Hi All,
Is there a way to adjust the fontsize and color of a textsensor in LUA
Jan
Fontsize of textsensor
JuanUil
- Domoticz version: 4.11083
JuanUil
Re: Fontsize of textsensor
anybody any idea?
zicht
- Domoticz version: 2023.1+
Since the dashbord displays HTML with jquiry you should be able to use HTML code (i hope
If that works you could be able to use colors also..
Never tried it ...
Never tried it ...
JuanUil
Tnx for your reply,
but.....
any idea how to do that, because I have no clue...
Jan
but.....
Jan
- G3rard
- Target OS: -
- Domoticz version: No
Try this
I have even tried showing the album art of what's playing on the Sonos, but that didn't always work, sometimes the switch disappeared.
But after svalue= you can place any kind of HTML code.
http://192.168.1.170:8080/json.htm?type=command¶m=udevice&idx=62&nvalue=0&svalue=<font%20size=”6”>TEXT</font>But after svalue= you can place any kind of HTML code.
Not using Domoticz anymore
zicht
You can even add a second text line with adding a <DIV>
and also hyperlinks to external (for this be aware of crossdomain errors)
example from used in a rainscript:
Where tmp2 is my returned function variable , displayed on top in color depending on the value (amount of rain)
and tmp3 is my second returned function variable displayed below in black. (display the times -can be multiple- the rain is expected)
test="<A href='http://weerslag.nl/bliksem#' target='_blanc'><font size='2' color='"..color.."'>"..tmp2.."</font></a><div><font size='2' color='black'>"..tmp3.."</font></div>"
if otherdevices['Regen Verwachting'] ~= test then commandArray['UpdateDevice'] = '636'..'|0|'..test
