Security status in block events
Mario1972
Post by Mario1972 »
I'm trying to built an event in Domoticz using the security status. In block editor the security status is available as a standard block. The status can be disarmed, armed home and armed away. However, the status of the built in security code panel is disarm, arm home and arm away. Therefore nothing will happen when I used the block event with the built-in security status. How can I solve this??
Schermafbeelding 2017-06-18 om 07.12.46.png (18.87 KiB) Viewed 1568 times
Schermafbeelding 2017-06-18 om 07.07.46.png (394.21 KiB) Viewed 1568 times
heggink
Domoticz version: 12451
Re: Security status in block events
Post by heggink »
Blocky can only be used to test the status, not to switch it. Hence lua scripts used in the alarm system wiki.
P1 meter & solar panel
