click on 'Select playlist'?
vgr2
Post by vgr2 »
I mean, empty playlist
EdwinK
Post by EdwinK »
remb0 wrote:INVALID_CLIENT: Invalid redirect URI
Same here. Triple checked to see if the API key was inserted correctly
robgeerts
Post by robgeerts »
Ok, I'll get back to the drawing table ;) will try to fix it tomorrow!
robgeerts
Post by robgeerts »
Well, I just tested it.
I tried to call the dashboard by localhost and 192.168.1.119 and both worked when entering the address to the spotify app page:
First time it didnt work till I found out I forgot to press the save button ;)
AND make sure you enter the Client ID in CONFIG.JS, and NOT (!) the Client Secret
vgr2
Post by vgr2 »
Hi Rob, whats about my empty playlist? Saw some same issues in google.
capman
Post by capman »
INVALID_CLIENT: Invalid redirect URL
I have the same problem. Try this. Select the redirect url with your mouse (example: http://192.168.178.29/keuken/) Then click with your right mouse key on it and choose option "open link in new tab'. Now spotify ask you if you give permission to open this link. Click OK button. Solved !
robgeerts
Post by robgeerts »
vgr2 wrote:Hi Rob, whats about my empty playlist? Saw some same issues in google.
Good question, maybe we can solve this via Teamviewer? PM me..
robgeerts
Post by robgeerts »
Thanks to vgr2 I just pushed a fix in latest BETA!
EdwinK
Post by EdwinK »
All of a sudden it seems to work
Screen Shot 2017-07-11 at 21.24.45.png (37.62 KiB) Viewed 18096 times
vgr2
Post by vgr2 »
Rob, now I have to loging to Spotify parallel, otherwise it will not work.
