Python plugin: UPS Monitor
Logread
Post by Logread »
Another python plugin that I wrote that I am releasing in case anyone finds it useful.
It exposes via Domoticz devices a number of status variables reported by compatible UPS (Uninterruptible Power Supply) units via a NUT (Network UPS Tools) server running on the same local network as the Domoticz system. An example could be a UPS compatible with a Synology NAS and connected to it with UPS management enabled on the Synology NAS (this is my personal setup: a EATON Ellipse PRO 650 UPS connected to a Synology NAS via USB, with the UPS driving a router, a wifi A/P, the NAS and a Raspberry hosting domoticz).
The plugin is written so as to avoid the need to install any client side software or "packet" such as the NUT Client. It fetches the UPS data directly from the NUT Server via a telnet session, updated every minute (hence any change in the UPS status such as switching to backup power may take up to one minute to be reflected. This is a compromise setting to avoid undue network traffic)
This plugin allows the monitoring/logging of the following UPS variables:
  • "ups.status": displayed as alert device "UPS Status" - the status of the UPS (Green = On Line, Red = Backup power)
    "battery.charge": displayed as device "UPS Charge" - the % charge of the UPS battery
    "battery.runtime": displayed as device "UPS Backup Time" - estimated time on backup power before the UPS dies
    "input.voltage": displayed as device "UPS DC Input" - the voltage of the DC mains input
    "ups.load": displayed as "UPS Load" - the load output in % of max power of the UPS
    "ups.realpower": displayed as "UPS Power" - effective power in watts of the UPS load
    "input.frequency": displayed as device "UPS DC Frequency" - the frequency of the DC mains input
Only the "UPS Status" device is always created by the plugin, others are created if the specific UPS reports the variable. Here is a screenshot with all these devices:
If you want to know more and for installation instructions, see the wiki at https://www.domoticz.com/wiki/Plugins/NUT_UPS.html
remb0
Re: Python plugin: UPS Monitor
Post by remb0 »
great work!!!
marco.bag
Post by marco.bag »
Brilliant, thank you so much!
Logread
Post by Logread »
Thanks for the positive feedback.
I pulled a new version 0.1.1 to GitHub to fix:
  • a bug in the code in the event a specific variable is not published by the UPS that caused a python error, and
    two incorrect device labels (AC v.s. DC...)
marco.bag
Post by marco.bag »
Unfortunately if I git-pull the new version the domoticz server do not start at all...
Any clue to solve that?
G3rard
Domoticz version: No
Post by G3rard »
@Logread, thanks for this plugin!
I have installed it on Domoticz v3.8025 on Ubuntu Server.
The UPS is running on my Synology NAS, I have enabled Network UPS and added the IP address of the Ubuntu server.
When starting the plugin I get the following errors in the log
2017-07-04 23:32:35.650 (UPS) Initialized version 0.1.1, author 'logread'
2017-07-04 23:32:35.651 (UPS) Debug log level set to: 'true'.
2017-07-04 23:32:35.651 (UPS) 'Name':'UPS'
2017-07-04 23:32:35.651 (UPS) 'Mode1':'UPS on Synology'
2017-07-04 23:32:35.651 (UPS) 'HardwareID':'18'
2017-07-04 23:32:35.651 (UPS) 'Author':'logread'
2017-07-04 23:32:35.651 (UPS) 'Port':'3493'
2017-07-04 23:32:35.651 (UPS) 'Key':'NUT_UPS'
2017-07-04 23:32:35.651 (UPS) 'HomeFolder':'/home/gerard/domoticz/plugins/nut-ups/'
2017-07-04 23:32:35.651 (UPS) 'Mode6':'Debug'
2017-07-04 23:32:35.651 (UPS) 'Address':'192.168.1.102'
2017-07-04 23:32:35.651 (UPS) 'Version':'0.1.1'
2017-07-04 23:32:35.651 (UPS) Device count: 1
2017-07-04 23:32:35.651 (UPS) Device: 1 - ID: 63, Name: 'UPS - UPS Status Mode', nValue: 0, sValue: ''
2017-07-04 23:32:35.651 (UPS) Device ID: '63'
2017-07-04 23:32:35.651 (UPS) Device Name: 'UPS - UPS Status Mode'
2017-07-04 23:32:35.651 (UPS) Device nValue: 0
2017-07-04 23:32:35.651 (UPS) Device sValue: ''
2017-07-04 23:32:35.651 (UPS) Device LastLevel: 0
2017-07-04 23:32:45.176 (UPS) Calling message handler 'onHeartbeat'.
2017-07-04 23:32:45.181 Error: (UPS) Error reading UPS variables: BEGIN LIST VAR UPS
2017-07-04 23:32:45.182 (UPS) Variable UPS AC Frequency = None
2017-07-04 23:32:45.182 (UPS) Variable UPS Charge = None
2017-07-04 23:32:45.182 (UPS) Variable UPS Backup Time = None
2017-07-04 23:32:45.182 (UPS) Variable UPS Status = 0
2017-07-04 23:32:45.182 Error: (UPS) 'onHeartbeat' failed 'TypeError':'argument of type 'int' is not iterable'.
2017-07-04 23:32:45.182 Error: (UPS) ----> Line 143 in /home/gerard/domoticz/plugins/nut-ups/plugin.py, function onHeartbeat
2017-07-04 23:32:45.182 Error: (UPS) ----> Line 99 in /home/gerard/domoticz/plugins/nut-ups/plugin.py, function onHeartbeat
2017-07-04 23:32:45.182 Error: (UPS) ----> Line 111 in /home/gerard/domoticz/plugins/nut-ups/plugin.py, function UpdateDevice
2017-07-04 23:32:55.156 (UPS) Calling message handler 'onHeartbeat'.
2017-07-04 23:33:05.180 (UPS) Calling message handler 'onHeartbeat'.
2017-07-04 23:33:15.160 (UPS) Calling message handler 'onHeartbeat'.
2017-07-04 23:33:25.188 (UPS) Calling message handler 'onHeartbeat'.
2017-07-04 23:33:35.165 (UPS) Calling message handler 'onHeartbeat'.
2017-07-04 23:33:45.200 (UPS) Calling message handler 'onHeartbeat'.
2017-07-04 23:33:45.201 Error: (UPS) Error reading UPS variables: BEGIN LIST VAR UPS
2017-07-04 23:33:45.202 (UPS) Variable UPS AC Frequency = None
2017-07-04 23:33:45.202 (UPS) Variable UPS Charge = None
2017-07-04 23:33:45.202 (UPS) Variable UPS Backup Time = None
2017-07-04 23:33:45.202 (UPS) Variable UPS Status = 0
2017-07-04 23:33:45.202 Error: (UPS) 'onHeartbeat' failed 'TypeError':'argument of type 'int' is not iterable'.
2017-07-04 23:33:45.202 Error: (UPS) ----> Line 143 in /home/gerard/domoticz/plugins/nut-ups/plugin.py, function onHeartbeat
2017-07-04 23:33:45.202 Error: (UPS) ----> Line 99 in /home/gerard/domoticz/plugins/nut-ups/plugin.py, function onHeartbeat
2017-07-04 23:33:45.202 Error: (UPS) ----> Line 111 in /home/gerard/domoticz/plugins/nut-ups/plugin.py, function UpdateDevice
2017-07-04 23:33:55.180 (UPS) Calling message handler 'onHeartbeat'.
The upsc tool command line utility is running fine from a shell session on the Ubuntu server:
upsc [email protected]
Init SSL without certificate database
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 50
battery.date: not set
battery.mfr.date: 2015/01/28
battery.runtime: 1440
battery.runtime.low: 120
battery.type: PbAc
battery.voltage: 13.5
battery.voltage.nominal: 12.0
Any ideas how this can be fixed?
Edit: fixed it by renaming the field UPS NUT name from "UPS Synology" to "ups". Apparently that field cannot contain spaces.
It's now working!
Not using Domoticz anymore
Logread
Post by Logread »
marco.bag wrote:Unfortunately if I git-pull the new version the domoticz server do not start at all...
What version of domoticz ? I am facing issues with the latest beta builds since a few days that broke some device handling capabilities... for instance beta 3.8035 requires a (minor) rewrite of most of my plugins. I have not yet pulled these on Github pending testing and reading from the python plugin framework developers if they can help in understanding this issue. Will advise ASAP
marco.bag
Post by marco.bag »
I'm running 3.8025
Very strange, you basically modified a couple of lines and the old version is working, the new one not... since i run it under ESXI i'll do more tests and i'll let you know :)
nmaster
Domoticz version: 3.6304
Post by nmaster »
Hi Logread,
I'm trying your UPS plugin on my domoticz v3.8070.
3 remote UPS and for now it's working fine.
Thank you for his nice work.
Logread
Post by Logread »
nmaster wrote:Hi Logread,
Thanks for reporting and for your appreciation !
Logread
Post by Logread »
nmaster
Post by nmaster »
Hi Logread,
I have one of my ups that isn't accessible all the time because it's a desktop computer.
When this computer is off, ups can't be reached, so error comes while plugin tries to connect to it.
In this case the UPS status remain green (Online).
An idea of improvement would be to update the UPS Status sensor in this case to grey color (Not avaliable).
Apart from this, the plugin works nicely on 2 domoticz (me and a friend).
Logread
Post by Logread »
Should be easy to implement... when I find the time I'll look into this (busy on vacations right now :lol: )
nmaster
Post by nmaster »
OK,
good vacations to you ;-)
videodrome
Post by videodrome »
Thanx Logread, very good job!
2 questions: i have only 5 switch (status, charge, backup time, Laad, input), why?
In blockly i added a new event:
if "UPS status mode"= "Backup Power" (as user variables)
then send message....
but this seems doesn't work.
Logread
Post by Logread »
videodrome wrote: Thursday 24 August 2017 10:18 Thanx Logread, very good job!
Thanks. I am not familiar with blockly but did you make this script a "device" event ? And I am confused with the reference you are making to user variables... hopefuly someone with blockly knowledge can help ?
Logread
Post by Logread »
videodrome wrote: Thursday 24 August 2017 10:18 i have only 5 switch (status, charge, backup time, Laad, input), why?
Sorry, missed your other question. The devices created by the plugin depend on the NUT variables reported by your specific UPS hardware.
TiXav
Post by TiXav »
I have installed this plugin for 3 days, but I must deactivated it because domoticz crashs.
I put the plugin in debug mode
2017-08-28 18:55:38.510  (MyUps) Calling message handler 'onHeartbeat'.
2017-08-28 18:55:38.560  (MyUps) Variable UPS Power = None
2017-08-28 18:55:38.560  (MyUps) Variable UPS Charge = 100
2017-08-28 18:55:38.560  (MyUps - UPS Charge) Updating device from 0:'100' to have values 0:'100'.
2017-08-28 18:55:38.564  (MyUps) Variable UPS AC Input = 236.0
2017-08-28 18:55:38.564  (MyUps - UPS AC Input) Updating device from 0:'236.0' to have values 0:'236.0'.
2017-08-28 18:55:38.568  (MyUps) Variable UPS Status = OL
2017-08-28 18:55:38.568  (MyUps) Variable UPS AC Frequency = None
2017-08-28 18:55:38.568  (MyUps) Variable UPS Load = 8
2017-08-28 18:55:38.568  (MyUps - UPS Load) Updating device from 0:'8' to have values 0:'8'.
2017-08-28 18:55:38.577  (MyUps) Variable UPS Backup Time = 450
2017-08-28 18:55:38.577  (MyUps - UPS Backup Time) Updating device from 0:'450' to have values 0:'450'.
2017-08-28 18:55:38.732  Error: Domoticz received fatal signal 11 !...
2017-08-28 18:55:38.743  Error:   /home/pi/domoticz/domoticz() [0x22c6f8]
2017-08-28 18:55:38.743  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x22c7b0]
2017-08-28 18:55:38.743  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0)
2017-08-28 18:57:55.000  RxQueue: queue worker started...
2017-08-28 18:57:55.477  Incoming connection from: 192.168.1.4
2017-08-28 18:57:57.000  Hardware Monitor: Started
2017-08-28 18:57:57.016  WOL: Started
2017-08-28 18:57:57.017  (MyUps) Started.
Again below
2017-08-24 15:55:19.197  Error: Domoticz received fatal signal 11 while backtracing !...
2017-08-24 15:55:19.197  Error: Domoticz received fatal signal 11 !...
2017-08-24 15:55:19.200  Error:   /home/pi/domoticz/domoticz() [0x22c6f8]
2017-08-24 15:55:19.200  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x22c7b0]
2017-08-24 15:55:19.201  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76cd1180]
Before crashes, all devices are well updated by the plugin for 1h or 3h or 6h (max) then suddenly it crash.
Very strange and pity because before I used a personnal python script connected to Nut with PyNUTClient which upated dummy devices
Best Regards
Logread
Post by Logread »
TiXav wrote: Monday 28 August 2017 19:27 I have installed this plugin for 3 days, but I must deactivated it because domoticz crashs.
There are apparently some issues with python plugins in recent beta versions of domoticz (python plugins have even been deactivated in latest betas since a couple of days, pending a fix possibly). Which version are you using ?
TiXav
Post by TiXav »
Ok, understood, you are right I saw some thing about that but I did not make the link in mind. I run 3.8364.
So I look forward a patch patiently
Thank you
