I'm trying to built an event in Domoticz using the security status. In block editor the security status is available as a standard block. The status can be disarmed, armed home and armed away. However, the status of the built in security code panel is disarm, arm home and arm away. Therefore nothing will happen when I used the block event with the built-in security status. How can I solve this??
Security status in block events
Mario1972
- Schermafbeelding 2017-06-18 om 07.12.46.png (18.87 KiB) Viewed 1502 times
- Schermafbeelding 2017-06-18 om 07.07.46.png (394.21 KiB) Viewed 1502 times
- heggink
- Domoticz version: 12451
Re: Security status in block events
Blocky can only be used to test the status, not to switch it. Hence lua scripts used in the alarm system wiki.
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
