Fontsize of textsensor
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi All,
Is there a way to adjust the fontsize and color of a textsensor in LUA
Jan
JuanUil
Re: Fontsize of textsensor
Post by JuanUil »
anybody any idea?
zicht
Domoticz version: 2023.1+
Post by zicht »
Since the dashbord displays HTML with jquiry you should be able to use HTML code (i hope :P)
If that works you could be able to use colors also..
Never tried it ...
JuanUil
Post by JuanUil »
Tnx for your reply,
but.....
any idea how to do that, because I have no clue...
Jan
G3rard
Domoticz version: No
Post by G3rard »
Try this
http://192.168.1.170:8080/json.htm?type=command&param=udevice&idx=62&nvalue=0&svalue=<font%20size=”6”>TEXT</font>
I have even tried showing the album art of what's playing on the Sonos, but that didn't always work, sometimes the switch disappeared.
But after svalue= you can place any kind of HTML code.
Not using Domoticz anymore
zicht
Post by zicht »
You can even add a second text line with adding a <DIV>
and also hyperlinks to external (for this be aware of crossdomain errors)
example from used in a rainscript:
test="<A href='http://weerslag.nl/bliksem#' target='_blanc'><font size='2' color='"..color.."'>"..tmp2.."</font></a><div><font size='2' color='black'>"..tmp3.."</font></div>"
if otherdevices['Regen Verwachting'] ~= test then commandArray['UpdateDevice'] = '636'..'|0|'..test
Where tmp2 is my returned function variable , displayed on top in color depending on the value (amount of rain)
and tmp3 is my second returned function variable displayed below in black. (display the times -can be multiple- the rain is expected)
