Using BROADLINK RM2 on DOMOTICZ
kniazio
Domoticz version: 3.7243
Re: Using BROADLINK RM2 on DOMOTICZ
Post by kniazio »
OyyoDams
Post by OyyoDams »
Tisours97410 wrote:Hi , i've got the dame error
Would you give some answear?
pi@raspberrypi:~$ python learn.py
File "learn.py", line 3
import broadlink
IndentationError: unexpected inden
t
pi@raspberrypi:~$
Do you have any blank space before "import" ?
Tisours97410
Post by Tisours97410 »
I removed all Before and i got now :
File "./learn.py", line 2
import broadlink import time import sys
SyntaxError: invalid syntax
Tisours97410
An y idea ?
zak45
Domoticz version: V2024.4
Post by zak45 »
All import on the same line do not work.
burton666
Post by burton666 »
sorry if this has been answered already, but does this work with the small black RM3 or whatever it is called?
Tisours97410
Hi , i had To reinstall all and i got now: File "learning.py", line 23
else:
Any idea ?
Thé file : print("No button press read - quitting")
sys.exit()
else:
# record learned hex code to file
f = open(codeName +".txt",'w') f.write(myhex)
f.close()
claudioita
Post by claudioita »
is there a guide to use (the best way) broadlink products in domoticz?
I have RMPRO, TC2 switches, and SP3 power plugs
claudioita
especially interested for the TC2
betonishard
Post by betonishard »
Dear domoticz users,
Great support / plugin by the way.
I am really struggling to get one IR device working via the broadlink rm2 pro device all other devices working perfectly via the plugin. I tried it with the app NOT working, tried it with plugin (obvioulsy) not working.
It is a cisco 8485 tv tuner (mediabox) form upc (dutch). Is there someone who could help me? Or others who have the same problem. the remote is rc2094501 If you need some debug logs with arduino, I can provide.
Thanks in advance,..
ToneStrife
Post by ToneStrife »
Hello everyone!
So probably my idea was wrong. I bought the RM2 pro thinkg that when importing from my phone (I have my hole TV remote) I would be able to add a Remote control easyly to domoticz.
Was I wrong? Now I have like 20 devices and I don0t know how to group them
zak45
Post by zak45 »
ToneStrife wrote:Hello everyone!
On the next release (soon) you will have a Remote Control customizable...
ToneStrife
Thanks!! Looks really cool!
Andree
Post by Andree »
Hi to all,there is a way for use Broadlink with domoticz on Windows?THX
jackslayter
Domoticz version: stable
Post by jackslayter »
Andree wrote:Hi to all,there is a way for use Broadlink with domoticz on Windows?THX
http://www.domoticz.com/forum/viewtopic ... 65&t=17224
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
Onkytonk
Post by Onkytonk »
Can anyone tell me if I can use the RM as an RF receiver like an RFlink?
I want it to be able to receive RF signals (ie doorbell) and then trigger other devices within Domoticz.
Is this possible or do I need an RF link gateway?
jackslayter
Onkytonk
Post by Onkytonk »
jackslayter wrote:yes in "pro" version http://www.ibroadlink.com/rmPro/
I can't find anywhere that says what I want to do is possible.
I know it will "learn" an RF signal and then transmit it via the app (or domoticz).
But what I want to do to, is create a dummy switch in domoticz, that is triggered by my existing 433mhz doorbell. Or an existing 433mhz remote control.
So will the RM Pro learn/receive the RF signal from the doorbell, and then relay it into domoticz, so I could then trigger other devices?
Or, do I need an RFLink to do this?
zak45
Post by zak45 »
Rflink gateway or RFXCom.
RM Pro will not learn/read RF continously and trigger something in Domoticz
Onkytonk
Post by Onkytonk »
zak45 wrote:Rflink gateway or RFXCom.
Ahhh, yeah. That's what I suspected. Thank you for confirming.
Sent from my iPad using Tapatalk
