dzVents 2.0 just got integrated into Domoticz (beta v3.8023)
Doler
Re: dzVents 2.0 just got integrated into Domoticz (beta v3.8023)
Post by Doler »
Maybe it's specific hardware(interface). It might help when people having problems list their hardware so we can compare.
Mark
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
jeanclic
Post by jeanclic »
Do you have a lot of devices and "classic" scripts ?
-> I have 14 script_device, 17 script_time, 1 php, 23 bash (via crontab most of the time) -> not using any version of dzVents.
-> I have about 175 devices (including dummies).
=> my CPU usage is around 3-4% for domoticz only (some times 0% but come back fast to more due to scripts I assume).
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
dannybloe
Post by dannybloe »
I did have a comparable issue a little while ago with the 'motherboard sensors' hardware freezing up my Pi system. After I removed it it ran like a charm. Perhaps you can try that? Probably unrelated though.
jeanclic
Post by jeanclic »
regarding my hardware : see the picture.
-> I will try to remove the motherboard sensor hardware. but do you know where I can find some scripts examples to replace it ?
EDIT : I observed domoticz using up to 20% of cpu when motherboard sensor disabled instead of 30% with it.
x4 fibaro / x1 PIR
dannybloe
Post by dannybloe »
randytsuch wrote:One comment.
If you use the domoticz events editor (which is very convenient), the example still uses [] for definitions instead of the new convention ()
Randy
Good catch. Fixed that. I thought I converted them all but forgot about this template.
heggink
Domoticz version: 12451
Post by heggink »
Is there a correlation wit Hue lamps?
DASHTICZ 🙃
P1 meter & solar panel
heggink wrote:Some people appear to have issues (high cpu) with 8027 on rpi3. Anyone without these problems on rpi3?
No problems here with events- and dzVents 2.0 active since 8034. CPU < 5% on my RPI3
jeanclic
Post by jeanclic »
see the picture for dzVents enable in my Domoticz : not good !
x4 fibaro / x1 PIR
Phantom
Domoticz version: 4.11652
Post by Phantom »
rpi3 here and cpu is higher then normal also after the last update's.
Running the latsest beta atm Version: 3.8034.
Doler
Post by Doler »
I can confirm that: upgrading from 3.8015 to 3.8027 made my CPU usage (RPI3) go up from average 2% to average 5%. So still low and maybe this is the new normal.
Am I right that people who use dzVents have NO problem whilst others may have. Just a hunch: do people with problems have 127.0.0.1 in their Local Network settings (required for dzVents)?
Mark
jeanclic
Post by jeanclic »
Doler wrote:I can confirm that: upgrading from 3.8015 to 3.8027 made my CPU usage (RPI3) go up from average 2% to average 5%. So still low and maybe this is the new normal.
Mark
I do have 127.0.0.1 in dzVents_settings.lua, and no script at all in dzVents folders (neither via web editor, nor put manually in some folder), but when I activate dzVents, domoticz start using 100% of my CPU... I have to stop domoticz and restart and then I have a few seconds to disable dzVents.
x4 fibaro / x1 PIR
Doler
Post by Doler »
What you could try is disable all your hardware and then enable dzVents and see what happens (just to rule out possible causes).
Mark
dannybloe
Post by dannybloe »
jeanclic, is it possible for you to see which hardware may cause this for you? Can you make a copy of your entire setup (or just the database) and perhaps remove some hardware of scripts to see when the cpu load drops to normal levels?
It's so hard to debug this if you cannot reproduce it yourself.
Your help is greatly appreciated in this. We have to nail this bugger!
dannybloe
Post by dannybloe »
Mark
Well, domoticz is gathering a bit more information than before when it starts the event handlers so maybe that causes a bit more cpu. But just a couple of percents shouldn't be a problem. After all, it's a computer that needs to DO stuff for us ;).
jeanclic
Post by jeanclic »
dannybloe wrote:jeanclic, is it possible for you to see which hardware may cause this for you? Can you make a copy of your entire setup (or just the database) and perhaps remove some hardware of scripts to see when the cpu load drops to normal levels?
I tried to disable hardwares one by one to see the impact on CPU usage: I cannot really conclude anything.
I wrote a basic dzVents script via web interface (to write a log message every minute), just to see if with a script to execute dzVents is happier ? -> no.
I changed 127.0.0.1 to 127.0.0.2 to "loose" dzVents: not better. (btw, is it not possible to include config in the web interface and forget about this dzVents_settings.lua ? -> I do not understand well if this file is overriding the log level or if it is the web setup ?)
-> each time I activate dzVents, CPU usage reaches 100% in seconds.
x4 fibaro / x1 PIR
dannybloe
Post by dannybloe »
You should not use dzVents_settings.lua at all. That's prior to 2.0! The 127.0.0.1 setting is for some commands that don't have 'native' Lua support in Domoticz. Some device types need to call a json/api command. But unlike earlier, this ip address is not used for getting settings anymore.
Make sure that you don't have debug-logging enabled in the settings for dzVents coz that might slow things down quite a bit. Just enable that for special cases and tracking down problems.
jeanclic
Post by jeanclic »
When I tested enabling dzVents, I of course put the logs to "silent", but it is overloading my RPI for all levels.
You say I should not have to modify dzVents_settings.lua ? because I tried to enable dzVents on a Debian I use to test stuffs on domoticz and it worked only after I changed the adress from 10.0.0.8 to 127.0.0.1. (btw on this debian, dzVents is working very well, but I have almost no hardware and I also have absolutely no script except one "web" dzVent for testing)
I changed also the log level in this file to 0, and the logs disapeared as expected.
Maybe I have set something up in a bad way ?
x4 fibaro / x1 PIR
dannybloe
Post by dannybloe »
jeanclic wrote:
dannybloe wrote:
jeanclic wrote: I tried to disable hardwares one by one to see the impact on CPU usage: I cannot really conclude anything.
I don't now. I assume you have dzVents 1.1.1 running as well on this system? 1.1.x is running in /path/to/domoticz/scripts/lua/dzVents while with 2.0 it runs from another directory in the domoticz codebase: /path/to/domoticz/scripts/dzVents. Theoretically they can co-exists. For 1.1.x you do need dzVents_settings.lua. 2.0 doesn't use that at all. At least, it shouldn't.
ednl
Domoticz version: 3.8875
Post by ednl »
Did some troubleshooting myself:
- Dzvents enabled
High CPU Usage
Switching Hue enabled/disabled makes domoticz crash.
"Smart Meter P1" same story.
No problems with other hardware.
- Dzvents disabled
No problems.
Question: The users with no issues: have you got hardware like Smart Meter P1 or hue?
jeanclic
Post by jeanclic »
beeing completely newbie regarding dzVents, I wonder if this path is correct ?
2017-07-02 15_57_58-Debian - Oracle VM VirtualBox.png (11.25 KiB) Viewed 2434 times
x4 fibaro / x1 PIR
Users browsing this forum: hemant5400z and 1 guest
