Using BROADLINK RM2 on DOMOTICZ
kniazio
- Domoticz version: 3.7243
Re: Using BROADLINK RM2 on DOMOTICZ
Interested in: https://www.domoticz.com/forum/viewtopi ... 65&t=16859
- OyyoDams
Do you have any blank space before "import" ?Tisours97410 wrote:Hi , i've got the dame error
Would you give some answear?
pi@raspberrypi:~$ python learn.py
File "learn.py", line 3
import broadlink
IndentationError: unexpected inden
t
pi@raspberrypi:~$
Tisours97410
I removed all Before and i got now :
File "./learn.py", line 2
import broadlink import time import sys
SyntaxError: invalid syntax
Tisours97410
An y idea ?
zak45
- Domoticz version: V2024.4
All import on the same line do not work.
burton666
sorry if this has been answered already, but does this work with the small black RM3 or whatever it is called?
Tisours97410
Hi , i had To reinstall all and i got now: File "learning.py", line 23
else:
Any idea ?
Thé file : print("No button press read - quitting")
sys.exit()
else:
# record learned hex code to file
f = open(codeName +".txt",'w') f.write(myhex)
f.close()
else:
Any idea ?
sys.exit()
else:
f.close()
claudioita
- Target OS: -
is there a guide to use (the best way) broadlink products in domoticz?
I have RMPRO, TC2 switches, and SP3 power plugs
claudioita
- Target OS: -
especially interested for the TC2
betonishard
Dear domoticz users,
Great support / plugin by the way.
I am really struggling to get one IR device working via the broadlink rm2 pro device all other devices working perfectly via the plugin. I tried it with the app NOT working, tried it with plugin (obvioulsy) not working.
It is a cisco 8485 tv tuner (mediabox) form upc (dutch). Is there someone who could help me? Or others who have the same problem. the remote is rc2094501 If you need some debug logs with arduino, I can provide.
Thanks in advance,..
ToneStrife
Hello everyone!
So probably my idea was wrong. I bought the RM2 pro thinkg that when importing from my phone (I have my hole TV remote) I would be able to add a Remote control easyly to domoticz.
Was I wrong? Now I have like 20 devices and I don0t know how to group them
zak45
On the next release (soon) you will have a Remote Control customizable...ToneStrife wrote:Hello everyone!
ToneStrife
Thanks!! Looks really cool!
Hi to all,there is a way for use Broadlink with domoticz on Windows?THX
jackslayter
- Domoticz version: stable
http://www.domoticz.com/forum/viewtopic ... 65&t=17224Andree wrote:Hi to all,there is a way for use Broadlink with domoticz on Windows?THX
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
Onkytonk
Can anyone tell me if I can use the RM as an RF receiver like an RFlink?
I want it to be able to receive RF signals (ie doorbell) and then trigger other devices within Domoticz.
Is this possible or do I need an RF link gateway?
jackslayter
yes in "pro" version http://www.ibroadlink.com/rmPro/
Onkytonk
I can't find anywhere that says what I want to do is possible.jackslayter wrote:yes in "pro" version http://www.ibroadlink.com/rmPro/
I know it will "learn" an RF signal and then transmit it via the app (or domoticz).
But what I want to do to, is create a dummy switch in domoticz, that is triggered by my existing 433mhz doorbell. Or an existing 433mhz remote control.
So will the RM Pro learn/receive the RF signal from the doorbell, and then relay it into domoticz, so I could then trigger other devices?
Or, do I need an RFLink to do this?
zak45
Rflink gateway or RFXCom.
RM Pro will not learn/read RF continously and trigger something in Domoticz
Onkytonk
Ahhh, yeah. That's what I suspected. Thank you for confirming.zak45 wrote:Rflink gateway or RFXCom.
Sent from my iPad using Tapatalk
