Hydroquebec plugins (Python script)
Here is Quebec, all our electricity comes from Hydro-Québec. Someone made a plugins to access our consumption and other stats. Would I be able to run that in Domoticz?
https://pypi.python.org/pypi/pyhydroquebec/1.1.0
Tried the wiki but it seems the plugin would need to be a single file, I got a whole directory.
- Dnpwwo
Re: Hydroquebec plugins (Python script)
@godinperson,
Domotiz does not require everything to be in one file it, just requires that a plugin.py files exists and that by importing that file the required API callbacks are defined. That file can import as many other files as you want.
Would you be willing to help me test that?
I'm not that good with coding!
bump!
Anyone? Pretty sure it will take couple of minutes to someone who knows how it works.
No programmer that wants to help, probably a 10 min. job.
Anyone from Quebec that would need that plugin?
Me too will be interested to get it working!
I might have found someone. Checking with him!
Sounds good, let us known !godinperson wrote:I might have found someone. Checking with him!
Hello people,
I have created something as an external script that communicate with Domoticz server. Is not a plugin as intended as I did not know how to do it.
It can be programmed with a CRON job or from Domoticz on your need. I use it as my internet connection is not 24h up, I activate the scipt only on the first time the internet connection is available.
It save to the current day the value of previous day. Is the only limitation I have with it.
https://github.com/jingl3s/domoticz_hydroquebec
Hey Zorbac
I'm trying to get it working, where is supposed to be the folder "pyhydroquebec"
When I ran it I get couple error !
pi@DomoticzTest:~/domoticz_hydroquebec$ ./hydroquebec.py
2017-11-24 18:05:45,551- ERROR-main-Erreur d'execution
File "./hydroquebec.py", line 198, in main
consommation_veille = _get_hydroquebec_valeur_veille(json_configuration['HYDROQUEBEC'])
File "./hydroquebec.py", line 39, in _get_hydroquebec_valeur_veille
output = subprocess.check_output(cmd_hydro)
File "/usr/lib/python3.5/subprocess.py", line 626, in check_output
**kwargs).stdout
File "/usr/lib/python3.5/subprocess.py", line 693, in run
with Popen(*popenargs, **kwargs) as process:
File "/usr/lib/python3.5/subprocess.py", line 947, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.5/subprocess.py", line 1551, in _execute_child
raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] No such file or directory: 'pyhydroquebec'
Users browsing this forum: boum and 1 guest
