Hydroquebec plugins (Python script)
godinperson
Post by godinperson »
Here is Quebec, all our electricity comes from Hydro-Québec. Someone made a plugins to access our consumption and other stats. Would I be able to run that in Domoticz?
https://pypi.python.org/pypi/pyhydroquebec/1.1.0
Tried the wiki but it seems the plugin would need to be a single file, I got a whole directory.
Dnpwwo
Re: Hydroquebec plugins (Python script)
Post by Dnpwwo »
@godinperson,
Domotiz does not require everything to be in one file it, just requires that a plugin.py files exists and that by importing that file the required API callbacks are defined. That file can import as many other files as you want.
godinperson
Would you be willing to help me test that?
I'm not that good with coding!
godinperson
bump!
Anyone? Pretty sure it will take couple of minutes to someone who knows how it works.
godinperson
No programmer that wants to help, probably a 10 min. job.
Anyone from Quebec that would need that plugin?
Qcvictor
Post by Qcvictor »
Me too will be interested to get it working!
godinperson
I might have found someone. Checking with him!
Qcvictor
Post by Qcvictor »
godinperson wrote:I might have found someone. Checking with him!
Sounds good, let us known !
zorbac
Post by zorbac »
Hello people,
I have created something as an external script that communicate with Domoticz server. Is not a plugin as intended as I did not know how to do it.
It can be programmed with a CRON job or from Domoticz on your need. I use it as my internet connection is not 24h up, I activate the scipt only on the first time the internet connection is available.
It save to the current day the value of previous day. Is the only limitation I have with it.
https://github.com/jingl3s/domoticz_hydroquebec
Qcvictor
Post by Qcvictor »
Hey Zorbac
I'm trying to get it working, where is supposed to be the folder "pyhydroquebec"
When I ran it I get couple error !
pi@DomoticzTest:~/domoticz_hydroquebec$ ./hydroquebec.py
2017-11-24 18:05:45,551-  ERROR-main-Erreur d'execution
  File "./hydroquebec.py", line 198, in main
    consommation_veille = _get_hydroquebec_valeur_veille(json_configuration['HYDROQUEBEC'])
  File "./hydroquebec.py", line 39, in _get_hydroquebec_valeur_veille
    output = subprocess.check_output(cmd_hydro)
  File "/usr/lib/python3.5/subprocess.py", line 626, in check_output
    **kwargs).stdout
  File "/usr/lib/python3.5/subprocess.py", line 693, in run
    with Popen(*popenargs, **kwargs) as process:
  File "/usr/lib/python3.5/subprocess.py", line 947, in __init__
    restore_signals, start_new_session)
  File "/usr/lib/python3.5/subprocess.py", line 1551, in _execute_child
    raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] No such file or directory: 'pyhydroquebec'
